Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-25-2006, 08:08 PM   #1
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: Ran 11.44 @117.69mph
thats fast
AesC10s is offline   Reply With Quote
Old 06-25-2006, 08:22 PM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Another thing to keep in mind with his truck is that it would even faster closer to see level. What is the altitude in Sask?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-25-2006, 10:33 PM   #3
71Dragtruck
71Dragtruck's Avatar
Not too bad, little over 2000 I think? Hoping to make it to Medicine Hat next weekend, they have a new concrete launch pad it's suppose to have bite.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 06-25-2006, 11:31 PM   #4
bigjimzlll
bigjimzlll's Avatar
10.00 and below need sfi sheilds, unless the firewall is not stock. 10.99 and below you need aftermarket axels/or C clip eliminators. 11.49 to 10.00 need a 5 point roll bar and sfi fire jacket.
Here is the online rule book
http://members.tripod.com/MY5LTR/NHRArules.html
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 06-25-2006, 11:45 PM   #5
71Dragtruck
Thank's Jim.
Sponsored by:
Hard Candy Customs
Old 06-26-2006, 09:00 AM   #6
67_C-30
67_C-30's Avatar
2000 ft is pretty substantial though. According to NHRA's website at sea level you would be running 11.17 @ 120.52 at sea level. This is not really important at your track because obviously everybody is at the same disadvantage. It's just cool to see what would run at a track like Montgomery Motorsports Park or Silver Dollar in Georgia because they are only 400-500 ft. Here is the NHRA's conversion chart if you want to check it out.
http://www.smokemup.com/auto_math/nh...on_factors.php
My brother's '78 GMC has run a best of a 11.98 @ 112.11 (7.58 @ 92.86 in 1/8) with a 1.71 60' on motor with much less engine than you have. We'd only be in the mid 12's at your track. Here is link to his truck if you wnat to check it out also. http://www.bassettracing.cz28.com/photo2.html
My trucks
Old 06-26-2006, 10:26 AM   #7
71Dragtruck
Nice truck your brother has there, I'm allways interested in checking out other drag trucks. Would be nice to make a couple of passes at a near sea level track. But it is cool when you line up against a 440 procharged Challenger, stripped interior, roll bar, open headers etc. and then the look you get when you beat him, PRICELESS. Icing on the cake is when he asks later how big a shot your running and you tell him that was just motor.
Sponsored by:
Hard Candy Customs
Old 06-26-2006, 11:26 PM   #8
67_C-30
67_C-30's Avatar
Thanks. No matter how many times I see it, it is PRICELESS to watch this ol' truck sneak up on some unsuspecting Mustang or Camaro. My brother drives this truck around town a good bit, and lot of people who haven't seen it run just assumes since it street driven that it isn't really fast.
We are planning on a cage in future for his truck, because with the cheater shot, he is creeping up on high 10's. We are going to freshen up the engine this fall, and probably go with a solid roller. Here are a few old scanned pics when we built the truck. It was STUPID FUN driving it around with the front clip and bed off!!
My trucks
Old 06-26-2006, 10:39 AM   #9
71Dragtruck
Which rule would apply, they have 2 different rules, or has it to do with stock floor boards.
Under general:
2.14 TRANSMISSION, AUTOMATIC
Any non-OEM floor-mounted automatic transmission shifter must be equipped with a spring loaded positive reverse lockout device to prevent the shifter from accidentally being put into reverse gear. Functional neutral safety switch mandatory. All transmission lines must be metallic or high-pressure-type hose. All vehicles running quicker than 9.99 seconds (*6.39) or faster than 135 mph (217.2 km/h) and using an automatic transmission must be equipped with a transmission shield meeting SFI Spec 4.1 and labeled accordingly. "Blanket" type shield, appropriately labeled as meeting SFI Spec 4.1 permitted. All non blanket type shields must incorporate two (or one, per manufacturer's instructions) 3/4-inch (19.1 mm) x 1/8-inch (3.2 mm) straps that bolt to the shield on each side, and pass under the transmission pan, or transmission pan must be labeled as meeting SFI Spec 4.1. Permitted in all classes where an automatic transmission is used. 9.99 (*6.39) or quicker ET cars, and 135 mph (217.2 km/h) or faster ET cars using an automatic transmission must be equipped with a flexplate meeting SFI Spec 29.1 and covered by a flexplate shield meeting SFI Spec 30.1. Air shifter bottles must be stamped with DOT -1800 pound (124 bar) rating (minimum) and be securely mounted (i.e. no tie-wraps or hose clamps.)
Or would it be this?
Under SECTION 1A
E.T. SUPER PRO, PRO, SPORTSMAN
7.50 (*4.50) seconds or slower:
2.4 TRANSMISSION, Automatic
Spring-loaded, positive reverse lockout device and functional neutral safety switch mandatory. Transmission shield meeting SFI Spec 4.1 mandatory on any car running 10.99 (*6.99) or quicker or any car exceeding 135 mph (217.2 km/h). Automatic transmission flex plate meeting SFI Spec 29.1 and flex plate shield meeting SFI Spec 30.1 mandatory on cars running 9.99 (*6.39) or quicker or any car exceeding 135 mph (217.2 km/h). See General Regulations 2.14.
