10-15-2011, 11:06 PM | #451 |
Re: My 68 swb build.
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
10-15-2011, 11:12 PM | #452 |
this is the start of a really big hole...will be 3 inches soon...
10-15-2011, 11:32 PM | #453 |
Man of Mini-Talents
Love the gleam in this shot....
When you get white to reflect like that, that's remarkable. Nice work!
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
10-16-2011, 01:03 AM | #454 | |
10-16-2011, 01:44 AM | #455 |
VA72C10
very nice!!!
Looking for a 67-72 swb or blazer project in or around VA. |
10-16-2011, 12:07 PM | #456 |
Sofa King Crazy!!
Did you get the one peice windows completed? Looks very clean!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
10-16-2011, 01:38 PM | #457 |
low n' slo
looks nice!
how much did the one piece window kit set u back?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
10-16-2011, 01:42 PM | #458 |
PROJECT 7DEUCE
Hey chris ill trow up some pics here in a few on what I did with my harness its an ez wire set up btw..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-16-2011, 04:43 PM | #459 |
Oh ya. Finished them last nite. I still have to set one glass on the sash but i dont wanna put the glass in until I have the doors mounted and lined up. Less weight the better.!! BTW we had a killer nite Friday chilling at the house with u. She loved lcr so much she demanded to get it last nite at Walmart.
10-16-2011, 04:47 PM | #460 |
It was sort of a pckage deal. I bought the cab,doors,radiator,fans and a bunch of little misc parts for $1500. There is a set on craigslist for 250-300 and he's been trying to get rid of it for a while. dont know the specs on his but mine is electric. So far its easy to install. With tje doors off of course.
10-16-2011, 04:49 PM | #461 | |
10-16-2011, 05:23 PM | #462 |
Sofa King Crazy!!
Glad that yall were able to make it and had a good time, I enjoyed it too! That's funny how she "demanded" LCR!! It is a fun game.
10-17-2011, 12:31 AM | #463 |
Well I got a little bit done tonite but not much. I got the hole for the a/c box and mounted. I didnt get it perfectly level but I think its gonna have to do for now. I might fix it when I pull it off to drill the drain hole. Got the a/c control gauges in. Mocked a few a/c hoses up put all the clips on the dashpad and bolted it down. Having a small problem with the defrost vents not wanting to fit but I think I can make them work. Mocked up the glovebox and installed the glove box latch and door. All of this will come back off so I can finish the a/c. It doesnt seem too hard but the wiring is scary. Lots of relays everywhere!! Go the brake pedal assembly mounted and as soon as I figure where to put the fuse block ill start tackling that. I'm suprised the glove box fit with the cut firewall. I will post pics as. Soon as i get another router here at my house. My ex roomate took his back the other day. So no wireless internet yet.
10-17-2011, 11:27 AM | #464 |
my new toy!!! This thing wasnt that bad. 79 bucks and then 14 bucks for the 3".. SORRY FOR THE BLURRY PICS, PHONE WAS GOING DEAD LAST NITE AND I WANTED TO GET A FEW SNAPSHOTS BEFORE I WENT TO BED...WILL HAVE BETTER NEXT TIME.....i PROMISE...LOL
10-17-2011, 11:45 AM | #465 |
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 Last edited by 77chris03; 10-18-2011 at 12:48 AM. |
10-17-2011, 12:02 PM | #466 |
10-17-2011, 05:14 PM | #467 |
PROJECT 7DEUCE
hey chris my phone does not wanna post up those pics I think I still have ur number...btw on the cowl not in a hurry on my end so when ever ya got time..
10-17-2011, 05:20 PM | #468 |
PROJECT 7DEUCE
Lets try this
10-18-2011, 12:56 AM | #469 |
You got the mini one right? I got the 21 circuit. And no problem on the cowl. I did get a few things done the past few hours. Pulled the glove box back oit, wired the fan motor and thermostat cut and ran all but the drivers a/c hose. There's one wire I have no idea where it goes. It says trinary on it. Wth is that suppose to mean? The defrost vents I got to work with a little filing down to fit. Next is the wire harness block mounting or should i do the ebrake pedal first? Also put the glove box and got the door lined up.
10-18-2011, 05:06 PM | #470 |
PROJECT 7DEUCE
Mine is the mini fuse box...
10-19-2011, 01:05 AM | #471 |
Maybe I'm over exaggerating but this harness is wired funny. The rear section is done no problem except the dome light wire I forgot to pull out of it but no biggie. Pretty much got the ignition switch done. On the ignition switch it has two wires from the harness labeled " ignition switch coil" and " ignition switch igniton" and the go to the same terminal. Do these two wires get spliced together or what or take one out?
Now on the headlights switch it says to splice two wires together( red and orange). But my problem kid I'm missing the "dome return" and " instra panel power". What do I do? Any help? Posted via Mobile Device
10-19-2011, 08:14 AM | #472 |
anyone???
10-19-2011, 11:11 PM | #473 |
Not even a sorry we dont know? Dang this thread is dead!!
10-19-2011, 11:35 PM | #474 |
VA72C10
sorry, don't know
I'd post the question (with pictures of the wiring) in the electrical forum. There's some very knowledgeable guys that hang out in there to help people in these situations... might take more than a few hours for a response though....so be patient
10-20-2011, 09:23 AM | #475 |
Nice build you have and nice deal on the cab itself. I saw all the pictures and sped read so I'm sure I missed a lot.
Nice to see some of you are somewhat local to me. I'm new and am looking around for my first truck to build. I'm sorry to hijack, but can y'all recommend me some shops that might help me with my future build? Upholstery, sheet metal, paint, etc... anything. Thanks and keep up, 77Chris. Glad to see you made out ok through that nasty motorcycle accident. -Ulysses Last edited by LEX; 10-20-2011 at 09:29 AM. |
