#26 |
Re: Welding a patch panel
Wow. These things are less than $20 on Ebay! To weld 20 gauge sheet metal, is it like 15 seconds for a single 1/8" stitch weld, or longer? Could you do a whole quarter panel with this thing?
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
#27 | |
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#28 | |
#29 |
Post Whore
![]() ![]() Join Date: May 2015
Robert of MP&C shows welding with this meco in his thread.....I bet it cost more than $20.....http://67-72chevytrucks.com/vboard/s...53#post8414753
#30 | |
The MIG still has it's place and I use it regularly on the truck. But those welds out on the large panels, the jewelers torch is my go to. I use a short piece of 1/8" tubing in the vice and a drill to spin the .023 MIG wire to make it straight and use it as welding rod with the torch. Brian
#31 |
I've welded a lot of sheet metal with a Smith's aircraft torch and a small tip. Like the jewelers torch above, the gas valves are at the top of the torch handle for easy gas adjustment.
Getting the heat just right for gas welding sheet metal can be tricky. I find that I can get a little bit more 'granularity' in the acetylene by adjusting the regulator on the tank rather than the knob on the torch handle. Some of you will think I'm nuts but I've often used bailing wire as a filler when welding sheet metal. It is cold drawn and very low in carbon. After welding it remains very ductile (the HAZ has less carbon in it from the filler and presumably less martinsites) and it is easy to planish the weld. I certainly wouldn't do anything structural with this wire for filler, though. I think that gas welding is a lot quicker than MIG welding too - you can weld it all in one go instead of stringing all those dots together and waiting for the panel to cool in-between. Once you're done the weld is easier to grind and planish. Just my 2 cents |
#32 | |
I have to tell you, I went back to the torch when a guy at work (an estimator in the office, YES they know something) walked me through using the jewelers torch and MIG wire for rod. Or of course using nothing at all and "fusion weld" it plannishing the gap to perfect before welding. I am BLOWN OUT OF MY MIND how much you can close up a gap! But the most important thing is making that gap perfect then welding without stopping, go the whole length in one shot. The HAZ stays so much smaller and most of all it's consistent. When you weld and stop and weld and stop the HAZ looks like a row of flowers. Well each of those welds is going to shrink different than the metal where the welds meet. If you don't stop and make that one weld the HAZ is just a straight line, you are in WAY MORE control that way. Brian
#33 |
![]() Join Date: Sep 2017
Martinsr, I have the purple 3M rolock discs and they worked great removing the proud part of the weld and smoothing the metal. I went with a fairly tight fit and the Easy Grind .023 wire. Welded to keep it cool, I could touch it barehanded - NOT WITH MY TONGUE, before I put down another bead.
![]() This is what the door looked like after I converted it to a push button, and here it is with the handle. ![]() Thank you all for the help. I think I can do this now.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#34 | |
Brian ![]()
#35 | |
https://www.riogrande.com/product/ME...MaAvSLEALw_wcB
#36 |
A quick funny. Probably 50 years ago when I was a teenager, I was out in the garage helping my dad weld on a boat trailer. He would never let me weld, just be his helper. Anyway, I had on tennis shoes and he made me go back in the house and put on some work boots. He said the welding "bb's" would ruin my shoes.
Well, yesterday I took the wife to lunch and when we got back I was in a rush to get to the shop and work on the doors. I didn't change out of my tennis shoes. I was welding along when that BB went through the shoe and the sock and lodged between my big toe and the next one. I cussed a bit, but kept welding. So not only did I remember my dad's message, I now know why! Oh, the shoe is fine, you can't even see where it went through the nylon mexh, but that burn on my foot will take a while to heal.
#37 | |
The best one in the recent years was welding at home and having my wedding ring on. DO NOT DO THAT! ![]() ![]() ![]() ![]() I had a tiny "bb" fly over and stick to the ring. We are talking a tiny little bb like a 32nd inch kinda thing. It heated up that ring BURNING ME REAL BAD! I have never gotten a burn like that, it was about a quarter inch of COOKED flesh! HOLY CRAP that hurt for days! This photo is the second it happened, a day later it was a lot bigger with a HUGE blister, oh yeah, that was fun. Yeah, I could go on and on like when I was welding a bed side on a late model truck and someone walking by starts yelling and kicking me because my shirt was on fire! ![]() Brian
#38 |
I grew up welding with OA and a coat hanger. I like TIG on sheet metal. Much softer and more forgiving. I love my smith mini torch and with some shopping they are quite reasonable. There is nothing better for small work.
