#26 | |
Re: *Turn Signal Not working*
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck |
#27 |
Here's a test you might try.. Buy a new dual contact bulb socket for an 1157 bulb, along with an alligator clip large enough to grip around the socket.. Attach a wire to the alligator clip and wire up the socket to the harness using jumper wires.. Attach a wire to the big alligator clip and use it to ground the socket. Be sure the socket is well grounded and run the turn signals through their paces.. If the bulb in the test socket blinks as it should, you'll know for sure the socket on the truck is bad..
#28 |
Old member
Yes a test light should make it flash. I've never had one that didn't. But you are correct that the flasher should be good. I would check the tit's inside the connection and see if they have connection. If the truck lights are on then one of them should be hot the whole time, if the turn signal is on then one should flash also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#29 |
Did some more testing this morning. I have green and black wires going to both turn signal buckets. All test were done with the passengers side turn signal bucket and socket removed. Just the back and green wires hanging down. On the passengers side I tried to straighten the green wire contact inside the socket and it broke off. Need to get a new one now.
1) I probed the wires on the plug on the steering column side that I thought were for the turn signals. Only one would flash which was the drivers side. I thinking the dark blue is for the passengers side but it would not flash. 2) With the ignition on and no lights or turn signals on there is no power to any wires at both turn signals. 3) With the ignition on and the parking lights on there is power to the green wire on the drivers side and power to the black wire on the passengers side. 4) With the ignition on and using the turn signal on the drivers side the black wire flashes. No flashing from either wire on the passengers side. Update, I probed all the wires on the plug coming from the column. On the engine side of the firewall I find no wire that will flash for the passengers side, only the drivers side. Could I splice into the wires on the column plug and run a new wire to the passengers side turn signal? If so. Which one since two wire flash?
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 04-05-2020 at 03:15 PM. |
#30 |
![]() Join Date: Apr 2016
I recommend do not worry about flashing or not flashing until you actually get a bulb on it and glowing. (other than the bulb that is in the tester. The amount of current drawn by a regular bulb is critical to most flasher modules. Does the back right turn signal light flash?
#31 | |
#32 | |
#33 |
Edit: my other comments deleted, I think RustyPile is providing you better answers...
#34 | |
With all due respect Zippi, your biggest problem is you don't understand how the electrical system works.. You have my phone number.. Call me and I'll explain how all that works.. |
#35 | |
#36 | |
Tomorrow is not a good day for me.. I'm retired but I have some things planned that will take most of the day.. Today is really best for me.. |
#37 |
Just PMed you.
#38 |
RustPile,
It was nice talking with you and I will post the results of my findings whenever I can get the parts and get it swapped out. Here are a couple pics of my 49 pickup. Thanks for the help.
#39 |
Nice looking truck.. Be sure to use fender covers when working on it...
#40 |
Ok....Got my lock plate compressor this morning and got the plate removed. I can not get the plug at the bottom of the steering column to come up through the column. I'm thinking the other plug which is not being used it causing the turn signal plug to get wedged in the column. Can it be cut off so I can pull it out of the column to give more room for the turn signal plug to come through the column? Just not sure if there are other wires on the other side of the turn signal lever going back down the column.
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 04-06-2020 at 10:28 AM. |
#41 |
Sorry for the delay in responding.. I've been busy..
Since I'm not there to look at the way the column is wired, what wires are used and which ones aren't used, my advice is don't cut any wires,, Trust me, the turn signal harness will fit through the space.. How do you think all those wires got there in the beginning?? Tuck the plug up tight along the ribbon. help it get started, pushing on the plug and lightly tugging on the switch.. It will fit... |
#42 |
Ok, project is complete with all turn signals working and I got the emergency flasher working as well. RustyPile you are correct both ribbons had to go down the column but......there is a plastic shield that was preventing the plugs from going up the column. I had to unbolt the column from the underside of the dash and loosen the 4 bolts that were fastened to column on the sides and then with a pair of pliers I was able to pull the plastic shield out. Once that was done it was like dropping a bucket down a well. The extra plug was not connected to anything so I cut all the wires inside the column under the turn signal switch. My old 49 does not use cruise control or the wipers from the lever. I just like a cleaner install. I purchased 2 new light sockets from Tuckersparts.com and they were shipped today. I used my test light on the wires on the passengers side turn signal and it now flashes. Never had that recently. I appreciate everyone's help that participated in my issue with the turn signal.
#43 |
Just a quick update. My new Light socket came in today. Got it wired up and the passenger side front turn signal works as it should as I fugured it would. A special thanks to RustyPile who is a man of great knowledge on the electrical workings of the vehicles we love to drive.
