Old 07-06-2006, 04:37 PM   #26
BowTieOgre
Re: Who has Impala SS rear disc brakes ??
Im interested in these brackets as well.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 07-06-2006, 11:01 PM   #27
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
So who wants to make some $$ making some brackets ?
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 07-07-2006, 11:44 AM   #28
SB406
FORD is a 4 letter word.
SB406's Avatar
I've got Impala SS rear discs on my 71 GMC. I went the other way though.....Got an entire rear end out of a Caprice Cop Car (Same as Impala SS), cut off all the caprice trailing arm crap. welded on my own saddles & shock mounts & bolted the entire setup into the truck. That was the main reason I chose to start with a rear leaf truck. I've got the parking brake that works on the drum inside the rotor. E-brake cables were a lot easier than expected. I'll try to snap some pics.
I'm probably the ONLY guy to take OUT a 12 bolt, but the 8.5" 10 bolt from the caprice has 30 spline axels and is beefy enough for what I'm doin.
I have another one slated for my '58.
'71 406 GMC Short Box Fleetside - Daily Driver
'79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com
'58 LT1 Chevy Short Box Step Side - Next Project
SB406 is offline   Reply With Quote
Old 07-07-2006, 12:34 PM   #29
BowTieOgre
Actually I was thinking of doing the exact same thing with the '96 Caprice I bought from HartRod but I keep getting funny looks when I mention replacing my truck's 12 bolt with the 10 bolt. If you could share your experience with installation and performance after the install I would appreciate it.
Old 07-07-2006, 01:16 PM   #30
SB406
SB406's Avatar
I'm pretty satisfied. My rear end was a '95. I finished off the Auburn Posi that came in it and found out it's not rebuildable. I put in a detroit true-trac instead. VERY happy with that.
The housing had ears cast into the center section which I trimmed & ground off. I then trimmed all of the steel mounting brackets off the tubes, Lined up spring perches, & welded em up. I've since added traction bars and a sway bar. No complaints. only thing was, the caprice housing was about 1"-1.5" narrower than the stocker. I centered it up in the truck & fixed the width issue with my wheel backspacing.
For the E-Brake cables (this is slick..)
I ordered new rear cables for the caprice which both route to the driver side instead of the "X" style setup which was original to the truck. I saved the brackets that hook the 2 cables together & support them to the frame from the caprice (same setup was used on late 80's chevy vans & MANY other applications). I hooked up the cables to the rear end, hooked them through the above mentioned brackets and ran the cable that needs to be pulled up under the frame rail toward the front. Wouldn't ya know, the stock cable on the truck from the pedal lined up within an inch of the caprice rears. Plus, the cable from the pedal has a 1/4" threaded section for adjustment! Almost like it was made to work.
This is tough to visualize and pics speak 1000, so I'll snap some pics at home tonight.
I get funny looks on the 12 bolt thing too, but I don't really care what other people think. I'm of the opinion that I'm the one driving it, so I'll build it the way I want. If someone else would have done it different, that's fine, they can go build one. By the way, I kept the 12 bolt just in case . Sorry, didn't mean to hijack the thread.
Old 07-07-2006, 01:51 PM   #31
project1971
project1971's Avatar
I am tearing into my truck next weekend for new motor and trans but was going to add rear disc later but this thread had got me thinking i need to do it now instead of later. Any and all pics would be greatly appreciated.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 07-07-2006, 02:03 PM   #32
BowTieOgre
If I could get some brackets fabbed up I would love to keep my 12 bolt in place. Anyone have any ideas where to look for a vendor?
Old 08-08-2006, 01:21 PM   #33
SB406
SB406's Avatar
Better Late Than Never, Right?......
These are the pics I promised of my '95 Caprice Cop car rear end in My '71 GMC Daily Driver.
Pics Show rear end in truck (dirty)
and the e-brake cable connections/ brackets
Old 08-08-2006, 01:26 PM   #34
SB406
SB406's Avatar
Couple More Including the '78 Corvette MC I recently put on......
Old 09-12-2006, 03:25 PM   #35
BowTieOgre
Thanks for the pics man. I will keep you updated on what happens with my setup. BTW, when you said the caprice housing was about 1"-1.5" narrower than the stocker did you mean from one side to the other or from the center out?
Old 09-12-2006, 03:51 PM   #36
SB406
SB406's Avatar
Overall width, axle face to axle face is 1"-1.5" narrower.
Old 09-12-2006, 04:20 PM   #37
BowTieOgre
Thanks man...need to keep an eye on my backspacing when i order my wheels.
Old 09-12-2006, 07:56 PM   #38
Inthuwind
Straight jacket required
Inthuwind's Avatar
Bracket specs for 12 bolt rear and CAPRICE calipers
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 09-13-2006, 10:15 AM   #39
jkade
jkade's Avatar
Will the setup off a 99 camaro work?
jkade is offline   Reply With Quote
Old 09-14-2006, 12:13 AM   #40
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
Anyone know of, done home grown disc brakes on a Dana 60? Most I see on E-Gay are for "Dodge" or "Ford" style Dana 60's. Is ours one of the two or its own backplate boltpattern?
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 09-17-2006, 12:01 PM   #41
ClemsonChevy
Bump?
95 2500 350 w/ 3.73
Old 10-06-2006, 05:42 PM   #42
jkade
jkade's Avatar
I have a set of c4 corvette calipers, will they work?
Old 10-06-2006, 06:19 PM   #43
Inthuwind
Inthuwind's Avatar
The 94-96 Caprice work and I believe the Camaros do as well, not sure about the Vette's--TTT
Old 10-06-2006, 07:05 PM   #44
84 400
Sb 400 club
84 400's Avatar
i am pretty sure the vettes will work and i belive the bracket is much like the camaro but i might be wrong
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 10-07-2006, 05:10 PM   #45
powell72
powell72's Avatar
I am about half way through collecting parts to do this swap, has anyone ever tried to adapt the backing plate/e-brake shoes onto the truck rearend? Is anyone making brackets yet?
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 10-07-2006, 05:26 PM   #46
Inthuwind
Inthuwind's Avatar
I made my brackets from the specs I posted above. I could not use the bracket supplied from the Caprice. I also don't have an E brake, but might go with a Camaro caliper later that has them.
Old 10-07-2006, 07:38 PM   #47
WLPTMP
Active Member
WLPTMP's Avatar
only problem with using the caprice stuff is you cant get the left hand backing from gm anymore i founf this out after buying slotted and cross drilled rotors, new loaded caliper and a rh bracket
WLPTMP is offline   Reply With Quote
Old 10-08-2006, 03:12 PM   #48
powell72
powell72's Avatar
Inthuwind, I think the Camaro calipers take a different bracket then the Impala so you can't interchange without them.
Chris
Old 10-08-2006, 03:31 PM   #49
Inthuwind
Inthuwind's Avatar
I thought I read somewhere here that they used Camaro calipers on Caprice brackets. I'll look around in here and see if I can find the article. Sorry if I am wrong, maybe someone will chime in here~~~TTT for now.
Old 10-08-2006, 03:58 PM   #50
Inthuwind
Inthuwind's Avatar
Well, the calipers and brackets are about the same, I see you need to fab a different BACKING PLATE for the different calipers from what Chopped 71 did on the first page of this thread. Correct me if I'm wrong, I don't want to confuse anyone. My 12 bolt rear is done, with caprice calipers, brackets and self fabbed backing plate. I thought later I would just swap to camaro calipers.
