01-22-2008, 11:56 AM | #26 |
Re: Gringoloco's Camaro tach install
Thats awesome! Couldnt have come out any nicer than that...
01-22-2008, 11:59 AM | #27 |
will the clock in the camaro cluster fit in the vacum spot on the truck cluster? i am thinking of redoing my dash as well.
01-23-2008, 01:56 AM | #28 | |
A guy with a truck
I've seen it done and it looks pretty good, they're just not the most reliable pieces, so I didn't use it...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-23-2008, 02:19 AM | #29 |
A-Adam A-Adam
Thanks for the post.
Great Job
70 3/4 ton GMC Camper Special |
01-23-2008, 09:32 AM | #30 |
perfect timing. i just found a camaro tach cluster in a 79 z headed to the crusher
common sense isn't so common anymore |
10-12-2010, 11:02 PM | #31 |
Thanks for the post I will be doing this soon.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
04-16-2011, 09:18 PM | #32 |
I picked up a camaro cluster today at a swap meet. I'm going to give it a try soon.
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
02-26-2012, 06:46 PM | #33 |
Gringoloco
I picked up a couple of camaro clusters for the tachs and was wondering about the volt meter. I took it out,, it has 3 studs out the back,, 1 looks like a mount and the other 2 look like connection studs. I took a 9 volt battery with test leads to see what the polarity would be and get nothing across the 2 connection studs but the needle will move when I connect the mount stud and one of the connection studs. Problem is that with a 9 volt battery the gauge heads towards the max peg,, 18 volts. I did not leave the wire connected for fear of frying the gauge. How would a person connect this so it would work in place of the factory amp meter ,,,,, is there a resistor needed ? I will be using your tach install "how to" and would like to use the volt meter and also possibly the temp gauge in my pickup cluster. Thank you very much for the great article !!! Tom |
02-26-2012, 07:27 PM | #34 |
A guy with a truck
No experience with the Camaro voltmeter- I used a cheapie from AutoZone. Sounds like you're on the right track. I wouldn't think you'd need a resistor, but the factory often times does things differently than I would
Good luck!
01-18-2013, 02:33 PM | #35 |
Just read through this, found a cluster for $25 on my local craigslist! Woot!
Jason TEAM C10 HOT ROD POWER TOUR
689 Short Step 68 Step Trucks Sold: 70 GMC, 72 K5 Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins |
01-18-2013, 05:08 PM | #36 |
I changed my mind. Found a factory tach dash. Going to get rid of camaro tach.
01-18-2013, 05:17 PM | #37 |
Still Learning
subscribing
09-13-2015, 04:47 PM | #38 |
I have a 292 do I have to look for a cluster from a 6 cylinder Camaro?
09-09-2016, 10:43 PM | #39 |
Is there a difference between the 6 cylinder tach and the v8 tach ? And if so ,, how do you identify them ?
Thank you ! Tom |
09-09-2016, 11:14 PM | #40 |
10-03-2016, 11:42 PM | #41 |
man now you got me thinking...
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
10-04-2016, 08:55 AM | #42 |
A guy with a truck
Do it! Mine still works great, seven years later
10-04-2016, 11:19 AM | #43 |
What did you do for the plastic lense for the gauges?
10-04-2016, 12:06 PM | #44 |
A guy with a truck
Used the stock one. I think I had to polish off some painted-on lines
10-04-2016, 07:25 PM | #45 |
Pretty damn sweet
Boyd -67' C10 SWB FLEETSIDE LS 5.3 4 speed muncie |
10-04-2016, 07:26 PM | #46 |
what year of Camaro is the tach out of?
10-04-2016, 08:32 PM | #47 |
A guy with a truck
2nd gen, 70-something, though I don't remember the exact years. Get one that looks like the picture on the first page and you should be golden, just make sure it's from a v8 car--the v6 won't read correctly
08-16-2018, 03:15 PM | #48 |
This thread was extremely useful to building my cluster. Thanks for the info,hope others can use it too! I added vacuum and the voltage gauge as well.
Getting the numbers off the lens for the tach was trial and error. I ruined one lens till I found that "Goo-Gone" takes them off without hazing the plastic. Difficult to photograph but it looks like new. |
08-16-2018, 08:52 PM | #49 | |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
09-14-2019, 08:44 AM | #50 |
Good info might need it one day
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
