09-15-2007, 11:45 AM | #26 | |
Luv the Crewcabs
Re: 67 C-30 Dually pickup build.
Thanks, Rick |
09-15-2007, 12:22 PM | #27 |
I have a radical idea!
I measured the overall width of my rear end with all 4 tires and wheels installed, and determined how much of the stepside fender I needed to cover the outside wheel.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
09-23-2007, 08:36 PM | #28 |
I finished mounting them today. Here are a few pics of the mounting brackets I welded on the backside. I used a total of 10 bolts and they pulled the flares up nice and tight to bedside. Now I am going to take them back off, and strip/sandblast and POR-15 the back side. I am trying to decide whether to use seam sealer or fender welting between the flare and the bedside. I'm also going to fill the marker lights on the bedside and the flare since its a '67.
09-23-2007, 09:28 PM | #29 |
Luv the Crewcabs
I like the Way that you Did that, Seem's a Lot Better than welding it up. If you ever were to get any Damage to one of the Fender's you would be able to Replace it...............
Thanks for Sharing, Rick PS, I Think i would go with the welting |
09-23-2007, 09:56 PM | #30 |
I think I am going to go with the welting. There are several different kinds, but the kind I think I'm going to use is extruded urethane and is smooth finished opposed to the textured kind made from vinyl. The urethane type also has barbs on the flap to hold them in place.
09-23-2007, 10:21 PM | #31 |
Luv the Crewcabs
What other Plan's do u Have in Mind for the Truck, Would be Delux if you were to Lower it...........
Rick |
09-23-2007, 11:55 PM | #32 | |
FarmBoy.
looking good!
sometimes i think these trucks should've came dually with extended fenders from the factory, they look right with them. i also like the bracket mounting idea. practical, but still looks really good. i can't wait to see this thing get closer to coming all together and getting to be one color and enjoyed. i'll be watching. keep up the good work! -Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
09-24-2007, 09:09 AM | #33 |
This is very COOL indeed. Keep up the good work.
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT Last edited by manimal; 09-24-2007 at 09:10 AM. |
09-24-2007, 03:05 PM | #34 |
Thanks guys! I got the driver's side finished up today. Here's a few pics of the bracket placement on the back side.
09-24-2007, 03:10 PM | #35 |
Luv the Crewcabs
Are u Also Going to use some Bracing Rod's like the Stepper do or does it seem solid w/out any???
Sorry for all the ???, I just may want to do this some day & Figure it Best to Find out all i can in Helping to Decide whether to do this or noT............. Thanks for Your Patience & Most of all assistance, Rick |
09-24-2007, 04:17 PM | #36 | |
I just got done marking and drilling the holes and mocking up the driver's fender. It measures up the exact as the passenger side, so I guess my fab skills aren't as bad as I thought. The tape line is where I am going to cut out the fleetside bed for wheel clearance like a factory dually pickup is. I still have to take the stepside fender off and do that, but I wanted to make sure everything was concentric from side to side. Here are some more pics. After I get the bedside cutout, I'm going to put the outer wheels back on and see how it looks.
09-24-2007, 07:28 PM | #37 |
Funny you should mention that; I almost had my passenger side fender tore off yesterday on a multilane highway, there was a accident and someone swerved left and almost bought the side of my truck.
09-24-2007, 07:58 PM | #38 |
Just about every dually pickup I've ever owned had at least one cracked or broken wheel flare. Another factor is that I am not confident enough in my welding skills to weld that much on sheet metal without warping it up like a pringle! Your welder knows his stuff!!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 10-05-2007 at 11:02 PM. |
10-05-2007, 10:49 PM | #39 |
VERY INGENIOUS and nice work. I,am just doing a aluminum flat beds for my two c30,s 1. is 133"wb & 1 is 157" wb. all with 6 bt cummins and dana spicer 3053a trans (5 speed o.d. ) 14 bolt rears with 3.21 gears, 19.5 tires.
bob bob
I BELIEVE IN JOHN 3:16 |
10-06-2007, 10:41 AM | #40 |
Thanks! It's coming along pretty good. I'm going to try to the all the tires mounted on it this weekend.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 11-04-2007 at 11:42 PM. |
10-07-2007, 01:54 PM | #41 |
Well, I succeeded in getting the tires mounted on the rear. It looks much better with them, obviously. It has the short, stocky stance that I hoped it would. I think this thing is gonna look tough with some paint on it.
10-07-2007, 03:15 PM | #42 |
Luv the Crewcabs
Looking Good, Some Paint & Simulator's & You Got It.........
Congrat's on A Well Done Job Rick |
10-07-2007, 11:39 PM | #43 |
Looking good. Makes me miss mine more and more. Mine is sitting in the garage getting ready for winter. Had it to a show 3 hours away from home 2 weeks ago and she has been sitting since. Probably going to be sitting for another week as I am going away. Makes me sad. At least seeing you working on yours makes me feel better.
10-08-2007, 09:36 AM | #44 | |
10-08-2007, 09:58 AM | #45 |
Chevy nut
I love to be able to build a dually like that. You have done a great job with the fenders. Cool idea with the pencil. I would have never though of that. Excellent job!
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
10-08-2007, 08:49 PM | #46 |
Nice build thread.It looks like it's coming along nicely.
10-08-2007, 08:55 PM | #47 |
Official Site Guitar Shredder
i love this truck 67 , its one of my favorites for shure although i am liking this height change......
10-08-2007, 08:58 PM | #48 |
That black one looks like a decent truck! I sported mine around this evening for the first time since I got it all mocked up. Got a lotta looks and double takes from a bunch of folks. I took it to a few of my buddie's places and showed to a few guys at couple of shops I deal with. Like a lot of people I told about what I wanted to do, they didn't "get" my vision until they actually saw it. A few even admitted that they didn't think it would look good w/o actually seeing it.
10-08-2007, 09:12 PM | #49 | |
I digitally removed the side markers on the rear, and it cleans up the look a lot!
