06-19-2014, 04:25 PM | #451 |
Re: 1970 SWB : Porterbuilt to the Extreme "Double E"
I hope so. I just want to be able to drive it off a trailer into the show and back on the trailer for the time being. Keep in mind this will never be a trailer queen but I do want people to see what I have been working on, lol. I don't think id be able to drive on the street without a windshield anyway, lol.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme Mike |
06-19-2014, 08:20 PM | #452 |
Great build. Subscribed to see it progress more.
06-22-2014, 10:52 PM | #453 |
Thanks. More to come.
06-22-2014, 11:05 PM | #454 |
Worked on the truck for about three days straight. It doesn't look like I got a lot done but I feel like I did accomplish some things.
- final mount of the core support - modified core support to fit the radiator much better - mounted the steering wheel and hooked up the rack and pinion to the column - routed new power cables to the rear and ran all the power wires to a distribution block - welded up bed floor frames - buttoned up wiring under the dash - routed all wiring to the core support through the frame rails I'm sure I forgot some things
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme Mike Last edited by mikeleeshields; 06-22-2014 at 11:12 PM. |
06-22-2014, 11:08 PM | #455 |
Sorry on the iPad so I have to load single pics.
06-22-2014, 11:11 PM | #456 |
The front and rear lower floor frames.
I will try mounting them tomorrow Sorry for the crappy pics. My camera on my phone is all scratched.
06-23-2014, 08:01 AM | #457 |
Still Learning
Looking good Mike! I know exactly what you mean. I have had my truck painted for a couple months but it's still not together. Trying to get all the wiring and mechanical done take a super long time.....Keep up the good work.
06-23-2014, 09:20 AM | #458 |
Looks great Mike, you definitely got a lot more done then I did this weekend I like the frame you made for your bed, I might have to steal the idea if I ever get back to my bed. Have to finish the bodywork and paint on the front clip and cab while I have warm weather to paint.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
06-23-2014, 11:45 AM | #459 | ||
06-23-2014, 09:51 PM | #460 | |
I'm still trying to make the same decision about my bed floor that you are. Check out screamingchevypickups Lucy build thread. I'm thinking about doing a the same to my bed. Basically raise the floor up to the bottom of the wheel tubs so that I don't have to modify the tubs any and build a hinged notch cover.
06-25-2014, 06:53 AM | #461 |
I have some more progress to post. I actually feel like I am doing something, haha. I formed up a new radiator mount the other day and it fits pretty good. I spent a freakin long time making a battery mount to hang off the side of the frame, (took way longer than anticipated). Once it is cleaned up with some bracing I think it will turn out pretty good. I also laid the bedfloor frame down so you can get an idea of what I am working with so far. I tried laying out the air stuff to decide how I am going to do that and I am still up in the air. I do think I am going to mount it in the front of the bed and raise the bed floor up about 8" to cover it all with some hinged covers. I will still have to build a small notch cover more than likely but not too bad. I want to show off all the frame work in the end it is just too pretty and expensive to hide, lol. I also mounted the headlights to the core support.
06-25-2014, 06:53 AM | #462 |
Here are the headlights.
06-25-2014, 06:02 PM | #463 |
Looking good
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 |
06-25-2014, 10:09 PM | #464 |
I really like the frame you built for the Bed, looks good
06-25-2014, 11:49 PM | #465 |
Still Learning
Nice work on the battery box and bed floor. I bet you did rack up some time on those puppys.
06-26-2014, 05:55 AM | #466 |
06-26-2014, 06:49 AM | #467 | |
Thanks. I just looked at yours and you have made some progress too. Looks good.
That is the start. Now where to go from there is the question. Unfortunately I have to tear the bed back apart to put cab corners on soon. Quote:
Thanks. Are you driving your daily yet?
06-26-2014, 06:53 AM | #468 | |
06-26-2014, 12:24 PM | #469 |
Sounds great. Im gonna have a hard time putting real paint or anything on it. I don't want to have a nice paint job hinder me from driving it every day. We will see as time passes. There are so many other things I have in store for the truck. Yours looks good.
06-26-2014, 10:40 PM | #470 |
Got some new parts from one of my favorites, summit racing.
I can hook up my new tranny now. I am waiting on a gear shifter from southern classic so i can actually put this thing in gear. The column I had didn't have a shifter. Oh and a gallon of rust remover for all the bolts that are piled up on my benches.
07-02-2014, 02:33 PM | #471 |
I have gotten a few more things complete.
- The transmission linkage is now hooked up. - The transmission coolant lines are plumbed. - I have the driver's cab corner welded on. - I gave the majority of my bolts a rust bath and fresh coat of paint. - I fully secured the carrier bearing. - Headlights are wired and ready to go.
07-03-2014, 08:42 AM | #472 |
I got the passenger side rocker on last night. I almost have a complete hole free cab again, yippeee
07-03-2014, 09:52 AM | #473 |
Your cab corners look real good. You probably mentioned it but where did you get your cab corners from?
You've made some sweet progress. |
07-03-2014, 10:50 AM | #474 |
Thank you. I get all my sheetmetal from a local place here in Ohio called Restoration World. They are about 40 min from me and have just about everything for older Chevy's.
07-07-2014, 07:01 AM | #475 |
I got the first layer of filler on the cab corners and fixed some windshield rust.
I realized I am not going to be able to get this thing done in time for Goodguys in Columbus this weekend which is a big bummer. Too many things to get done in 4 days. Is anyone going to Gooodguys this weekend?