Sponsored by:
Hard Candy Customs
Old 06-26-2006, 02:28 PM   #10
57sailplane
57sailplane's Avatar
hey 71 drag truck here are some pictures of the cage welded to frame underneath cab. if you need anything else let me know.
57sailplane is offline   Reply With Quote
Old 06-26-2006, 03:15 PM   #11
71Dragtruck
Thank's, that's a serious cage you got going there, you must be planning on some 9's.
Sponsored by:
Hard Candy Customs
Old 06-26-2006, 05:25 PM   #12
57sailplane
yes i would be happy with low 9's since i am running a sbc 383 with nos. my combo might not be as large as yours but i hope it will go the distance.. i built it expecially for nos.. cam pistons and even heads were ported profesionally for nos.. anyways the weight thing is what i am looking at now. thats why i was wandering what your truck weighed.. anyways keep us posted on what your doing cause alot of us wish we were racing...
Old 06-26-2006, 09:38 PM   #13
bigjimzlll
bigjimzlll's Avatar
Under general:
Under SECTION 1A
You know I don't know. I'm running 10.20's on N20 and they haven't said anything about a trans shield. 10.99 on motor alone so I better find out b4 I go to a real track. My track is 550' above sea level but the DA is always over 4000'
I know I could get into the 9s but I'm not licenced or the truck isn't speced to run below 10.00
Anderson,CA
Old 06-26-2006, 09:57 PM   #14
71Dragtruck
What's yours weigh again, and are launching on a trans brake? I'd love to be running 10's on motor, doubt I'll ever run as fast as you. I,d have to lighten it up for sure, or go to a 540 next re-build, just need the block and pistons.
Do you have a DA chart, or how do you figure that?
Sponsored by:
Hard Candy Customs
Old 06-26-2006, 09:49 AM   #15
Zumo
Hot Rods For Life
Zumo's Avatar
Man! 71Dragtruck you and 57sailplane have big boy trucks. Good job on the run.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 06-26-2006, 10:07 PM   #16
bigjimzlll
bigjimzlll's Avatar
3500 wit my fat azz. I leave on a brake chipped at 4000rpm with a 5500 stall. 4.86 gears with 32x14-15 slicks. Im swappin converters this week. Going with a 8" ATI instead of the 300 dollar Torco. I'll see if it picks up as much as I think. In bracket mode I leave easier and short shift and run 11.33 at 115. It just dosen't MPH good at all. I will be going BBC next year.
Anderson,CA
Old 06-26-2006, 10:16 PM   #17
71Dragtruck
what you going through the traps at? Motor and with nitrous, I was going to go to a 31" tall tire and a 4.30 gear. I have a 29" and 4.10's now, go through at just under 6000? ( have to run on a better night to make sure ). When I ran 28" tires it was going through at 6200. I'd like to take off 200lbs. to make up for my fat azz LOL.
Sponsored by:
Hard Candy Customs
Old 06-26-2006, 10:18 PM   #18
bigjimzlll
bigjimzlll's Avatar
7200 rpm at 125mph The converter is too loose for N20
Anderson,CA
Old 06-26-2006, 10:33 PM   #19
71Dragtruck
That's BADAZZ, you have to get some video for us.
Sponsored by:
Hard Candy Customs
Old 06-26-2006, 11:32 PM   #20
Tynee
I miss this truck.
Tynee's Avatar
When I take her to the track she really shines
She always turns in the fastest times
My four speed dual quad posi-traction 409
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 06-27-2006, 10:12 AM   #21
57sailplane
hey bigjimzlll i noticed you a said somthing about a bigblock next year. what you runin now? did you remove the radiator suport to get her down to 3500lbs? by the way this is a bad a## thread..
Old 06-27-2006, 11:27 PM   #22
57sailplane
ttt
Old 06-29-2006, 02:31 AM   #23
409biscayne
409biscayne's Avatar
Now that's my kinda comment .
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 06-28-2006, 07:44 AM   #24
bigjimzlll
bigjimzlll's Avatar
I didn't remove it..but I did make it lighter. The engine is a 13-1 406.
Anderson,CA
Old 06-28-2006, 10:43 AM   #25
57sailplane
what are you guys runing for rear ends.. i have a 12 bolt in mine.. i hear there not as strong as the car 12 bolt which confuses me cause i would think a truck 12 bolt would be stronger. of course i am going to beef up whatever i build.. i can get a ford nine inch (wichever one i want) real cheap hear at a local junk yard.. what do you quys sugest. i have not had my engine dynoed but am shooting for 550 hp to 600hp on the motor and 900 on nos.. as i said before i built this thing for nos and have done my home work.. anyways what do you guys think or what are you runin..
