#451 |
Re: How about some pics of Static dropped 60-66
HELLO IM NEW HERE THIS IS MY 65 JALOPY BACK YARD SPECIAL. TO WHAT I KNOW IT HAS WESTERN 73-87 2 1/2" DROP SPINDLES, CPP 2" DROP SPRINGS, THE REAR I DON'T REALY KNOW, AND 235/75R15 ALL AROUND. I HAVE MANY PLANS BBW, LOWER REAR MORE, ALL THE BODY WORK, A REAL PAINT JOB(NOT MY RATTLE CAN DELIGHT) ECT.
![]() Last edited by ccachorro8; 09-18-2013 at 11:56 PM. |
#452 |
#453 |
#454 |
^^^^ nice! ^^^^
#455 |
My 63
#456 |
#457 |
Here's my 65, CPP drop springs and spindles.... close to being done.
#458 |
Oh, this is so hot. I'd add some pin striping to give it that edge I like. But regardless, this is one bad mofo.
Live and let live ![]() |
#459 |
Well, I just traded for the truck so I'm still checking stuff out but it does have cpp discs in front with coils that look new and 225/70/15. The back is leaf with air shocks on a 9" and Mt Indy n-50s. Nothing fancy but she sits good.
P.s. thanks for having me. Posted via Mobile Device
#460 | |
![]() Join Date: Oct 2013
#461 |
#462 |
Fronts are 255/50-18's on 8" wheels and rears are 295/45-20's on 10" wheels. Thanks!
#463 |
#464 |
Yes, the rear wheel tubs are stock. I did trim about 3/4" from the lip on the wheel well opening. From the factory there's close to an inch and a half lip so there's still plenty material left. If I remember right the wheels are 4 1/2" backspacing. I used the factory rear end, I just had the axles redrilled to five lug. A lot of people swap to a '71/'72 rearend which is wider and in which case would probably need a 5" backspaced wheel. There's not a lot of clearance but enough. I really like the 10" wheel but didn't want to widen the tubs, this combination works well.
#465 |
Cut coils all round with 2"blocks in the rear 1966 c20
#466 |
Here's mine! Three inch drop springs and 1 and 1/2 blocks in the rear with 2.5 inch drop spindles with 1 coil cut.
#467 |
This is my longbox 66. I'm not big on bags, I like to see them lowered but not touching the ground, in my humble opinion Some rake is important too.
#468 | |
Rollin' Old Skool
![]() While I personally don't feel the need for a ground scraper myself, I will say that bags can be utilized to achieve a killer rake as well. Perfect example would be Dino's blue '66: http://67-72chevytrucks.com/vboard/s...d.php?t=556602
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#469 |
![]() Join Date: Aug 2012
rustbucket66 - sharp looking truck!!! What the specs on your drop and tire sizes? That's about how I want my 66 longbed to sit.
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
#470 |
#471 |
Rollin' Old Skool
Nice looking truck, & looks like an awesome shop setup as well!
#472 |
Thanks fellas. The wheels are Appliance tru-spoke fine wires, 15x10 in the back and 15x8 in the front. I've had them for years and they were pretty rusty so I had them repaired and respoked. Appliance has been out of business for years. I can't find a new wheel that is the same. Tires are 295's x50's in the back and 245'sx50's in the front, but I think I will go to a 60 series tire in the front. The front is dropped 4 1/2 inches - 2 1/2inch drop spindles and 2 inch drop springs. The back is dropped 4 inches with 4" drop springs.
#473 |
Just another pic of my "Rattle Can"
#474 |
#475 |
