Old 01-12-2007, 08:28 AM   #26
gregfull
gregfull's Avatar
Re: Let's see some pics of shaved firewalls
Thanks for all the compliments! I plan to use a painless harness also, but my battery and fuse block is going to be relocated to the rear of the suburban, all wiring will be hidden (as best as possible). As for my A/C and heat, I will be using a Vintage Air system and all plumbing (heater lines and a/c lines) will be run between the fender and cab fresh air area, (it'll be tight, but it will be hidden). My goal is to have as few wires and lines exposed as possible, all of my lines will be custom bent stainless tubing. Thanks again. Greg
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 01-12-2007, 03:47 PM   #27
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
I still have alot of bodywork to do to get it completely smooth. There will be nothing on the firewall except for the throttle linkage coming out.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 01-12-2007, 03:59 PM   #28
cstm68
cstm68's Avatar
thats gunna look sick !! nice job
cstm68 is offline   Reply With Quote
Old 01-12-2007, 06:48 PM   #29
cstm68
cstm68's Avatar
[QUOTE=abadsvt;1981870]So where did you put the new fuse block?[/QUOTE
my fuse block
Old 01-12-2007, 07:02 PM   #30
blazerboy72
I havent done it yet but, my plan for the fuse box is to shave the vents and put the fuse box behind a kick panel where the vent was. if that makes any sense. That way the wires can be run out the side and be concealed inside the upper part of the fender.
blazerboy72 is offline   Reply With Quote
Old 01-12-2007, 08:05 PM   #31
brad2
two more.
74 swb
71 2wd Jimmy
82 2wd Blazer
brad2 is offline   Reply With Quote
Old 01-12-2007, 08:18 PM   #32
mnunn454
mnunn454's Avatar
I missed the shaved rails the 1st time I read through this.
Kewl!!
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 01-12-2007, 08:25 PM   #33
mike nutt
69fatmotor
mike nutt's Avatar
here's a couple of mine . i also used a painless wiring harness.
mike nutt is offline   Reply With Quote
Old 01-12-2007, 09:04 PM   #34
desertrat
desertrat's Avatar
WOW! the detail in that engine compartment is great, I like the painted valve covers
desertrat is offline   Reply With Quote
Old 01-12-2007, 09:27 PM   #35
68cajun
68 C/10
68cajun's Avatar
Here's mine
(2009) GMC Sierra Denali 6.2 AWD
(67 C/10 fleetside SWB)
(2018GMC Yukon Denali) Wifes Car
68cajun is offline   Reply With Quote
Old 01-12-2007, 09:30 PM   #36
onetonk5
Cereal Killer
onetonk5's Avatar
thats some paint by numbers **** he bought from a pawn shop in a chinese neighborhood.
onetonk5 is offline   Reply With Quote
Old 01-12-2007, 10:14 PM   #37
Rokcrln
Rokcrln's Avatar
Originally Posted by brad2 View Post
two more.
So Brad does this mean you are moving forward! When did the fire wall get changed? I like the booster set up
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-12-2007, 10:33 PM   #38
brad2
Kevin
LFD Inc.
Yes I am still hanging in there with it. The second firewall pic is probably at least two years old.
74 swb
71 2wd Jimmy
82 2wd Blazer
Old 01-14-2007, 06:23 PM   #39
ghetto_superman
ghetto_superman's Avatar
heres mine.. nothing different.. BUT note the pimped out paint job on the cab cart and the cab lift jig!
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 01-14-2007, 07:07 PM   #40
piecesparts
Parts and more parts
piecesparts's Avatar
The complete firewall was eliminated and a new panel welded in. The firewall is now 1 1/2" further back that original.
piecesparts is offline   Reply With Quote
Old 01-14-2007, 07:18 PM   #41
boogie67
boogie67's Avatar
Heres mine on my 67.I've never done anything like this before so I learned alot.I also will run my wires out the vent and thru the fenders.I'm using a heater off a forklift it will be behind the glovebox door.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 01-14-2007, 08:07 PM   #42
kafn8d
kafn8d's Avatar
Does anybody have picture with all the holes labeled for what they are used for?
kafn8d is offline   Reply With Quote
Old 01-14-2007, 08:21 PM   #43
kyull67
kyull67's Avatar
look here. for labeled holes
http://67-72chevytrucks.com/vboard/s...d.php?t=178458
kyull67 is offline   Reply With Quote
Old 01-14-2007, 08:42 PM   #44
65-72 chevytoys
65-72 chevytoys's Avatar
Mike did you paint those script valve covers yourself? Those rock and are the best looking ones I have ever seen.
65-72 chevytoys is offline   Reply With Quote
Old 01-15-2007, 06:20 AM   #45
mike nutt
69fatmotor
mike nutt's Avatar
yes, i used a stencel that CLASSIC INDUSTRIES sells , i believe it was a $12.00 dollars. thanks for the comments.
Old 01-15-2007, 12:15 PM   #46
abadsvt
abadsvt's Avatar
I am starting the process of shaving the firewall this week and i have plans to get rid of a lot of stuff of the firewall. I was wondering since i have never done a resto/custom project before i don't want to screw myself by shaving one hole and then realizing that i needed it. I was hoping that someone would be so kind to tell me what holes you can shave and were do you relocate them. I am posting the pic of the firewall with the holes labed so we can use that. For example. In the pic there is a hole that is for the speedometer cable. When you shave it what do you have to do to get it all hooked up. Another example. The trans linkage. How are you going to hook it up if you shave the hole. If i am using a column shift do i need that trans linkage hole? There is a few holes for emergency brake and winshield wipers that i wont need so those are easy. I am planning on using the krugel underdash brakes setup so i can clean that up. I am thinking that you need to have the fuse block connector on the firewall because it has do connect to the fuse block inside the cab. Is there another location?
All you guys with an all new firewall, how do you plan on hooking everything up? Do you jut plan on drilling the holes when you need them?
Thanks alot and i really appreciate it. I just like to know every option before i start something.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 01-15-2007, 12:36 PM   #47
piecesparts
On the pink truck up above, I plan on putting a brake booster back on it, I am putting an A/C bulkhead connector on the passenger side, as well as a throttle cable at the driver's side hump corner and the electrical connection will be eliminated, since I am going to use an aftermarket wiring harness. It will go through the floor board at the corner. The Fuel Injection wiring will go through the floor board just at the corner of the hump. The speedo is going to electric and there will be no cable to worry about.
Old 01-15-2007, 12:44 PM   #48
abadsvt
abadsvt's Avatar
That sounds just like what i am wanting done. What aftermarket wiring are you using? In post 29 of this thread CSMT68 is using a painless wiring setup but it still looks like he will have that connection on the firewall. Or am i missing something? Also that hole in the center of the firewall that is labed wiring. That is no longer going to be a hole right since you are using the aftermarket setup? Thanks for the help i am feeling like i know what holes i am going to eliminate!
Josh
(Project truck)
Old 01-15-2007, 01:06 PM   #49
hvychve
To The Levy
hvychve's Avatar
very cool color orange or gold ???? nice work guys, very nice indeed
hvychve is offline   Reply With Quote
Old 01-15-2007, 05:34 PM   #50
piecesparts
Josh
The word Painless is sometimes a misnomer. Every one I deal with in this area, does not use Painless, unless it is the only thing around. I am looking at a Ron Francis kit and I am NOT going with the replacement wiring that is designed for the chevy trucks. So with that thinking, I will not have to have that big block in the firewall. I am taking my truck to a different level and building it like a streetrod, that way I can do things that the factory design limits me in doing.
