11-08-2014, 02:18 PM | #451 |
Re: 1964 Caprick-up = (C10+SWB)*(94 Caprice 9C1+LT1)
Here is an update. Took Elie on a road trip last weekend. Got the bed cover on a few weeks ago. Run 80 mph with ease and got 18 mpg.
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
11-08-2014, 02:19 PM | #452 |
Mt Scott are in Oklahoma
11-08-2014, 02:21 PM | #453 |
Muscle Car Ranch in Chickasha Ok.
11-08-2014, 02:22 PM | #454 |
Halfway up Mt Scott.
11-08-2014, 02:24 PM | #455 |
Maybe the future owner. We shall see.
11-08-2014, 02:38 PM | #456 |
Rollin' Old Skool
You got some cool new pics! Truck is looking good, & it sounds like it's running good too.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
11-08-2014, 03:25 PM | #457 |
The 60-66 GMC/Pontiac guy....
Do you have pics of the COE? ??
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
11-08-2014, 09:00 PM | #458 |
It's in peices. Some metal work done to the floor, steering column and brake pedal mocked up. Have a 94 Chevy 1ton for it to go on. Going to make a driver NOT a car hauler like everyone else. Use it to pull my car hauler around.
11-08-2014, 10:49 PM | #459 | |
What's not to love on that classic..?
11-08-2014, 11:05 PM | #460 |
Twin turbo coronet first!!! :-)
04-01-2015, 06:22 PM | #461 |
WOW !!!! I'm jealous! Love the build.
What headlight switch did you use? I'm in the middle of a similar build. A 58 chevy short bed on a 92 roadmaster frame, I'll be using a 89 fleetside bed for now looking for a deal on a correct fleetside bed, but so hard to find. did you get your cruise fixed yet? Here is mine... http://67-72chevytrucks.com/vboard/s...d.php?t=627984
http://67-72chevytrucks.com/vboard/s...d.php?t=627984 |
04-01-2015, 09:24 PM | #462 |
Thanks, love driving it!!! I used the caprice switch and tucked it under the dash. I am stumped on the cruise. I was messing with it yesterday. Still think it's a ground issue in the brake light circuit. But I put bulbs in all the holes and it doesn't work. Could be the cruise box. Guess I'll pick one up at the salvage yard and try it.
04-02-2015, 02:24 PM | #463 |
6>8 Plugless........
Wow, your truck turned out sweet! It's been a while since I checked on your progress. It's nice to see you driving it and enjoying it. That COE is pretty nice and looks rust free. The Coronet will be a blast too!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-02-2015, 02:54 PM | #464 |
I agree with all the comments above. The truck looks awesome. Truly a work of art!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-27-2015, 02:05 PM | #465 |
Thanks!!! It is a lot of fun. Definately a conversation piece.
04-27-2015, 02:25 PM | #466 | |
Moderator
04-27-2015, 03:02 PM | #467 |
Had a buddy in high school that had a 66 coronet, back when I had my old 69 chevelle ss. We spent a lot of time cruising around in those two cars......sure brings back memories.
Always been a fan of mid 60's - early 70's mopar
04-27-2015, 04:13 PM | #468 | |
I put working light bulbs in all the old sockets and its still not working. I wish I could find out exactly what voltage the ckt 17 (brake light curcuit) is looking for so I could just mimic it and be done. But can not find any details. I will find a working caprice with cruise and see if I can take some voltage measurements..
12-05-2015, 05:08 PM | #469 |
Did you ever consider z-notching the front portion of the Caprice frame to get a little more drop. That may have taken up some of the gap in the engine bay, but also could have caused other issues. Your thoughts, pros & cons, as we are doing the same conversion.
12-05-2015, 07:36 PM | #470 |
Definitely would not have z-notched it.. I did consider moving the drivetrain back and bringing it up 2 inches or so. But I didn't want to shorten the driveshaft and rebuild all the mounts.. If I was going to go to that kind of trouble I would have just transplanted the drivetrain into a factory frame…
12-05-2015, 07:53 PM | #471 | |
The main reason why I ask is because we want to be as low as possible. I'm not sure if installing an air ride kit for the Caprice will do it or not. |
12-05-2015, 07:59 PM | #472 |
I'm pretty sure I could lay the frame on the ground. The top a-arms sit on top of the frame, unlike trucks, so you should be able to get it really low as long as you tub the front inner fenders.
12-05-2015, 08:05 PM | #473 |
I'm hoping we can find some kind of middle ground with the right wheel and tire combo along with bags that will minimize clearance issues up front. But, I know we are blazing a trail for the most part. I'd love to try and retain the Caprice heating and cooling system but you mentioned in your thread that it didn't look too hopeful.
12-05-2015, 08:58 PM | #474 | |
The wheels do sit in a little on mine. But no doubt I could drop mine another 2-3 inches and still drive it. Posted via Mobile Device |
12-05-2015, 10:49 PM | #475 | |
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
