Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 09-04-2004, 11:40 AM   #26
thisolechevy
wow!!! that is amazing that you lived through that, and thanks for sharing about why they are not safe.
Man I need another 67-72!!!
thisolechevy is offline
Old 09-04-2004, 09:55 PM   #27
corn
My 69 has a chrysler cordoba tank in it. I didnt install it,but I was told thats what it was...corn
corn is offline
Old 09-04-2004, 09:59 PM   #28
Joe67
67 is sold
Originally Posted by junkyardjohn
JOHN FABRIS-- IN 1977 I WAS HIT BROADSIDE AT AN INTERSECTION BY A DRUNK DRIVER (I WAS DOING 55 OR 60) CAUSING ME TO ROLL END OVER END IN MY 72 3/4 TON FORD. AFTER ROLLING ABOUT 80 YARDS, I STOPPED WITH THE TRUCK UPSIDE DOWN WITH MY HEAD PINNED TO THE GROUND. ...
Amazing story John!! Glad you survived that wreck.
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline
Old 09-04-2004, 11:36 PM   #29
big blue 72
Glad you made it JY.
big blue 72 is offline
Old 09-05-2004, 12:10 AM   #30
ed455
Captain Ed
here's what I did for a gas tank. One thing I alway noted about the old trucks was that the cabs always smell like gasoline.
ed455 is offline
Old 09-09-2004, 03:08 PM   #31
Joe67
67 is sold
MackL - any contact information for this Kenny's Truck place? Google comes up empty.
Dallas71 - Are you referring to www.thetruckshop.com? I sent them an email today I was just checking to see if it was the same place you were referring to.
Thanks.
Joe67 is offline
Old 09-09-2004, 08:08 PM   #32
jorgensensc
jorgensensc's Avatar
The Truck shop in Cali is where I got the tank and all for the writeup in the FAQ. They do not have the best customer service (I found out later) but they are cheap if that is what you are looking for. The setup for 166 was complete at the time, including sender, etc. If you want a really great setup, go with FCG, he makes a great product. If you want to do a blazer style tank you have a few options available to you. I always try and support local vendors, but am not a hater of the truck shop. I just know they have poor customer service, but I've never had a problem with their product quality (My oinion only though, others have). With a 6 inch drop I would probably lean towards FCG. I don't fel the blazer tank hangs to low, (about 3-4 inches lower than back bumper), but I wouldn't risk it on a 6 inch drop personally. Hope it helps a little.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline
Old 09-09-2004, 10:07 PM   #33
MACKL
Almost done!
MACKL's Avatar
Here is the info for Kenny's trucks. I found them at a swap meet and they had the best value. They also have great customer service. As good as Kenny's is, I would buy my next one from the fuel cell guy or weld a larger filler neck on the one from kenny's.
http://KENNYSTRUCKS.COM
918-827-2600
Good luck...Kelly
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline
Old 09-10-2004, 07:07 AM   #34
Joe67
67 is sold
Thanks guys, I'll check it out. I'm not necessarily looking for the cheapest, but the best value
Joe67 is offline
Old 09-10-2004, 12:00 PM   #35
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
What does one from FCG cost,(ballpark)?
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline
Old 09-10-2004, 12:52 PM   #36
Joe67
67 is sold
I think it runs about $375 + shipping with sending unit. Here is a thread
Joe67 is offline
Old 09-10-2004, 07:57 PM   #37
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
375 is what he estamated me too
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline
Old 09-11-2004, 07:06 AM   #38
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
We don't want the tank in the cab because they can make the cab smell like gasoline. That would be because the fuel lines are old, and/or the fuel fill hose is old/leaking. When the trucks were new, they didn't smell like gas.
As for relocating them to the rear of the chassis, it frees up space behind the seat, and/or allows for different seating.
Simply relocating the tank to the rear of the chassis doesn't negate the possibility of damaging the tank in a rear-end collision. Fuel Cells, as I understand them from a racing concept, are supposed to retain the fuel, even if damaged. A tank, if damaged, will leak. Whether it leaks, or not, will be determined by the construction of the tank, versus the force of the impact.
