Old 10-01-2016, 01:26 PM   #4726
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by Wide Open View Post
Yeah I saw those and wondered if you were going to use them or those never have to retorque ones.
"or those never have to retorque ones" I think you mean Remflex ones. funny thing you ask because the Remflex guy recommended the metal / aluminum squash kind for my headers when I showed him my pictures on this forum, yeah I showed off this thread to the Remflex guy, ha ha
Gregski is offline   Reply With Quote
Old 10-01-2016, 01:39 PM   #4727
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so the Mr. Gasket 7402G rode home shot gun with me, no seriously in the front seat
$38 bucks, pretty pricey, hewk at this rate I'm building a million dollar exhaust
Old 10-01-2016, 01:41 PM   #4728
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so lets take a closer gander at this be all end all gasket cause it sure wasn't what I expected, it comes off as a nice 1/8th of an inch gasket, or at least that's how it looks like in the box, well until you open it and flip it over
what's up with these ridges?
hey man, I'm just sayin' and I'm just sharin', cause sharin' is carin'
Old 10-01-2016, 01:45 PM   #4729
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
well lets try these on for size
first in non of the 17 languages on the box does Mr. Casket tell us which way is front and which way is back, in other words which side goes to the cylinder head and which one to the header
I guess the ridges are supposed to wrap around some header, but good luck finding a header that matches the gasket exactly precisely
Old 10-01-2016, 01:48 PM   #4730
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
two more pics of the ends
Wonder if I should flatten out that ridge around the border on the gasket or leave it be so the gasket lays flat on the header?
Old 10-01-2016, 01:54 PM   #4731
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
well dingle dangle, Miss Easy On The Eyes shows us how to install these types of exhaust gaskets in this here YouTube video
How To install Mr. Gasket Aluminum Layered Exhaust Gaskets
Old 10-01-2016, 04:23 PM   #4732
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the carbon buildup is starting up again on the brand new #5 spark plug, no bueno!
and I refuse to Dyno Test a bad build
Old 10-01-2016, 04:27 PM   #4733
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
clearing the runway...
Old 10-01-2016, 04:29 PM   #4734
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
~ commencing the teardown ~
Old 10-01-2016, 04:31 PM   #4735
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
what in the world is that? would that explain my coolant always being low?
ah the life of a Hot Rodder, one step forward, two steps back
Old 10-01-2016, 07:18 PM   #4736
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
my push rod numbering system
left to right
1 medium zip tie
2 medium zip ties
3 medium zip ties
0 medium zip ties
4 small zip ties (ah snap I forgot the zip ties on this little rascal)
3 small zip ties
2 small zip ties
1 small zip tie
Old 10-01-2016, 07:21 PM   #4737
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Off with Rusty's head!
something is definately up with the two middle cylinders (for sure #5 ie second from the right with all that build up)
Old 10-01-2016, 07:26 PM   #4738
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the jugs look fine ie cylinders and piston tops at least from what we can see here
Old 10-02-2016, 02:32 AM   #4739
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
looks like the head gasket held just fine (here we check out both sides of the same gasket)
Old 10-02-2016, 02:35 AM   #4740
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
here I show you my one man piston catching aparatus, don't worry it never came to that, the towel was there just in case, I tapped them out gently to where only the rings were crowning out
Old 10-02-2016, 02:38 AM   #4741
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the first piston to come out was #5 and right away I noticed a problem, the oil rings were frozen / stuck, they would not spin nor wiggle
I marked this guy with a zip tie because I did not a have a number punch yet
Old 10-02-2016, 02:45 AM   #4742
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so I decided to compare it to the number 1 piston
I lined up the ring slots on purpose for the pic so you can see the spacing, they were properly offset in the engine
notice how further apart the oil rings are on the #1 piston than the #5 (last pic) which are jammed closer together squeezing the piston to the point where they can't move
Old 10-02-2016, 02:49 AM   #4743
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
decided to hit Harbor Freight for a stamping set before pulling any more pistons, didn't want to mix them up, as they were not numbered/labeled already
Old 10-02-2016, 02:51 AM   #4744
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so I pulled all four pistons from the driver side and stamped there with their numbers
Old 10-02-2016, 02:54 AM   #4745
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I also picked up what I thought was a bore gauge set from Harbor Freight, and folks don't waste your money this is total junk, I was unable to find the center ie the widest point of the cylinder this thing wobbles all over and by the time to lock it down you are in a different spot
Old 10-02-2016, 02:56 AM   #4746
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
cleaned my second work bench, this one is on the passenger side, i really like these benches, come in so handy, and a clean workbench keeps me sane
so the driver side head etc. went on the drive side workbench, and the passenger side components will go on this side
Old 10-02-2016, 02:58 AM   #4747
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
this is what happens when you don't label your push rods, ha ha
at this point I didn't care
Old 10-02-2016, 03:00 AM   #4748
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
pulled the passenger side cylinder head
no surprises here - things looked normal
Old 10-02-2016, 03:01 AM   #4749
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
passenger head looked better
Old 10-02-2016, 03:05 AM   #4750
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
passenger head gasket was in good order, front and back shown here
