Old 04-01-2021, 08:43 AM   #26
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: 1970 4x4 Blazer Disc brake conversion
Originally Posted by ohboy321 View Post
The only parts that will bolt in on a 70 D44 would be from a 71. They increased the axle and u-joint size starting in 72.
Duckduckgo the BOM (bill of materials) for the D44 and you can see the axle part numbers are different between 71 to 72, while 70 to 71 are the same. Sorry I don't have a link for the BOM, but the info is out there.
My K10 has a 70 Blazer D44 front axle, and I hope to convert to disk some day.
Regardless of the thread age, this info is gold. On my 1970, I am just swapping the entire front diff from a 1972 to avoid mismatched parts.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
Old 04-15-2021, 11:59 PM   #27
mthomlinson
I swapped 72 axle into my 70, The brake lines are a different size and go through the frame in a different location
mthomlinson is offline   Reply With Quote
Old 04-16-2021, 12:13 AM   #28
franken
Hmm, I always was under the impression was 71-87 pickup (81 on Blazer and sub) front half ton D44 diffs pretty much swapped.
I had a 3/4 ton 91 sub I was going to swap the diffs for on my 72 K10, but got lazy.
franken is offline   Reply With Quote
