#451 |
![]() Join Date: May 2009
Re: What did you do to your truck today?
Hey Tony received the steering wheel today it's in great condition to as some I've seen looking around, it will look nice on the truck. Thanks allot and again Happy Holidays I'm well pleased.---Vernski
#452 |
I actually got out there and spent a few hours cleaning the front end up to paint. Starting to get in the mood to work on it again.
#453 | |
Junior Member
Any idea what the clock is out of?
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() |
#454 |
Member of the longbed union.
I didn't do anything to the truck, but I did buy a new rebuild kit for my Demon carb! Anyone want a 750 Holley, never had gas in it!
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#455 |
Worked on my front cross member for my back half today. Its a little over built but its for my wishbone link. I messed up and cut my tube wrong so now the seam faces the wrong way wich is one of my pet peaves, so I'll try and sand that down and make it look as un noticable as possible.
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#456 |
wired new fancy plug to the alternator...
removed, tested and replaced with a new... engine module. ran a test to confirm if alternator was charging... it was. Pulled voltage regulator and bought a new one. I hope to replace that, tomorrow. I also hope my headlights come back on... -W |
#457 |
![]() Join Date: Sep 2009
I installed LED taillights and a new flasher in my 66 GMC today. Nice and bright.
66 GMC 1500 Series LWB |
#458 |
I checked out the shop, while my Dad was talking trucks with the fellas!
#459 |
The Beach Cruiser
I installed my fuel sending unit and made brackets to mount the tank to the frame. Only one old strap holding the tank. I'm sure glad it never broke.
1999 Silverado DD ![]() 1966 Panel Truck 2003 Harley Road Glide ![]() 1967 Schwinn Tandem Single Speed |
#460 |
Give him the keys Tony, Looks like he's ready for a spin around the block
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl Last edited by 198plus; 12-19-2009 at 10:43 PM. |
#461 |
I installed the new voltage regulator and ran a ground wire from the ground post on the new alternator.
The biggest aggravation were getting the nuts onto the 3 bolts that hold the v. reg. to the radiator support. yeesh! it is running and charging again tho', so yay! -W |
#462 |
I moved my truck out of the garage yesterday to work on my buddies Honda, then moved it back in today. I took a pic because I thought it looked cool. I had to have him sit in the engine bay and put gas in the carb out of a bottle because my fuel pump went out.
#463 |
Cut the exhaust off of my truck right off the manifold, de-rusted and painted the headers, got that little 6 running a bit better. More to come tomorrow.
1982 K10 SWB 1987 V20 - Sold - Doh! |
#464 |
Blasted and painted cateye capsules to install new lenses for my 65 GMC,fixed the horn button on steering wheel,cut out exhaust to pipe up to headers.And tested all lights,turn signals and brake lights.Almost ready for inspection.YEAH!
#465 |
We made a little more progress on OLRED66.
#466 |
And a few more of our progress...
#467 |
sanded and primered the tailgate...sorted and put away all of the tools that have acquired in the bed
#468 |
Made templates & started fabbing my new rear upper shock mounts. I needed 17" overall length @ ride height & was shooting for 60° angle. I think my number crunching worked . . ....
#469 |
Got both front fenders sanded and maybe some paint this week.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#470 | |
chevy only
![]() Join Date: Sep 2006
CHEVY ONLY... Nothin Else ! |
#471 |
The Beach Cruiser
Took the panel out and gave her a top off of petro. I averaged 11.7 mpg on the only tank I have checked.
That includes her sitting at idle in the garage multi times and draining the line to replace the sending unit. It's good to see the gauge working. ![]()
#472 |
I sanded some of the rust off of my roof and then spread a little filler and got it sanded back down.
#473 |
One day...
Put my trans on the work table, going to attempt my first rebuild
#474 |
not much today just worked on some 3/4-16 Weld in bungs for my 4 link.
#475 |
Sunburst C10!!!
i did nothing again
Gage 1967 C10 Shortbed Stepside |
