#26 |
![]() Join Date: Dec 2001
Re: which carburetor is best????
I got rid of the Edelbrock 1406 and replaced with the Holley 4150 double pumper. The Edelbrock didn't have great performance, and I could never get the electric choke to work right. Once I tuned the Holley, the performance was significantly better.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
#27 |
Best carb I ever ran on a stock 350 was a 500 Edelbrock with a manual choke. Throttle response was awesome, so was gas mileage. With a TH350 and 3.73's, I got between 18 and 20 mpg.
If tuned right, I can get 16 mpg out of my 68 with a GMGoodwrench 350(260 hp) with a 570 Street Avenger. If you're gonna buy a Demon, buy the expesive ones, don't waste your money on the Road Demon line.
#28 |
If the thread starters truck were mine Id stay q-jet personally. fix or have someone fix your q-jet. a properly working q-jet will get just as much performance & MPG as the aftermarket.
that being said, if you are going aftermarket. its personal opinion. I personally dont have much use for Edelbrocks Carbs, although I love most of there other products. Ive heard so many people complain about Holleys . Ive had the 770 Holley on my 454 for 4 years, never..ever a problem with it. John
75 GMC C-15 short/step factory 454, lowered |
#29 |
FWIW, I vote to keep the Q-jet. When it comes to rebuilding, if I can do it, anyone can.
This book helped. http://www.hrpworld.com/index.cfm?fo...action=product
George Morgan Hernando, MS '69 C-10 swb fleetside '72 GMC swb Stepside |
#30 | |
#31 | |
http://www.amazon.com/gp/product/089...Fencoding=UTF8
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes. My lame K20 page My lame Eaton disc brake page ![]() |
#32 |
![]() Join Date: Oct 2005
Thanks for all the input. I do have two quads so I think I will try rebuilding one of them. Thanks for the link Gman69 and rainfade.
I had thought about the edelbrock but my first truck (a 70 chevy) backfired through the carb and it was an edelbrock and the truck went up in flames ![]() ![]()
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. ![]() |
#33 | |
Old Skool Club
![]() Join Date: Jun 2001
Demon says the best thing to do is to contact the manufacturer to help you decide which of their carbs is best. For trucks that are hauling a load, smaller primaries will help with the low-end torque, per Demon. I replaced my 1405 (manual choke, performance jetting) with a 1901 (Q-Jet with divorced choke). I have been completely satisfied. I bolted it on and fired it up. Haven't touched it in 4 years. The 1405 ran rich, even though it is only a 600CFM, compared to the 750CFM rating of the 1901. The 1405, and a new Edelbrock overhaul kit, are still in my garage, in the box that the 1901 came in. I haven't made up my mind as to what to do with it, but I like the AFB's when I had them on my '64 Bonneville and my '67 Skylark. They're good carbs, but for street use, the jetting needs to be re-done. The Q-Jet is easier to rebuild (my opinion) than the AFB. Don't even talk to me about ThermoQuads. Holley and Ford(Autolite) carbs are also easy. As for the old 94 shown near the top of the post, the 97's have more history, but the 94's (Ford and Chandler-Grove) are both good old carbs, on the right engines.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#34 |
A.K.A- Crummy
The Holley Avenger or the Demon. Quadrajet is fine if you find a late model fairly low mileage one(late 70's) and someone with some old school know how. Problem with the older quads is age and wear.
2003 Silverado Z71 Are fishermen all liars? |
#35 |
Gone Fishing
My personal preference is the Edelbrock performer series carbs. I have had great luck with them. Holley's are just a pain every time the weather changes had to readjust them.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
#36 |
I have an Edelbrock 1406 on my 350 and I just got a Road Demon. As soon as I get the new 700r4 linkage plate from Bowtie overdrives I will put the Demon on and get rid of that Edelbrock carb. I've changed everything on that 1406 and it still doesn't run right. Even the Edelbrock techs can't figure it out. Maybe I just got a bad one. I'm not giving them a second chance.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
#37 |
67-72 Addict!
Ken, you will love the Demon once it's dialed in!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#38 |
Active Member
The carter AVS and the thermoquad are not the same carb. The AVS (adjustable valve secondary) has an all metal body like the AFB and is a square bore with the primaries being slightly smaller than the secondaries. The thermoquad was a true spreadbore like the Q-jet and had a metal base and top but the center section was plastic(gas bowl area to keep it cool). The thermoquad wasnt made very long and has never been reproduced since and the old ones are hard to run because of no parts. Had a 73 340 Duster that came with a thermoquad stock and at the time was an OK carb.:::::::::CB
#39 |
Active Member
![]() Join Date: Dec 2002
Location: West TN (Memphis area) now. East TN (my favorite place to live).
Here is a pic of my new carb.
BigFredTN 70 chevy stepside 350 with some goodies inside, turbo 400. 69 Chevy long wheel base. Dad bought new in 1970 62 Chevy Impala 98 GMC Yukon 1970 Ford Mustang Fastback I know its a Ford. |
#40 |
Here is my 2 cents. Anyone got change
![]() When I first got my 68 and the stock rebuild 350 I have a holley 650. Found myself tuning it every 5-6 days. When I got the qjet rebuilt I installed it, adjusted it and have not had to touch it. Also noticed about a 2 mpg increase.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
#41 |
Like I said before. The Holley on my 454 hasent seen a screwdriver in3 years. Oh wait, I put a bigger squirter in it a couple years back after switching intakes.
That being said...I think a properly tuned Q-jet is hard to beat. John
#42 | ||
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 03-25-2006 at 01:40 PM. |
#43 |
My edlebrock 1406 took quite a bit of tuning before it was right. After that I never had to touch it again. The stock Qjet performed similarly to the 1406 but got 2mpg better mileage. Right now i've got a rebuilt 600 holley vacuum secondary, converted to metering blocks on both ends and center hung bowls. This has the best performance/throttle response of the 3, but the worst mileage. About 1mpg less then the edlbrock and 3 less then the quad. I have replaced the powervalve once allready and its due for another now. Been about 2 years i think. This carb has powervalve protection too but still having problems. All of these were on the same truck/motor. Only reason I changed out the Qjet was because of the divorced choke.
On my other car I put an Edlbrock Qjet on. No adjustments were necessary. Great performance and has been very dependable. I think they quit making them though, so may be hard to come by.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop 70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress |
#44 |
Well, one thing is for sure.I will save money by rebuilding the quad. then I can spend it somewhere else HEHEHE.
#45 |
GM ONLY BABY!!!
If you want more power and performance then get a BG Demon. They are proven to outperform a Holley and Edelbrock. Plus they use many of the same parts as a Holley, like gaskets, jets, diaphrams, floats and so on.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
