01-25-2007, 02:00 AM | #26 | |
Re: 72 chevy cab with a/c-parting out.
I think I'm going to try to go with a gray interior so I'll pass 'em on to you gringoloco.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
01-25-2007, 05:04 PM | #27 |
gringoloco-$15 to ship..
CG- not yet, just put headers on it. what part of the dash do you want? |
01-25-2007, 09:20 PM | #28 |
A guy with a truck
I'll take 'em. PM me your payment info. Thanks -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-25-2007, 10:07 PM | #29 |
hazard knob???
01-25-2007, 10:07 PM | #30 |
oh i need a pic too.
01-25-2007, 10:15 PM | #31 | |
BlahBlahBlah
Mark |
01-25-2007, 10:25 PM | #32 |
CG- you understood correctly. I am trashing the cab, but I wanna make sure I can keep moving the truck around. Don't wanna take the cab off till I get the engine work done.
ol'Blue- pics on the message board. gringoloco-pm coming. |
01-25-2007, 10:51 PM | #33 |
BlahBlahBlah
Oh ok...well if you want, when you are done stripping that thing down I will take whatever is left over. I just want the dash. Im going to be purchasing a welder soon and I could use the stripped out cab to practice with. OH...wait...I should ask what you are going to want for it first lol. Let me know.
02-23-2007, 01:26 AM | #34 |
Official C-10 Destroyer
can you get some pictures of the doors (mainly the bottoms of them) the cab floor, and the fenders? please? lol
5 miles to a gallon, and lovin it! Deceased: 1972 C10 Stepside, 350ci smallblock, Edelbrock 750 performer carb, Edelbrock Performer RPM manifold, DynaMax headers, Thrush glasspacks, flame-throwers! |
02-23-2007, 02:59 PM | #35 |
How much forthe steering column clamp??? (Goes around steering column and clamps to the firewall slightly below where the brake master cylinder bolts to firewall. MUST be in good shape, if rusty then I'll pass. TJ
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD |
02-23-2007, 04:52 PM | #36 |
Active Member
I need the screws that hold in the AC vents on the far left and far right hand side of the dash, the screws that hold in the swivel balls?
How much?
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
02-23-2007, 05:31 PM | #37 |
67 chevy SWB Fleetside
I'd like that gas pedal assembly if 71meangreen doesn't come through
67 Chevy C10 Short Wide 350/350 ... Front Discs ... ECE Lowered 2.5/4 Vintage Air ... Oak Bed Floor ... Painless Wiring Brothers 1 pc Windows ... Lokar Pedals, Shifter, E-brake Ididit Column ... VDO guages |
02-24-2007, 04:39 PM | #38 |
1971LT1-pic below for you. is that what you need? $15 to your door.
1968SWB-screws for the a/c balls aren't the right type, they are just some generic standard screws. zacut- gas pedal assembly yours, if you want it. $20 plus the ride. |
02-27-2007, 08:21 AM | #39 |
That clamp is the one that goes inside the cab below the dash panel.
I'm after the clamp that goes around the column forward of the firewall, under the hood, near the master cylinder.
