Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 06-26-2005, 12:19 PM   #26
jermasaurus
jermasaurus's Avatar
I'm going by what I was told and I have to stand behind my instructor on this one. He is the most reputable person I have ever known and has all the credibility anyone could ask for. He has been ASE master certified for Quite some time, Director of the automotive department at JJC, taught my Engine rebuilding class, electrical/electronic diagnosis, automotive fuel systems,automotive performance diagnosis, Automotive service 1,2,3,a and 4 and just retired last year.
If you don't think it will mess up the sensor, go try and coat the outside of the most expensive sensor you can find on any of your cars. Use a scope or graphing meter to check the voltage output, and tell me it hasn't changed.
-Jeremy
jermasaurus is offline   Reply With Quote
Old 06-26-2005, 12:38 PM   #27
jermasaurus
Straight out of the book..."When the thimble is filled with oxygen rich outside air and the outer surface of the thimble is exposed to oxygen-depleted exhaust gas, a chemical reaction in the sensor produces a voltage"
That is not the whole story of how an O2 sensor works, but just one of the things it needs to work properly. Now, if the oxygen rich outside air cannot be seen because the thimble is covered with armor all, clear coat, or anything like that how will the chemical reaction occur?
-Jeremy
From Automotive Electricity and Electronics 3rd edition by Barry Hollembeak
Old 07-12-2005, 11:52 PM   #28
pickemup
Talking
i have heard that a light coat of brake fluid works wonders on rubber stuff except tires. not a lot just a very light coat.
pickemup is offline   Reply With Quote
Old 07-15-2005, 11:07 AM   #29
shifty
Questionable
shifty's Avatar
I heard that peeing on your tires is a great way to give it a deep shine and luster.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 07-16-2005, 09:54 AM   #30
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Grab a case of BEER, pop the top and sit back and enjoy. By the end of the day you should have all four of your tires shining. If your lucky you might even get the spare.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 08-16-2005, 10:47 PM   #31
olblue81
olblue81's Avatar
I've used Armor All since the mid 80's on my 81. Like it says in my sig, my truck is the only one I've seen with the original dash uncracked. Not saying that other stuff is worse or better, but Armor All has worked for me. As far as having to do regular applications or it will accelerate damage- my truck sat inside the barn neglected from 1991 when I retired it from daily driver duty until 2002. I don't recall applying Armor All at all during that time. Just wish I would have done the door panels, they look like s**t.
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
Old 09-07-2005, 12:46 AM   #32
79Silv4x4
Workaholic
79Silv4x4's Avatar
used to do that. . .
79Silv4x4 is offline   Reply With Quote
Old 10-20-2005, 06:00 AM   #33
73737373
Re: Armor All in the engine bay?
I don't use Armor All. If I want a little shine to my vinyl interior surfaces, I'll spray a little Pledge on a rag and wipe them down. Leaves a nice not-so-glossy finish. Usually, though, I just wipe them off w/a damp towel...the one I've just used to dry the car off after washing it. NOTE: In my house, the car towels are nicer than the house towels....the fights my wife and I have over towels... YIKES!!!
1968 Custom SWB, 327/3 speed OTC
1969 CST LWB, 402/400
1970 CST LWB, 402/400
1970 Sierra Grande LWB, 350/350
1971 Cheyenne LWB, 350/350
1972 Cheyenne Super LWB, 402/400
1972 Sierra Grande LWB, 402/400
1979 Silverado LWB, 350/350
1984 Suburban
1990 454 SS
1991 Silverado, X-cab, 4.3/5 speed Getrag
2005 Silverado Crew Cab
Corvettes: 75, 77, 78, 93, 96
73737373 is offline   Reply With Quote
Old 12-28-2005, 02:00 AM   #34
wibilly
wibilly's Avatar
i agree with 73 pledge is the sh!t it contains lanolin a natural lubricant already found in vinal if you stop using or don't use all the time it won't dry out vinal as the silicone based products will and don't contaminate painted surfaces eather
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 01-10-2006, 04:05 PM   #35
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
I use goop hand cleaner instead of pledge. It is almost pure lanolin. Wipe it on, rub in with some effort, then wipe off with a damp cloth. Don't use the goop with abrasive though.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 01-10-2006, 05:52 PM   #36
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
heres a good product to shine up rubber under the hood wd40
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 01-22-2006, 06:00 AM   #37
_Dick_
PROUD TO BE A MEMBER
_Dick_'s Avatar
i did notice any thing other then mild soap and water used on my motorcycle tires voids the warranty
I wouldnt use it anyway ,it might get very interesting leaning the bike tire into that shiny stuff at legal speed wheeeeeeeeeeeeeeeeeeee
_Dick_ is offline   Reply With Quote
Old 01-23-2006, 10:21 PM   #38
lofly'a
lofly'a's Avatar
i use pledge inside also, but i like the goop tip. i don't know if i'd like the smell as much though.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 01-26-2006, 02:39 PM   #39
Rydn2L0w
Active Member
Rydn2L0w's Avatar
PLUS if you ever plan on getting any paintwork done, armor all causes fish eyes like crazy. PPL usually love to juice there whole car or truck with this stuff then drop it off at the shop! Just because it shines, doesnt mean it looks good!
Rydn2L0w is offline   Reply With Quote
