11-22-2013, 12:17 AM | #451 |
Re: Project '64 Cheapskate
As usual, outstanding work from you and Brad!!! I can't wait to see the end result.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
11-22-2013, 12:58 AM | #452 |
Thank You, sir!
Thanks, Phillip! Thanks! Brad is probably the only guy I know who thinks like I do when it comes to hot rods. We've collaborated on a lot of stuff over the years. He's one talented dude.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
11-23-2013, 05:36 PM | #453 |
The weather has been cold and rainy for the past few days, so it has given me an opportunity to turn up the heater and the tunes in the garage and get crackin'.
Today's project was assembling the A/C condenser, the receiver/dryer, and the lines on the newly painted core support. I'm real happy with the results: I don't like the look of a body-colored core support poking through the grill of any car or truck, so everything had to be black. If you recall some posts from a few months ago, I modified the core support to accept a 2001 Corvette A/C condenser. It meant that I had to cut pockets in the uprights to give clearance for the inlet and outlet fittings. I used a couple pieces of 2"x 2" square tubing to fill the cutouts and Mig welded them in. The hard line at the inlet on the bottom of the condenser is a combination of the factory Corvette line and a #6 A/C crimp fitting that I had a buddy Tig weld together. The factory outlet line at the top of the condenser was chopped off and a fitting to accept a #10 Beadlock style A/C hose was Tig welded on. All of the fittings were bought on ebay for cheap, the hose was extra pieces I had laying around, and a buddy crimped them for me. The dryer was also an ebay special ($14.99). I put some heat shrink on the dryer clamps to tighten them up a little bit and to also insulate the dryer from metal-to-metal contact. The core support actually looks better in person versus the pictures because the camera flash does weird stuff with the satin black and makes it look blotchy and shiny. Next task: Install all of the rubber seals on to the inner fenders.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 Last edited by chevyrestoguy; 11-23-2013 at 05:42 PM. |
11-23-2013, 08:51 PM | #454 |
Looks nice cheapskate. Got me motivated dude!
11-23-2013, 10:13 PM | #455 |
Kool man.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
11-24-2013, 12:14 PM | #456 |
That's TIGHT!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
11-24-2013, 01:39 PM | #457 |
chevy only
and that's how's done !!
CHEVY ONLY... Nothin Else ! |
11-24-2013, 09:46 PM | #458 |
Thanks for the comments, guys! I've been on a roll, and today was a big day. It was time to start bolting stuff together for the last time. No more mocking up and taking it all back apart.
I realized that I had never taken any pictures with the engine installed. It's been installed for a few months now, but I've been focusing on other stuff, so I apologize. Here it is: We had to to be extra careful installing the inner fenders and core support, and I'm lucky I had Brad helping me. This is definitely a 2-person job. We had a few issues to contend with and a couple of holes needed to be slotted slightly, but that's to be expected when you're putting one of these things together and trying to make it all fit right. Here's a teaser shot of how the inner fender lower edge sits in relation to the frame. It looks factory, and that's what I was going for. I don't want anybody to figure out that the chassis has been Z'd. I've got more time in those dumb inner fenders than I want to admit, but it was all worth it. In all of the excitement, I forgot to take pictures of the core support installed. I can't believe I forgot to do it, but take it from me, it looks good. I promise to take pictures of it next weekend when I get back on it. I have a big list of things to accomplish next weekend, and if it all goes to plan, the front sheet metal will be on the truck. A big thanks to Brad for the helping hand. We thought we were in for trouble when the driver's fender to door gap was huge and we were completely out of any more adjustments. We couldn't move the fender back anymore. After about 45 minutes of racking our brains, Brad figured out that the driver's front cab mount needed to be shimmed up. Once we jacked up that corner, the gaps came in perfectly. I was thinking the worst and figured that the inner fenders and core support all needed to come back off and get tweaked. What a relief.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 Last edited by chevyrestoguy; 11-24-2013 at 09:54 PM. |
11-24-2013, 10:14 PM | #459 | |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
11-24-2013, 10:22 PM | #460 |
Ditto, nice work! A/c routing looks premo
11-25-2013, 09:10 AM | #461 |
Motor/firewall looks great! Can't wait to see the big holiday weekend progress! No better words than "for the last time".
ps- Brad hiding an s-10 from someone else's wife?
11-25-2013, 09:42 AM | #462 | |
The S-10 is one of Brad's Land Speed projects. Right now, it's just a shell. His intent is to break Gale Bank's long-standing pickup truck landspeed record, but once he started building the streamliner, the S-10 has been on hiatus.
11-25-2013, 11:12 AM | #463 |
Ha, he's gonna have to build a patina'd 70's Peterbilt to haul all his stuff to the Salt!
"Hey, where's Brad?" "Utah." "When's he coming back?" "Next month. Maybe." Salt Fever, watch out for it, Kids.
11-25-2013, 11:26 AM | #464 |
Your modifications, unless you know what to look for you don't even see them.
I can hear people now,"Somethings different but I don't know what he did!???!!" Great job. Keeps me on my game. |
11-25-2013, 12:53 PM | #465 |
The lines look absolutely killer!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
11-25-2013, 07:03 PM | #466 | |
Thanks, John! I wish I would have taken some pictures with the core support installed, because it makes the inner fender mods even more stealthy. You'll see those pictures this weekend.
11-26-2013, 10:35 AM | #467 |
Alex has done a great job on his truck! He's kept on his path of keeping the truck simple but with lots of little details, I just have to keep reminding him that he's building a driver and not a Ridler contender! I know how much fun we've had going to different events in my truck and I'm excited for him to have to pick ME up for a road trip! This thing is gonna be sooooo cool!
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 |
11-27-2013, 05:47 PM | #468 |
Man if I lived closer you guys would be picking me up...hahaha.
11-27-2013, 07:52 PM | #469 |
did you just paint the lines after they were crimped? looks good
11-27-2013, 10:22 PM | #470 |
Post Whore
WOWZA! looking good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
11-27-2013, 11:17 PM | #471 |
Been a minute or 3 since I checked in…
Looking Great!!!
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
11-28-2013, 11:06 AM | #472 | ||
Heck yeah, Rusty. I'd gladly pick you up!! Quote:
Thanks, T.J.! Standby, Don! There's more pictures coming!!
11-28-2013, 12:19 PM | #473 |
Post Whore
YEAH! More pictures!!!! LOL!
11-28-2013, 08:24 PM | #474 |
More pics.....please....purty please.
11-30-2013, 12:27 AM | #475 |
some killer work you have been doing man!! I really dig your build. super clean
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
