04-16-2007, 10:09 PM | #26 |
A guy with a truck
Re: C-Notched w/ pics
YUMMY. Looks like my truck, only a sh!t-ton nicer...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-16-2007 at 10:09 PM. |
04-16-2007, 11:12 PM | #27 |
Just like a fine wine......keeps getting better with age!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
04-17-2007, 06:41 AM | #28 |
see ten, yes i am still running the inner fenders, Ram-man tires are 255/40/20 front,29540/20 back toyo proxys. thanks, danny
04-17-2007, 06:57 AM | #29 |
Village Idiot....
Very Nice!
04-17-2007, 09:37 AM | #30 |
Commander Taco Bello
based on the wheels/tires you have, how well do you think the following will fit?
Front 20x8.5 wheels with 5.4bs 265/50VR20 Back 20x8.5 wheels with 5.4bs 305/50VR20 i am running RE7 bags on all 4 corners, 2.5" blocks in the back, and 2.5" drop spindles up front. I want to keep my inners and bed wells if possible. |
04-17-2007, 01:05 PM | #31 |
LAIDOUT
Danny, how come you decided to go with the bigger wheels on the front? Didn't like the rake or what?
04-17-2007, 01:26 PM | #32 |
I'M TRUCK CRAZY!
He is running the bigger tire in the back. Front and backs are 20" fronts are 255/40, backs are 295/40
04-17-2007, 01:27 PM | #33 |
I'M TRUCK CRAZY!
Oh yeah, I didn't see any pics of the C-notch
04-17-2007, 04:30 PM | #34 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-17-2007, 07:10 PM | #35 |
iveldesigns,i am not sure on tire/wheel size i am no expert i copied off Keith (in2billet) i am sure someone on the board knows more about this than me.surely someone on this board can answer your question. Danny
04-17-2007, 11:00 PM | #36 | |
oh, and since when is a bagged truck with 2.5" lowering blocks and 2.5" drop spindles considered "little amount of drop" ? |
04-17-2007, 11:59 PM | #37 |
Keep Your Nose Clean
Your truck is one of my favorites. How is it lowered?
04-18-2007, 12:03 AM | #38 |
04-18-2007, 12:07 AM | #39 | |
If your worried about bending a wheel, the magic number is 4" sidewall height. Look over most of OEM's tire sizing & most of the 'sporty' type cars come w/245-45-17's or 275-40-17's (common Mustang/Camaro sizes). Each of those are roughly 4.25" sidewall height. Try & stick to this as your minimum & you'll be ok (I've been driving around on 245/45-18's & 295/40-20's for 4yrs now, daily commuting w/no bent rims).
04-18-2007, 12:12 AM | #40 | |
What brand of tire are you running? Are you running 10's and 8's for your rim width?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-18-2007, 12:14 AM | #41 | |
already have the new adjustable panhard bar, but it sounds like i'll need some spacers and lugs when i order the wheels then. |
04-18-2007, 12:15 AM | #42 | |
8's & 10's
04-18-2007, 02:44 AM | #43 | ||
A guy with a truck
I've got 255/45-20 and 295/45-20 on 8" and 10" wheels on my '72 Blazer(bags,spindles,blocks) and this is the max height I would go. Matter of fact, next time, I'll probably do 40 series sidewalls. On my '70 pickup I'm running 8.5x20 5.4BS all around. 1" spacer in the rear w/ a '71-72 axle(wider than '70) I'm leaning towards a 255/40 and a 275/45...
04-22-2007, 08:17 PM | #44 |
What type of airbag setup do you have in the rear? Is it custom or a bolt in kit? Any pics of setup would be great.
04-25-2007, 01:59 AM | #45 |
Active Member
Danny,
Truck still looks awesome!! What have you done with the old wheels and tires...hint, hint?
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
