06-11-2007, 07:30 PM | #26 |
Re: Project "BLACKOUT"
After we had it blasted it went back to the painter where it was etched and epoxy primed. Once that was finished I took it home to install the lift kit, which I purchased from a local truck shop trying to give the local guy my business. (SPORT TRUCK) This ended up being nothing but a headache. When I ordered this kit I asked for all new hardware so I would not have to deal with weak rusty bolts. But once I started on the install I found that they had given me the wrong U bolts. They told me that my truck was not standard and I would have to buy the correct ones. That didn’t set well with me, because I told them the exact set up I needed. After I had the back ones installed I started on the front, and they seemed a little tight. I called them to find out if these were the right ones, and they told me they were. So I called Skyjacker and gave them the numbers, and was told they were for a blazer in the eighties. Now I’m pissed cause I have to swap them and during that time they moved more than hour away. Needless to say I will never use them anymore.
These pictures are from the first install. |
06-11-2007, 07:39 PM | #27 |
Oh by the way, what is this bracket for?
06-12-2007, 06:10 AM | #28 |
I've read that the factory put it there in case the leaf spring failed somehow it will not go any where. Should be one up front also, I don't think they are on the pass. side, mine doesn't. Can't see how this works, really nice progress BTW. enjoying your thread.... J.
Nice touch on notching the 6x6, wood is a great brake on steel. I use it all the time when I have to move machines around at work.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-12-2007 at 06:16 AM. |
06-12-2007, 06:27 AM | #29 |
I can smell it from here...this project reeks of quality.
Keep the pics coming. Agree with Jaros44, no need for the bracket any more. |
06-12-2007, 06:42 AM | #30 |
Yeah, that scent came thru Philly first, before heading up north, sorta like a 'EastNorther'...
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
06-12-2007, 09:29 AM | #31 |
Its lookin' like a Blazer!
Lookin' awesome. I want a Arizona blazer...lol... Workin' with no rust, I wouldn't know what to do with myself.... Whats the plans for wheels and tires? Some 18s and 40s would look killer.....
06-12-2007, 02:09 PM | #32 |
Guys our AZ Blazers are here, I have one. I think a nice rust free Blazer can be had for like $5-6k, I know that sounds steep, but figure the time, effort and materials to fix one and the $5-6k buy in is actually a steal!! Mine will be up for sale (Well it is now in my siggy) but I need to finish a couple of things. This one is nicer in the unmolested way that some of you easterners drool about. I like it, the lift is a big one, any thoughts on 3/4ton or 1-ton axles to keep the monsters tires on it?
06-12-2007, 03:36 PM | #33 | |
I still don't understand what the thought was behind it. Like you said there isn't one on the pass side. So what good is it if it is only on one side? Also I don't think I had anything in the front of the spring. Notice how tight the spring is against that bracket. Its causing the driver side leaf to bow out. |
06-12-2007, 03:40 PM | #34 |
06-12-2007, 03:54 PM | #35 | |
As for the axles... I took it to a friends shop and had them completly go thru them. Had them put Eaton diffs front & back change the gears to 4:56 and change all bearings, ball joints, tie rod ends, rotors so that once I paint the frame I won't have to foul it up later. (plus the peace of mind) |
06-12-2007, 04:09 PM | #36 |
The front springs are going to hit the frame and/or that bracket if them are not 67-72 style springs.73-87 springs are longer so if you have them,they will hit the frame.The bracket is on the drivers side of the frame and on the front spring hanger there is metal welded to the hanger.Most of the time when a lift kit is added,the metal gets in the way of the spring and the people cut off the metal.
06-12-2007, 05:13 PM | #37 | |
You should have one in the front as well, unless someone took it off
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-12-2007 at 05:14 PM. |
06-14-2007, 10:49 PM | #38 | |
So here are the pictures of them back off the truck to get replaced. Went alot easier the second time. |
06-14-2007, 11:01 PM | #39 |
And here she is loaded up and going back to the painter.
06-19-2007, 08:32 PM | #40 |
PROJECT 7DEUCE
Looks good keep up the good work..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-19-2007, 08:50 PM | #41 |
Can't wait to retire!!
That looks awesome! I can't wait until mine is that close...7 or 8 years I'm thinking.
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
07-07-2007, 12:55 AM | #42 |
I agree, looks real good. Keep up the hard work. Hey chevyman63, 7 or 8 years? You must be dealing with major rust issues also. I can only hope to have mine done that soon. I bought my k5 in Utah, but I don't have any history before I bought it. At least I've started hoarding parts for the build, I've been doing that for some time! Anyway, nice project Jusblaz!
08-12-2007, 11:00 PM | #43 |
Well due to summer projects and vacations I haven't had the time to update the thread, but have enjoyed reading others.
These are the last few pictures that bring the project up to its current state. Here is where we are mocking up the front clip and the top. |
08-13-2007, 11:46 AM | #44 |
Post Whore
Good to see the progress - gonna be sweet!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
08-14-2007, 10:03 PM | #45 |
I've enjoyed your blog. You see I'm working on a build similar to yours. I have decided to have a professional like Kevin build my blazer (Project Traser).
Nice work. Dan
Dan |
08-15-2007, 01:48 PM | #46 | |
In 1969 there was a factory recall on the Blazer. Aparently the eye bolt on the front driver side springpack had busted on several Blazers and caused the driver to loose control of the truck. Years ago on an old site blazer-net.com one of the 1969 Blazer owners had the actual letter from GM and he posted a picture of it..kick myself for not saving it. So the strap on the front of the eye and the stop at the rear are both from that recall/fix GM implemented after the 1969 model. The idea from GM is that the springpack would get 'trapped' inbetween the two and alow the driver to not loose total control of the truck. I seam to recall the eye bolt was increased in size also... Anyway back on topic! Nice build up for sure!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
08-15-2007, 07:00 PM | #47 | |
WTB this ad
08-17-2007, 07:31 PM | #48 |
Ahhh That makes sense, now I understand why in post #37 he said "I should have one in front" I never would have guessed.
Thanks guys! |
09-30-2007, 03:06 PM | #49 |
figured i'd bring this one back to the top...
hey man, what/who's springs are those? did you have to modify the front brackets of the front springs any? nice lookin' btw! matt
1970 C20 now a K30 1986 3+3 Dually |
10-16-2007, 01:57 PM | #50 |
Well "Project Blackout" is back in action, after lightning striking our house back in August and pretty much frying everything electronic in the house. I am now able to move on. Thank God nothing happen to my family, house, or blazer, everything else can be replaced. It just put me back a little on schedule.
To answer you question Matt... The springs are from SkyJacker and didn't have to do anything to the front bracket. |
