Old 03-01-2007, 05:54 PM   #26
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Thank you Uncle Sammy.......
that spounds like a generic 'old school' replacement engine.
Find out if it has a roller cam. if you still have the part number, you can research it through GM.
Old 03-01-2007, 05:55 PM   #27
arkracing
Weekend Warrior
OK - lots of stuff being thrown around in here about the lack of zinc etc.
WAS THE CAM PROPERLY BROKEN IN?????!!!!!! if you started a new motor with a new cam and let it idle - it was not broken in.
If you are worried about your older motor - run some Shell Rotella Deisel oil in it.
The GM addative shouldn't be used with every oil change.
Crane Cams makes some break-in lube (that supposedly can be used @ every oil change)
http://store.summitracing.com/partde...5&autoview=sku
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-01-2007, 06:04 PM   #28
grebus1
grebus1's Avatar
Knsmodels--you specify small blocks, is there a reason big blocks wouldn't be prone to damage of this type?
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 03-01-2007, 06:28 PM   #29
Longhorn Man
if it's a flat tappet cam, it is at risk.
An improperly broken in cam would only last a hundred miles or so.
Old 03-01-2007, 06:47 PM   #30
68C15
blood type; Retumbo
68C15's Avatar
the Hot Rod article mentions a few options.
1. run a roller cam
2. groove the lifter bore
3. check for sloppy bores allowing the lifter to rock and essentially scrape the cam
4. run beehive springs instead of dual springs
5. avoid bargain priced "no-name" lifters
6. use weaker springs for cam break-in
the rest are for in service engines
7. run a pre-lube all the time
8. use diesel oil (but that stuff will loose the zinc soon) and on an older engine with more blow-by you will end up with detergents in the chamber causing detonation.
9. use racing oil. but this is not good for catalytic converters and may void any warranties.
on a side note some of the lifter manufacturers offer versions with either a small hole on the face or a flat ground into the side to allow extra lube to reach the cam/lifter contact area.
as has been discussed earlier the oil companies are doing what the car makers ask. they (car makers ) have bigger fish to fry than worry about us guys who are bound and determined to keep driving old technology. they are in business to sell NEW cars and trucks. in order to do this they have to meet ever increasingly stringent emissions standards. I do not blame them, but I am disappointed as to this "advancement".
now, where in God's name do I find a roller cam and lifters for a 472 caddy?
68C15 is offline   Reply With Quote
Old 03-01-2007, 07:11 PM   #31
Longhorn Man
I was wondering the same since I hope to rebuild my 500 soon.
Old 03-01-2007, 08:17 PM   #32
knsmodels
I make Models
knsmodels's Avatar
as was said I would think any engine with flat tappet cam and lifters would be at risk (maybe lawnmowers, powerwashers, and any other small engine as well)......I know I will probably go roller with my BB Chevelle when I redo the engine this spring......
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 03-01-2007, 08:32 PM   #33
arkracing
Weekend Warrior
Basically all non-Roller Cams are @ risk here - the average joe who is rebuilding his motor is running a "Hydraulic Lifter" - which are the biggest problem right now.
Only way to slove the problem completely is to run a Roller - but the cost to retrofit
Andy - I have to disagree with the 100mile comment,
From my experience and from everything that I've heard - an improperly broke in cam can last anywhere from 0 miles-20k miles. I've seen plenty of "improperly broke in" cams with more than 100 miles on them - still running ok @ about 5k - the vehicles haven't stuck around long enough to know what the future life will be though. It seems from all the failure stories that I have heard - most of them end up happening around 6k-12k
I'm not trying to be a A$* - but before blaming a cam failure on the lack of Zinc or Phosphate addatives, you really should know if the Cam was properly broken in.
KNS - when you first started the truck (fresh off the rebuild with the new cam) did you let the motor idle or did you have the truck running @ about 1800-2200 RPM?????
