07-11-2004, 09:07 AM | #26 |
PROJECT 7DEUCE
The swap look's good glad to see you got in there ... Can't wait to see the smokey tire pic's..
07-11-2004, 12:45 PM | #27 |
OOps, didnt read the sig on the bottom. My fault. The SRT only get 13.9's? Figured theyd get a lot better than that, must not have good traction. The lightnings get into the 11's fairly easily with not much money spent.
72 Chevy C20, SOLD (Dang it.) 09 Challanger RT six speed in all black. 74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power. 73 C10 long bed, 350/350 combo, nice shape. |
07-12-2004, 02:01 AM | #28 |
Just Don't Stop!
no prob. actually alot of it has to do with the huge wheels the SRT 10 runs which makes its rear gear too high. That and the thing weighs a bunch! Honestly, none of the trucks perform well for the money IMO.
1968 C10 build in process TT LSA/6L90e/9" |
07-12-2004, 11:42 PM | #29 | |
Just Don't Stop!
Right under the front edge of my 2001 chevy 60/40 using this PRO 5.0 shifter. Just gonna make a custom shifter arm and be set...
07-13-2004, 08:06 AM | #30 |
Insert funny comment.
You have a gas tank/fuel pump setup yet?
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
07-13-2004, 12:25 PM | #31 |
Just Don't Stop!
summit 16 gal fuel cell foam filled and modified for an in tank walbro 255 fuel pump with 1/2 line to the motor and 3/8 return line.
07-13-2004, 09:47 PM | #32 | |
Thanks!
07-13-2004, 10:56 PM | #33 |
Just Don't Stop!
underneath the bed. you can buy them with or without foam. I just changed the fittings and made a pickup for the pump. goodluck.
07-13-2004, 11:35 PM | #34 |
Back in the sticks
Wow!! Can't wait to see what it looks like when you get it all in there. It will be sweet. Are those power steering lines tied up in front, or fuel? Keep us posted! Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
07-14-2004, 02:27 AM | #35 |
Just Don't Stop!
oil cooler and power steering lines are tied up in the previous pics
07-14-2004, 03:02 AM | #36 |
14.1 @ 96MPH
Definitely watching this thread. My 700R4 bit it today and with my new job I should be able to afford a LS1/T-56 to replace it.
How do you think that shifter position will work? Are you going to use A/C? And why did you scrap the modified stock tank like you had in your older thread?
Project1970 - LS1 Swap Complete! |
07-14-2004, 12:19 PM | #37 |
Just Don't Stop!
the shifter should work out fine. I'll post some pics of the custon shifter I come up with. The stock tank would have worked fine I just angled for the cell so I would have room for car audio behind the seats later on if I get the itch not too mention that I really wanted the extra weight over the rear wheels (also did batt relocater kit)
If anyone is interested in the tank local, $10 and come get, it's looks great!
07-27-2004, 11:56 AM | #38 |
Just Don't Stop!
the cell
07-27-2004, 11:58 AM | #39 |
Just Don't Stop!
custom driveshaft with spicer 1350 universals on both ends with new pinion yoke and custom crossmember:
07-28-2004, 08:13 PM | #40 |
Do you have any pictures of the modificaton of the fuel cell. I am about to tear out my 6cyl and put in my 5.3l SSR engine. I was also wondering if I could use a blazer tank and put in a fuel pump.
Are you the one from ls1tech that asked for 2000 silverado cluser pinouts? If so and you didn't get them I can send you them. Did the motor mount plate diagram work for you? Would like to know, before I do it myself. Will post pictures of my progress too. Jeremy
1972 Chevy C-10 Short Stepside 6Cyl, 3 spd, not opts (Current Project) Now a 2004 SSR 5.3L with 4L60E Now Ididit tilt- ps, pb 2002 Saturn L200 2006 Toyota Highlander HYBRID |
07-28-2004, 09:44 PM | #41 |
Just Don't Stop!
there is no modification that needs to be done to the cell itself. Just the fittings. Actually, I ended up pulling the intank pump and using it on my camaro because I got a killer deal on a Aeromotive inline A1000.
Couldn't tell you about the blazer tank but on the cell you will just need to get the cell and the pump and have a line and or fittings setup from a decent truck shop. Good luck on the SSR swap. The motor mount plates worked alright I just had to fabricate custom perches to make everything fit with the right drivetrain pitch, or at least the way I wanted it. Yeah, I asked for the pin outs but I don't need them anymore. I ended up using a F-body PCM anyway with Autometer guages. The motor ended up being a 2003 6.0l not a 2000 5.3 like the seller thought also LOL. -Taylor
1968 C10 build in process TT LSA/6L90e/9" Last edited by FirstGen; 07-28-2004 at 09:46 PM. |
07-28-2004, 09:54 PM | #42 |
i`m planning to do the same swap but with either the 5.3 or 6.0 w/ automatic. the 6spd would be fun but my knees are bad and too much shifting makes it no fun anymore.
Anthony |
07-29-2004, 01:09 AM | #43 |
Young Gun wth Fast Inline
So you got the 6.0 liter for the 53 money.... awesome deal
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
07-29-2004, 03:09 PM | #44 |
Just Don't Stop!
yup
08-05-2004, 01:26 AM | #45 |
Just Don't Stop!
more pics for everyone:
1968 C10 build in process TT LSA/6L90e/9" Last edited by FirstGen; 08-05-2004 at 01:32 AM. |
08-05-2004, 01:38 AM | #46 |
how much longer before it can burn the tires right off?
70 longbed 496/th400/Ford 9" |
08-05-2004, 01:49 AM | #47 |
Just Don't Stop!
done...
will post pics after the dyno tune next week.
08-05-2004, 07:47 AM | #48 |
Where did you get your harness rewired... or did you do it yourself?
08-05-2004, 11:23 AM | #49 |
Just Don't Stop!
Jared @
www.currentperformance.com I some myself also but he built a completely new harness for this project since I went to a 6 speed.
08-05-2004, 05:40 PM | #50 |
Firstgen,
Do you have any idea how jealous I am?? Looks great! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
