#26 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Where on engine is thermostast sensor?
The reason they had moved the temp sender is that the later heads had a smaller threaded hole that the early model sender won't screw into.
#27 |
dwaite72lnghrn,
My problem is I can't get the "plug" (or whatever the name of it is) out of the driver's side head. I can get the sending unit out of the passenger side, just no where to put it. So, I'm stuck with the fugly line running behind the engine.
1968 C10 Stepside 396 bored .030 TH400 |
#28 |
My 402 head had the plug crack in half in the head it took some work but it did come out. When they finished your heads maybe they thread locked it in(like JB weld or something).
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
#29 |
![]() Join Date: Aug 2005
Anybody see a problem with soldering that connector?
#30 |
Neighborhood Pickle Slinger
You can solder it to but itīs easier to take a connector off when you want to fix something. I think a connector looks better too.
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
