#26 |
needin' money
Re: 73-87chevytrucks pickup.
lookin good!
SWB Stands for Short Wide Bed |
#27 |
yeller
DAMN chris!!! That looks sweet, you definately ruined my day!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#28 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Saturday May 20th: lifted the motor up and pulled the ECE mounts off and replaced them with the new S&P plates. Installed the "normal" SBC mounts and dropped it back in place. As you can tell, the motor sits back quite nicely now. Once the plates were on I took the original Truck manifolds and test fitted them. The driverside fit fine. The passenger side still hit some (of which I had expected) and I chose to see what I can do along the lines of grinding down the area I don't want to use since I liked how they exited the truck. After some grinding I got it so it doesn't hit. Now I just need to plug the hole off.
![]() http://www.73-87chevytrucks.com/proj...dp_plates2.jpg ![]() ![]() http://www.73-87chevytrucks.com/proj...man_clear2.jpg http://www.73-87chevytrucks.com/proj...man_clear3.jpg ![]() ![]() Once that was out of the way we decided to pull the Tilt frontend out of it home of about 8 years. We pulled it out and set it on the truck for a general idea of what we were up against. ![]() ![]() ![]() ![]() ![]()
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 05-30-2006 at 05:57 PM. |
#29 |
Sunday May 21st: After successfully removing the Tilt from the crate we decided to start on the core support next. Since the leading edge of the core support is built into the tilt A LOT of metal had to be removed and we still are not done. I plan to update my How-to section on captkaoscustoms.com with the process, but here is what we started with and here is where we are now.
![]() ![]() Once we got this far we realized that there were going to have to be some modifications on the mounting of the core support and we needed to get all the body panels back on. We trimmed the bed for the Blazer tank Mod and then set it down on the frame. The we mounted up the doors and tried to get them aligned as best as we could. (yes these are GM doors from another truck and they need some serious work to be perfect) Once we got the body line fairly close we began the inspection process and dropped the frontend on and tried to align it. This is were we are currently ![]() ![]() ![]()
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#30 |
Happy to be here
![]() Join Date: Mar 2000
Now that's what I call progress. This is a huge step in the right direction. I'm not sure what got you fired back up on this, but it's working well. Keep it coming...
#31 | |
#32 |
Fat Fendered Fleetside
man your project is looking just great!
keep it up.. |M|
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
#33 |
any progress lately?
#34 |
Well, I am trying to get with my bodyman so he can take a look at somethings before we finalize the mouting of the tilt. The last visit didn't warrant posting since I just went to pick up the manifolds to have some block-off plates made for them.
I hope to mock the turbo this next time around to find the best placement/routing.
#35 |
turbo? did you say turbo?
holy hell this is gonna be one bad truck. i have a line on a 5.3 out of a 2006 truck and was wondering if you know if there is any difference between the 6.0 and 5.3? truck looks great man! i wish i were as far along as you. |
#36 |
Yep, a turbo. I am trying to decide between 1 or 2. My other business venture is with my brother who started out selling STS turbo systems...
The 6.0L has a larger bore than a 5.3L, same crank throw. there are some other differences like cam size etc... Is this what you were looking for? I did make it up there to check it out and it will be possible to fit 2 under there. I also talked to another bodyman that did some work on the cab, he said that he may have some time to work on it..
#37 |
i was mainly looking for differences in block mounts and frame mounts. i was sure the blocks would be fairly similar but was not totally sure.
thanks steve |
#38 |
No difference in the blocks at all.
#39 |
Born a Chevy Man
Man, that thing is going to be (pardon the expression) *****en!! Really looking good.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
#40 |
7/16/2006 - I picked up my manifolds that I had plates cut for the EGR ports (pics coming)
7/23/2006 - Went to the shop to pick up my wiring harness. 7/24/2006 - Ordered the first phase of plugs that I am missing for the 4L80E. Should be here tomorrow.
#41 |
Sunday Dec. 10th, 2006: With all that is going on at the house with remodeling and such I have broken down and ordered a wiring harness for the truck so it will be moveable. Sorting through it requires more time that I can currently spare.
#42 |
Chevys Kick A$$
Damn, great progress. Just now read through the whole thread. Thats going to be 1 bad ass truck when its all done!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
#43 |
Sb 400 club
WOW nice work on that one gonna have 2 sweet trucks when they are done. nice motor choice by the way!!!!!
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
#44 | |
