07-13-2015, 10:44 PM | #451 | |
Re: '57 Ford Custom 300 Tudor Sedan
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
07-14-2015, 02:47 PM | #452 |
Nice touch with the dimple dies and the mesh. I like the outcome.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
07-14-2015, 11:14 PM | #453 |
Yea, i like the dimple dies as well!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
07-16-2015, 01:43 PM | #454 |
Very nice! I like the mesh. Enjoyed seeing you and Kathy this weekend, a photog got a couple good shots here:
http://mingle.kansascity.com/photos/...ike-show-2015/ Enjoy!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
07-25-2015, 06:00 PM | #455 |
We trekked over to Bonner Springs this morning for the 42nd Annual Show and Shine at the Ag Hall of Fame. I think they said they had 107 cars there in addition to the Genuine Chevy GMC Club members. They did a top 60, a top 10 and a Best of Show. We were pleased and honored to take home the BoS trophy. Ryan and Rachel (our twins from Houston) were very excited! As usual, we had a great time catching up with a lot of the truck guys we know from the Midwest Truck Nats and the forum. Summer has definitely arrived however, and we wuz sweatin' it out this afternoon when the heat index got above 110 degrees.
On the way home, Ryan and I turned up the AC to cool off. Engine temps did real good, but the alternator isn't keeping up. I guess with the dual radiator fans, the trans cooler fan, the AC fan, the blue Holley electric fuel pump and the miscellaneous amp draws, the little 10SI is struggling to put out enough juice. The voltage gauge showed around 11VDC with the AC on high. Temp gauge was hovering around 190 which is fine. But I guess I need to do some digging into the electrical system. The transmission shift points have steadily improved since I put the other vacuum modulator in and machined a new connector rod. I started out with the preload on the spring set to 11.5# like the factory spec. Since then I've turned the adjustment screw in two turns at a time for a total of 8 turns currently. I can now feel the trans shift out of low around 10 mph and out of second around 35 mph. Much better, but the shifts still feel a little soft. I may still need to look into a shift kit. But at least it's getting better.
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
07-25-2015, 06:40 PM | #456 |
Congratulations on the best of show win Vic!
07-25-2015, 06:53 PM | #457 |
That is a well deserved trophy...
07-25-2015, 08:45 PM | #458 |
Very nice work Vic. Congratulations on the Best of Show award.
Scott |
07-26-2015, 12:59 AM | #459 |
Awesome!
07-26-2015, 08:42 AM | #460 |
Congrats on the hardware ,more to come Im sure and well deserved.
07-26-2015, 11:53 AM | #461 |
Congratulations Vic and Kathy!!! A well deserved award.
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
07-26-2015, 05:20 PM | #462 |
Thanks for all the nice words, everyone. Several folks at the show commented that you sure don't see many of these (57 Fords) around. Maybe the element of surprise worked in our favor.
This morning, I grabbed a shop towel to wipe up the usual motor oil leaks off the floor. Seems like they're getting worse after every long trip. All along, the leaks have appeared to come from two places: the rear main seal and around the oil filter. The rear main seal will have to wait until winter as the engine will have to come out for it to be replaced. The oil filter is another matter. I've been running a Fram HP-1 filter meant for racing engines, mainly because of the higher oil pressure output (75 psi) from the Melling pump. I've noticed a drip off the bottom edge of the filter and oil has been pooling in the area circled in the photo below. Tightening the filter an extra 1/4 turn had no effect. After cleaning around the area good, I removed the Fram filter, inspected the sealing surface, installed a new Motorcraft filter in it's place and tightened it the recommended 3/4 turn. Fired the engine, brought it up to operating temperature and ran it up to 3000 rpm for a minute or two to simulate 65 mph out on the highway. After shutting it down, the oil had once again pooled on top of the corner of the block, but the groove around the filter was dry as a bone. So whatever is leaking must be from something else and not the filter gasket. The pan gasket is a Milodon one piece unit installed without any RTV or other sealant. It has crush proof washers embedded into the rubber gasket material so you can't really over torque the pan bolts. However the gasket looks wet with oil all along the pan rail on the driver side. I'm running a windage tray, but the area where the leak seems the worst is right where the oil pump sits. It's possible the windage tray is shearing off the oil and flooding the gasket along the driver side rail. However, it's notched for the oil pump and doesn't extend that far forward. It's not a huge leak, but it's aggravating. If it's the pan gasket (which is my current theory) it will also have to wait until winter as there's no way to get the pan off with the engine in the bay.
