Old 04-24-2010, 03:55 PM   #451
Strodder
Daring to be Different
Strodder's Avatar
Re: Shrunken66Stroker's build thread.
What new fuel requirements
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 04-24-2010, 11:25 PM   #452
Bulldoser65
I just read through your whole build thread. I must say, great build, very motivating.
I just got a 65 Stepside SBW last mth, its needs alot of work, and your build gives me alot of ideas.
Its my DD right now, but when my 89 mustang gets outta the body shop, I will start driving it more and pull the truck into the garage and start working on the rust and other things.
-John
Bulldoser65 is offline   Reply With Quote
Old 04-25-2010, 09:43 PM   #453
creep
Registered Loser
creep's Avatar
Could you give me the dimensions of the Blazer tank? Did you have to cut the frame any to get it in there? I am going to raise my bed floor about 7" to clear my suspension and would like to to have as little tank below the frame as possible.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 04-25-2010, 10:00 PM   #454
daverod
SSN 706
daverod's Avatar
If your going to raise your floor why not raise the tank also?
daverod is offline   Reply With Quote
Old 04-25-2010, 11:30 PM   #455
shrunken66stroker
shrunken66stroker's Avatar
I didn't cut the frame to get it in there but I took out everything behind the crooked cross member. I jacked up the bed slid the tank in between the C-channel of the frame rails on both sides. The pinch weld that holds the two halves of the tank together is sitting on the inside of the frame rail. It is a long tank. I had to notch out the back cross sill. I'll shoot some picks and post them for you soon.
If your bed floor is going up 7" you should be able to tuck the tank almost all the way up inside the frame.
shrunken66stroker is offline   Reply With Quote
Old 04-26-2010, 07:21 AM   #456
creep
Registered Loser
creep's Avatar
I was thinking about just dropping it in on top of the frame rails if it would fit. I found on LMC that the tank was about 28" wide but I assume that was the flange and not the actual tank. Mine is a long bed and the crooked crossmember has been removed because of the bridge notch.
Old 06-25-2010, 08:26 PM   #457
shrunken66stroker
New developments. Out with the old 350.
Old 06-25-2010, 08:31 PM   #458
shrunken66stroker
Almost time to build an LS2.
Old 06-25-2010, 08:36 PM   #459
shrunken66stroker
Got the stainless brake lines plumbed. The kit is from Inline Tube. It fit great but they don't make a conversion for rear disk. I had to make some custom bends on the ends and luckily the Baer brake kit came with braided hoses with banjo fittings.
Old 06-25-2010, 08:55 PM   #460
shrunken66stroker
Here's how it sits at the moment. Planning the engine build has taken a while, especially since I've never touched an LS motor.
Old 06-25-2010, 09:08 PM   #461
Joemomma1
Joemomma1's Avatar
That 350 looks new, why the change?
Joemomma1 is offline   Reply With Quote
Old 06-25-2010, 11:53 PM   #462
shrunken66stroker
It is new-ish. It's got 25000 miles on it but took it out and painted it, put new freeze plugs in it, worked the stock heads, new intake, headers, water pump, oil pump, etc. I'm trying to get rid of it now. I just thought the LS2 fit the build better and I'm interested in the LS fuel injected stuff. Basically curiosity is the reason for the change.
Old 06-26-2010, 01:01 AM   #463
apachedaddy
apachedaddy's Avatar
What year/modle kit did you order that fit so well??
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
Old 06-26-2010, 02:54 AM   #464
shrunken66stroker
The stainless brake line kit was for a 66 short bed with a disk conversion. The Baer brake kit was the Track Plus 13" rear set up.
Old 07-08-2010, 08:11 PM   #465
scotts62
One day...
scotts62's Avatar
Very nice build you have going, keep up the good work!
Scott
93 crew cab build
Project 62
Old 07-08-2010, 11:18 PM   #466
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
plus your ls2 is gonna kick that 350's ass
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 07-08-2010, 11:25 PM   #467
gixxerpymp
Sick!
gixxerpymp is offline   Reply With Quote
Old 07-09-2010, 12:21 AM   #468
shrunken66stroker
Thanks guys. The LS2 weighs 100 lbs less and will have 100 ft lbs. more torque. It's draining my wallet but the whole project is far beyond what ever budget I had in mind in the first place. This is how things snowball out of control, I guess. I still don't have a transmission but I think I can get a T56 for a decent price or drop a little more for a tko-500. Not sure yet.
Old 07-09-2010, 08:23 PM   #469
protrash64
Resistance is Futile
protrash64's Avatar
.......no doubt!! You need to get a second one, too.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-09-2010, 08:41 PM   #470
shrunken66stroker
I've had my eye on the burbs for while. It's either that or a 63 fleet bbw. damn it. it's got ahold of me.
Old 07-10-2010, 02:01 AM   #471
ratty 46
Looking good ...
Ratty 46
ratty 46 is offline   Reply With Quote
Old 07-10-2010, 02:44 PM   #472
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
what heads are those
Gage
Old 07-10-2010, 02:53 PM   #473
shrunken66stroker
Brand new L92 heads from a 6.2 liter. They flow like crazy in stock form and are pretty cheap. $650 for new assembled aluminum heads that flow 320 cfm @ .550 lift out of the box. Serious flow from a stock head. The valves are 2.16 intake and 1.59 exhaust.
Old 07-10-2010, 04:35 PM   #474
strokerPop
strokerPop's Avatar
Wow! Just blew my morning reading thru your build. You got the addiction bad!
Thanks for the insperation. Keep up the great work. Looking forward to following your build.
So I'm headed to the garage.......
Brad
strokerPop is offline   Reply With Quote
Old 07-11-2010, 11:36 AM   #475
shrunken66stroker
Thanks. The other projects keep eating into my truck time so there's been little progress lately. I should have the other time sucker done by August(hopefully) and then it will be full speed ahead on the truck. I want to wait till there's no distractions and I have all the parts to build the engine. I have 95% of the parts already, but I have to sell the 350 and T-5 first before I can get another trans. I'll post it on CL soon so it shouldn't be long till I have the tko 500 on my doorstep.
1966, bagged, disc, long to short, stroker
