04-28-2009, 12:03 AM | #26 |
Re: Rochester Monojet Help
I woulod be interested in getting a pic from the front of that carb set-up. I can't seem to figure out how the choke rod is supposed to be bent and hooked up for my 292
I got some carb pictures you may want to look at http://s221.photobucket.com/albums/d...2pulled077.jpg |
04-28-2009, 09:25 AM | #27 |
I hop these help some. I don't know if the linkage has been bent over the years or not.
04-28-2009, 10:06 AM | #28 | |
Active Member
The 2 barrel has larger openings than the primaries on a quadrajet. I used to have a 2 barrel and the gas mileage was dismal. If gas mileage is the main concern, about the only thing that may help is rear axle ratio change, overdrive transmission, HEI distributor and maybe larger tires. |
04-28-2009, 11:20 AM | #29 | |
Q-jet primaries are 1-3/8" each, or 2.97 in^2 total area. That's the same as a 1.94" bore. I tought most 2bbs had 1.5-1.75" bores. I know Holley/Webber made some 2bbls with different sizes for the primairy and secondary. And I want a vacuum secondary if I can find one, not a mechanical. Guess I should start a different thread for trhis. It's off the monojet topic. |