07-27-2015, 11:10 AM | #463 |
Just a guess, but have you looked at the fuel pump block off plate? Maybe stick a mirror in there and look underneath to see if you find your leak. I'm not certain, but it looks like a possibility based on the location of it and the circled area in your first pic. It might be that simple.
Congrats on the Best of Show! Well deserved.
07-27-2015, 12:15 PM | #464 | |
You can't see it very well in the photo, but there's also a 3/8 pipe plug in that same area that I'm pretty sure goes into the oil passage. I took it out this morning, cleaned the threads good, wrapped it with teflon tape and reinstalled it snugly. We'll see if any (or all) of these fixes make a difference. Since the oil is pooling on top of that corner, I'm less inclined to think the pan gasket has anything to do with it. But there's a lot of turbulence in the area and after a long trip, there will be tiny droplets of oil along the side of the pan clear back to the rack. The next day, the floor has several small spots of oil where it has collected above and formed drips. Man, do I ever hate leaks! I try to achieve a balance between the need to seal up an engine and the possibility I may have to tear it down again in the future. I'm already thinking hydraulic roller cam this winter when I yank it to fix the rear main seal and swap in a lower psi oil pump. Kill all the birds with one stone.
07-27-2015, 11:11 PM | #465 | |
The car looks great. I'm sure you'll get the leak fixed... one way or the other.
07-28-2015, 12:58 PM | #466 |
Wow, congrats!
07-29-2015, 12:42 AM | #467 | |
07-31-2015, 10:48 PM | #468 | |
As you can see from the photos, I have some other issues to deal with at the moment. Front end has been making some odd noises so I took the car to NKC Brake yesterday morning to have the front end realigned (which I hadn't done since replacing the rack and pinion.) They were unable to turn the wheels by hand on the turntable to do a caster sweep, so they sent me home to fix whatever was binding in the steering. Turns out both upper ball joints had rusted from sitting so long without grease. The lowers were in much better shape and a few pumps of green grease freed them up like new. The uppers, however, couldn't be saved. I ordered two new ones along with a set of upper control arm bushings. They, like the ball joints, were new many years ago, but have deteriorated while in storage. You can see how they have cracked and extruded around the sleeves. With everything apart, I'm greasing all the places I can think of that might be squeaking. Maybe it will help for at least a little while. We went to one last cruise in last night before the big teardown. On the way, the voltmeter read around 11VDC while idling at the stoplights. The other day, I tightened the V-belt a little bit even though there was no sign it was slipping. Didn't help a bit. So this afternoon, I ordered a new alternator from Quality Power. They have one that puts out 120 amps at idle and 150 at cruise rpm. Should be more than enough for my needs. It looks sorta like a Japanese unit stuffed into a custom billet housing with the same mounting dimensions as a 10si. Hopefully it will put an end to my low voltage blues.
08-01-2015, 04:20 AM | #469 |
As usual Vic you have everything under control.
#Winning! |
08-01-2015, 11:25 PM | #470 |
Glad at least one leak was a simple fix. Like Brian said, looks like you've got it all under control.
08-20-2015, 05:11 PM | #471 |
Hey Vic it's been almost 3 weeks since your last update, I'm curious how the improvements are progressing.
08-20-2015, 10:40 PM | #472 | |
The brake booster arrived from Hydratech and I had to send it back also. The pushrod that fits in the m/c piston cavity was .050" too long, so it preloaded the m/c when you bolted it up. The connecting rod that links the brake pedal to the rear of the booster was 1" too long. And the bolt pattern for the adapter plate that bolts the unit to the firewall was too wide by about .075". I could have fixed it in the mill, however it was held on by a special fastener shaped like a four leaf clover. After discussing it with them, I boxed it up and returned it, including pictures marked with the dimensions I needed. No telling when I'll get it back. It was over four weeks to get it in the first place, so it may take that long again for the repairs. Meanwhile, I reconfigured the p/s pump can for two -6AN return fittings and capped off the original return tube. I'm also refinishing the valve covers. The stainless trim pieces kept moving around when the engine got hot, so I procured some tiny eyeglass screws to stop all that. Also, I wanted to switch sides to shorten up the PCV valve tubing which meant the designs/lettering were all backwards... resulting in a repaint. Last but not least, here's a shot of the newest addition to the family. Hemi Challenger with the R/T Shaker package. Getting it has helped take my mind off all the Ford screw ups.
08-20-2015, 10:42 PM | #473 |
Wow! That is a nice car Vic!
Scott |
08-20-2015, 10:57 PM | #474 |
Thx, Scott. If you ever doubted I was a car 'ho", this is proof positive. We are officially decked out with GM, FoMoCo, and Mopar hardware.
08-20-2015, 11:02 PM | #475 |
Lol.
Scott |
