08-10-2005, 11:05 PM | #26 |
I used stainless steel line and brass compression fittings, you should be able to pick up the parts a auto supply store. I got most of the stuff at Napa, and Acklands, the rest at a local machine shop.
08-10-2005, 11:46 PM | #27 | |
Psalm 23
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD. "Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy |
08-11-2005, 07:16 PM | #28 |
Around $25, plus the reg and gauge. That's with the adapter fittings for the carb, hard line was free, and I borrowed a guy's double flare tool to make the carb connections. Yes I know you aren't suppose to double flare stainless steel, but it worked for me.
08-11-2005, 11:22 PM | #29 |
Got Big Block?
very nice. I'd like some more info on the baffeled breathers. take a look at my pic in my sig. I spun mine up to 6k a few days ago and puked a fair amount of oil through my cheap breathers....
"Experience is what you get when you didn't get what you wanted." |
08-11-2005, 11:45 PM | #30 | |
Psalm 23
Sorry to cut into your thread here but I really am interested in how ya made that. Teach this man to fish.
08-12-2005, 11:04 PM | #31 | |
08-12-2005, 11:26 PM | #32 | |
08-13-2005, 01:31 AM | #33 |
Psalm 23
I will most likey be running a Street Avenger carb(dual fuel inlets) and a standard ol mechanical fuel pump. My current carb(quadrajet) has seen its last days as I believe its getting warped so its time to upgrade. I just really didn't want to run a hard line up from the fuel pump as its a real tight fit and I don't won't to put to many bends in the line(such as there is in my current line).
Thanks for your help!
08-13-2005, 04:23 PM | #34 | |
08-14-2005, 01:29 PM | #35 |
I have a REALLY stupid question, so dont make too much fun of me...I see all these people with their chrome valve covers, and such with breathers, but when you all change your oil, where do you pour the new stuff in? My truck has the filler hole for the oil in the back...so does it matter where you put the oil in from as far as the valve covers or what?
-Steve |
08-14-2005, 02:39 PM | #36 | |
Psalm 23
llegos go back to page one where someone asked the exact same question...the answer is there too .
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD. "Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy Last edited by R@nger; 08-14-2005 at 02:39 PM. |
08-14-2005, 03:09 PM | #37 |
haha, thanks. my comp lags sometimes, and can skip over a couple posts when im scrolling down. thanks for that. now it wont be so confusing once i get my chrome covers and try to change oil...
-Steve |
08-14-2005, 07:09 PM | #38 | |
All you need is a chrome Holley line fo duel feed carb, $15-20 bucks at Jeg's or Summit. You could run a rubber hose from the pump to it, I know alot of people don't like that but it's the cheapest, $20 complete set up. You could go with braded line from your pump to carb for a bit more around $75 complete. Summit part # SUM-G3156 $37.95 plus Russell part #799-641090 $39.99 will give you a braided line setup with a nice braided bowl feed line a really sweet set up for the price ( what I would use if I wee you ). Or the cheapest way would be Mr.Gasket part # 720-1552 $15.99 plus a Mr.Gasket part #720-2965 $4.69 plus a piece of rubber hole and clamps. Lot's of options depending on your budget. Last edited by 71Dragtruck; 08-14-2005 at 07:11 PM. |
08-14-2005, 07:45 PM | #39 |
Psalm 23
Yeah I'm on a very tight budget but I want quality so I guess I'll be saving for a bit. I'm gonna go with that braided line setup you suggested.
Thanks again.
08-14-2005, 08:41 PM | #40 |
It's a good choice, might as well save in the start, or you will just end up redoing it later.
