11-20-2006, 10:50 PM | #26 |
Re: This is pathetic. What's broke?
I would start by checking the electrical, rotor, coil, wires, we are dealing with a 454 they have enough ponies you can loose a bunch and not notice them without a big load. you might try putting a load on it and see if it tells you more. If those are ok, I would then do compression check.
11-21-2006, 10:37 AM | #27 |
Active Member
3.33 mile to the gallon sucks.
11-21-2006, 11:10 AM | #28 | ||
7000 #'s of american IRON
11-21-2006, 11:24 AM | #29 |
just checking, these are KITS, correct? It says includes lifters, are they 1.5 or 1.6 lifters?
Jegs #'s 638-60200LK 638-60201LK 270-133904 270-133934 |
11-21-2006, 11:32 AM | #30 |
Parts and more parts
1) Look at the choke being closed when it should be open.
2) Look at the oil for saturation of fuel into it, could be a float is sticking the carb. 3) Look at the tank for any leakage. 4) Check the motor for a good tune and operation. |
11-21-2006, 11:38 AM | #31 |
I'm just about to switch this thing to manual choke...i've been battling it for a year, replaced the stat coil, just can't get it to work right. I'll check if it's opening sometime, may put a default-to-open return spring on it if i have to. The tank isn't leaking, and i'm going to go over the motor today.
11-21-2006, 11:58 AM | #32 |
how well named...the title says "what's broke?"
the answer: the clip that holds the rod from the choke stat to the choke lever..so the choke was flapping around as it pleased, the rod was just sitting there hooked to nothing. |
11-21-2006, 12:10 PM | #33 |
Just pulled the #2 plug, its gapped at 45 and is thoroughly tan, that's a good A/F ratio, right?
Hardly any carbon buildup, it looks by my guide like it's somewhere between normal and high speed glazing. Last edited by magnethead; 11-21-2006 at 12:19 PM. |
11-21-2006, 01:35 PM | #34 |
ok, so i made about 4 trips walking around my truck with a rubber mallet. Who wants to guess how much of what was on the ground when i moved the truck afterwards?
11-21-2006, 03:30 PM | #35 |
Sb 400 club
i know that feeling man my old 85 was really bad abpout leaving parts behind
i used to hit the frame with a sledge lightly and listen as a ton of flakes fell on the ground ahhh well
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
11-21-2006, 08:30 PM | #36 |
actually in this case, it was 5 gallons/60 pounds of mud and tar (our road just got paved).
11-21-2006, 11:53 PM | #37 |
sounds fun
11-22-2006, 12:45 AM | #38 |
I fixed the choke lever, looked in my box of wiring and made myself a 1" length of bare 22AWG solid copper wire. Bent it around the groove twice, made it tight with pliers, and i don't think it'll go far.
All that mud (very little was actually tar) had been there for a very long time, so i should be down from 6680 to 6620 or even 6600 pounds even. Also, i found another mileage culprit: the aircleaner. Apparently is till have an OE replacement paper element- i cranked the air compressor to 60 PSI output and held the nozzle straight to the paper, i couldn't hardly feel anything directl across the element from the nozzle. Is that restricting or what? Last edited by magnethead; 11-22-2006 at 12:47 AM. |
