05-28-2006, 06:28 PM | #26 |
Questionable
Re: my official 68 shortstep ls1 thread (lots of pics)
did you make your own lines? i know there are a lot of simple kits out there to make braided lines, just curious if that's what you did.
you are using a fuel pressure regulator, right? i am quite certain you cannot get by without using one on this engine. the stock LS1 has a filter/regulator in one unit.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
05-28-2006, 06:41 PM | #27 | |
im useing the truck manifold, which has the regulator built in the fuel rail. |
05-28-2006, 06:54 PM | #28 |
Questionable
wow i need one of those!
05-28-2006, 06:54 PM | #29 |
Questionable
oh - last question - how much you have sunk into the lines and adapters alone?
05-28-2006, 07:00 PM | #30 |
Project92 SWB stepside
Nice progress man!! I dont think my wife has been in the garage over 10 times in over 2 yrs.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
05-28-2006, 07:13 PM | #31 | |
05-28-2006, 07:17 PM | #32 | |
05-28-2006, 08:20 PM | #33 |
Questionable
i had the opposite problem - ever since my woman and i broke up a couple weeks ago, i ain't got nothing done i couldn't keep her out of the garage in anticipation of the truck being done.
i've been helping other board members with stuff though, enough that i have an excuse why i can't work on the truck
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 05-28-2006 at 08:21 PM. |
05-29-2006, 09:26 AM | #34 |
Did you use the same size lines for feed and return?
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-29-2006, 10:15 AM | #35 | |
05-29-2006, 11:03 AM | #36 |
Beautiful job!!! Nice pics and expalination. I just ordered my fuel line and will be putting in my Fuelcellguy tank and running line. I am using a combination of hard aluminum and braided line.
05-29-2006, 08:04 PM | #37 |
Straight jacket required
Awesome Awesome Awesome!!! Keeps me motivated on mine. Keep the pics coming.
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." |
05-30-2006, 12:25 AM | #38 |
MY EX DRIVES A BROOM
good progress....keep the pics coming.
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
05-30-2006, 12:31 PM | #39 |
chevelito
yes...very good write up and thanks for the part number on the fuel line adapter.
New deadline...when my son can drive. Aloha from Honolulu, HI |
07-08-2006, 12:49 AM | #40 |
welp, more progress to report... been working on the rad support. under the bat box was all corroded and pitted or non existant, so i cut out the old metal and welded in new metal, shaved the ' bumps ' on top of the support, filled a few non used holes ( need to fill couple more ), and finished mounting my radiator..... i had to drill out the old bottom rad mounts , move them to fit this rad ,and welded them back to where there new home now is.. the overflow tank is pretty streight forward locate and drill 2 holes and mount with included hardware.. plan for the next week include finish 'smoothing' rad support, disassemble (after mock-up), take to get sand blasted, prime, sand,sand,sand, paint, sand,clear,clear, clear, sand,buff.....reassemble and install.....
07-08-2006, 01:04 AM | #41 |
Yeah right, show off.
07-08-2006, 01:18 AM | #42 |
Tell me how you prepped and painted the engine/trans, chassis and driveshaft if you would. Im almost ready to get my frame going. Nice job BTW.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
07-08-2006, 08:36 AM | #43 | |
on the frame and such... i had them sandblasted, then go over it with acetone (till clean), prime it with 2 coats, paint with 3 coats paint, then 3 coats clear.. remember get good quality primer, paint, clear so it will with stand the road... or powdercoat it |
07-08-2006, 08:54 AM | #44 |
It's looking better every post.
09-16-2006, 11:40 PM | #45 |
ehaust will be gitting done this week.... had to install my flang on the slip flang (i dont like) so it'll be easier to connect/disconnect should i need to....
09-17-2006, 08:03 AM | #46 |
prommises to become a verry nice truck ill keep an eye on the progress .
those LS1's look great and from wat i've read about them there pretty sturdy too
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
09-17-2006, 08:33 AM | #47 |
-Chris
Very nice work, looks real good. Keep it up!
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
09-18-2006, 05:41 PM | #48 |
Looks great!!! Nice work.
1977 Camaro 468 BBC - SOLD - 1972 Chevy SWB....in the works!! 2006 Crew Cab Dmax/Allison Summit White-SOLD- 2009 Toyota Tacoma V6 Pre Runner - daily driver - my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595 |
09-20-2006, 11:31 PM | #49 |
the exhaust is ready to be installed... i had to get the rear sway bar installed so there wouldnt be a interference problem with the exhaust being dumped in that vacinity..... i got the POL front and rear kit ( although the front has no way of fitting, atleast as i see it... and the rear i would of designed the mounting bracket to pick up a existing hole in the frame instead of haveing to drill a new one!! but so far there customer survice is doing good, i'll keep ya'll posted)
and the rear installed pics Last edited by 68 short step; 01-10-2008 at 04:40 PM. |
09-22-2006, 07:56 PM | #50 |
the exhaust pipes are bent up ( have the mufflers, moroso spiral flow) they are 3 inch.. ill mount the mufflers when i mount the bed cross seals. so i can see where i need the hangers to go... its gonna be dumped just before the rear axles (i also have the turn downs )