In my first vehicle, I carried a one-gallon gas can. It was placed in the back left corner of the trunk, directly beneath the tail light. I had a '54 Ford 2-dr. I got rear-ended by a then-new '65 Impala. Ford was nose-down, in braking to keep from hitting a car that had stopped just over the rise of a hill. When I hit my brakes, the Impala driver hit his. His front end was nose-down. When he got hit by a fourth vehicle, it drove the front of the Impala into the rear of my Ford, and knocked me into a '64 Chevelle. The rear of my Ford was crushed to conform to the front of the Impala.
That can of gas?? It, too, was crushed to conform to the damage in the trunk of the Ford. It didn't leak. I have never kept a can of gas in a vehicle, since then.
Having once owned a '71 Pinto, which Ford recalled to install a thick plastic shield between the rear axle and the gas tank, I have to consider the location of the gas tank as very important. I think I'm just gonna replace the rubber and leave my tank in the cab.
Member Nr. 2770
ChevLoRay is offline
Old 09-11-2004, 12:58 PM   #39
Russell
Professional Grade
Russell's Avatar
Personally I'd rather have an explosion at the back of my truck rather than underneith my butt...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline
Old 09-11-2004, 01:14 PM   #40
gregfull
gregfull's Avatar
I knew there was some reason I didn't like those DAMN Fords! But then again that Ford may have saved your life.
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline
Old 09-11-2004, 04:13 PM   #41
Joe67
67 is sold
GregFull - Your Suburban project looks bad as Hell
502 Ram Jet
Joe67 is offline
Old 09-11-2004, 05:24 PM   #42
guyryan100
guyryan100's Avatar
If you go with a blazer tank (I am but haven't put it in yet) I found the best price, with shipping, to be from American Classics. I checked all the board vendor's web sites and found this to be the cheapest. The Truck Shop wanted near $280 shipped for theirs (I had read that their kit was $166 but I talked to the guy on the phone and he informed me otherwise).
guyryan100 is offline
Old 09-11-2004, 07:48 PM   #43
junkyardjohn
junkyardjohn's Avatar
DO YOU HAVE AMERICAN CLASSICS PHO. # or web address?? JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline
Old 09-15-2004, 02:49 PM   #44
Joe67
67 is sold
http://www.americanclassic.com/
Joe67 is offline
Old 09-15-2004, 03:59 PM   #45
Chevyguy111786
whoever it was that said the smaller necks are a pain to fill up. My 78 has small necks...every time you try to fill up it just clicks off. i found out that if you put just the tip of the nozzle in...so that it's just inside the little flap/baffle deal...you can fill up without it clickin off...now sometimes, if the pumps goin fast enough, a little bit of gas will back flow out. but other than that, works much better than taking 30 min to fill up the tank. just a little trick i learned
Chevyguy111786 is offline
Old 09-15-2004, 08:36 PM   #46
MACKL
Almost done!
MACKL's Avatar
That would be me. I doesn't mater what you do, it pukes gas out. The only correction I have found is to locate the gas station with the slowest pumps and and lock the nozzle on the lowest notch. Then it only pukes a couple of times. I am worried it will ruin my new paint. Your '78 does not have a fill hole that is only 1 1/4" OD. That is about 1 1/16 ID. That is a little over an inch. Your 78 is closer to 2 inches. Big difference.
V8-350
Auto/PS/PDB
Blazer Fuel Tank
MACKL is offline
Old 09-15-2004, 09:01 PM   #47
Chevyguy111786
oh ok, didn't know, just knew it was small and clicked off on fast pumps. i misread your post about it puking, i thought you were talking about them clicking off all the time.
Old 09-16-2004, 12:03 PM   #48
Joe67
67 is sold
Thanks for all the input guys.
I just placed an order for a tank from Mark aka FuelCellGuy (Payment is on the way Mark)
Game on....
Joe67 is offline
Old 09-16-2004, 11:11 PM   #49
nate68
i dont hafta worry about that because i have no fill neck
68 short step, 406/700r4, 9" w/discs.
nate68 is offline
Old 09-17-2004, 03:43 AM   #50
Mudder
Mudder's Avatar
I havent read this whole thread but am wondering if you guys are venting the fill tubes. The air in the tank has to come out somewhere as the gas is replacing it.
Mudder is offline