-'66 C10 Suburban
Old 03-01-2007, 08:57 PM   #34
Longhorn Man
I'll take your word on that one... never heard of that myself.
Old 03-01-2007, 09:25 PM   #35
knsmodels
I make Models
knsmodels's Avatar
KNS - when you first started the truck (fresh off the rebuild with the new cam) did you let the motor idle or did you have the truck running @ about 1800-2200 RPM?????[/QUOTE]
ark......ran it at 1800-2200 for 20-30 min as soon as it fired up......
Old 03-01-2007, 10:11 PM   #36
ks147j111928
ASE Certified Spoon Operator
ks147j111928's Avatar
Ah, screw it all... I'm gonna stick to 20w50 for my 292. Works good so far! Maybe straight up 30wt if I can get it...
My six is bigger than your eight
67 K20 292 +.060" SM465 NP203 3.73s
86 4Runner, the daily on 31s
85 4Runner, the wheeler on 38s
92 x-cab truggy project for 2017... tons and 42s and V8 power
ks147j111928 is offline   Reply With Quote
Old 03-01-2007, 11:06 PM   #37
Longhorn Man
it's not the weight that matters so much in this discussion... it's the formula.
Old 03-01-2007, 11:51 PM   #38
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Here ya go- but it's gonna hit your wallet hard.
http://www.cadillacperformanceparts....id=5&Itemid=47
http://www.cad500parts.com/catalog/page12.htm
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 03-01-2007, 11:55 PM   #39
Longhorn Man
that's what I was afraid of.
Old 03-02-2007, 08:10 AM   #40
68C15
blood type; Retumbo
68C15's Avatar
$2200 for a cam and I will have to run their rockers?!
maybe I will have to do one of the other options.
where does a guy get Zinc?
Old 03-02-2007, 10:03 AM   #41
killer71
killer71's Avatar
Thanx for the info. ARKRACING!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 03-02-2007, 05:46 PM   #42
arkracing
Weekend Warrior
Well sounds like you properly broke in the cam.
Do you remember what brand it was?
There are a ton of variable that can cause a cam to have a short life.
If you choose not to go roller with the new cam - make sure you lub the heck out of the lobes and the bottom of the lifters with a moly type lube (Grey stuff from Crane is good) - the red "goo" from Comp = not so good
Get a bottle of that Crane "break-in-concentrate"
Use 2 quarts of Shell Rotella 15-40 and 3 of your favorite name brand oil
Break it in for 20-30min.
Change the oil ASAP - put it another bottle of the Crane stuff with your regular Oil.
Run that for approx - 200-300miles.
Change again - Now you can use more of the Crane stuff - or put Rotella in it or whatever.
Run it for about 1k
Then you should be able to switch over to a synthetic - Amsoil or similar.
There is lots of good reading about the subject in the link that I posted on the first page.
-'66 C10 Suburban
Old 03-02-2007, 09:35 PM   #43
knsmodels
I make Models
knsmodels's Avatar
Thanks ark......I am a member chevelles.com as well........dont frequent it as often as this one since my Chevelle is not presently running.....wish I had now I did not build the motor myself so I dont know what lube he used.....I will be replacing the wiped one though (flat tappet again) and will be following the procedure in that post.......
Old 03-03-2007, 07:52 AM   #44
68C15
blood type; Retumbo
68C15's Avatar
I am liking the idea of using some weaker springs for the break-in. maybe the old ones if they aren't broken.
Old 03-05-2007, 02:28 PM   #45
knsmodels
I make Models
knsmodels's Avatar
Just got the new Cam for the truck (Crane) and it seems there is now additional info in with the cam about the Zinc removal mandated by the EPA......it only refers to the "break in" period as being more critical than ever and recommends Shell Rotella T, Chevron Delo 400 and Mobil DELVAC for all flat tappet cam break ins....Just wanted to update as allot of people I talk to about this have been throwing the BS flag so this just kinda confirms what has already been discussed in this thread.....Thanks
