Old 09-11-2009, 01:05 AM   #26
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Re: Look what I found
I'm not sure on the carb, but I'm sure if you just went to NAPA and ask for a rebuild kit for a single Rochester for a 235 they could get you one. I got a rebuild kit for my 216 card at NAPA before.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 09-11-2009, 04:07 AM   #27
steve53
steve53's Avatar
yeah i got one from NAPA as well for my 216. the carbs look identical. i'm sure they should be able to hook you up. it wasn't too much dough if i remember right as well.
53 Chevy 3100 1/2 ton
1st Armored Division, OIF Veteran
steve53 is offline   Reply With Quote
Old 09-11-2009, 08:41 AM   #28
JML55
JML55's Avatar
I pick up a new carb kit for my Belair 235 6 cyl on ebay last fall for 10$.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 09-11-2009, 10:05 PM   #29
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Thanks Guys for the info. Here is a LINKY to NAPA's PN for a 235 with a Rochester.
Alan's Classic is offline   Reply With Quote
Old 09-12-2009, 02:17 AM   #30
nickp51chevy
I'm glad to be able to help. Now get that carb rebuilt and start drivin' her again!
Had;
Old 09-13-2009, 02:13 PM   #31
B17CRX
B17CRX's Avatar
Originally Posted by Alan's Classic View Post
Question: Is 1955 the 1st year that offered a V8? If so how was it mounted to the frame? I have a 283 that I could put in it. Will the 3 spd trans bolt up to the V8? I'm sure it will, but if this is the 1st yr of the V8 I'm not sure. If anyone has pics of the V8 installed showing the mounts I would apprieciate it.
The TF V8 mounts bolt to the front of the block and the front x-member and look like these:
-Joel
B17CRX is offline   Reply With Quote
Old 09-13-2009, 06:58 PM   #32
Alan's Classic
I can't wait to get it running, but who knows when that will be. I will post the progress when I do it.
-Joel
Thanks for the info and pic.
Old 09-14-2009, 08:50 PM   #33
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
I really like the 55-59 look. Congrads on a great find.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 09-15-2009, 01:10 PM   #34
OrrieG
OrrieG's Avatar
I could not find stock mounts in 1985 when I put in my SB so I made them out of 1/2" plate. Bolt hole to crossmember use the stock holes. I set the front to back location based on the stock front drive line length and keeping dist. to fire wall clearance. Fan to radiator clearance is not an issue.
OrrieG is offline   Reply With Quote
Old 09-22-2009, 08:33 PM   #35
Alan's Classic
Nice info.
Called NAPA today and they didn't have a kit in stock. He told me to bring the carb in to make sure I get the right kit. Even though there is only one listing for a 235 with a Rochester. He said he has a book that will tell him the info he needs with the numbers off of the carb. I found one number, but it looks like a PN for just the body. Anyway I took it off today. I realized that these trucks aren't meant to be worked on. the fenders are rounded, the tools won't stay put.
This is one of the numbers I found.
I know it's an oil bath breather, but have never messed with them. What's the best thing to do with it? I don't know if I should eliminate it and install a regular air filter or make this work.
While I have yall's attention one other question. This truck still has the generator, but someone had installed a 12 volt battery. It spins over fast, but is there any other damage I might do? I figure it will only get charged with 6 volts. I know a little about electricity, but not enough. In time if I keep it it will get a new harness and convert over to 12 volt. Just want to get it running and driving for right now.
Old 09-22-2009, 09:47 PM   #36
mylow53
mylow53's Avatar
the starter can run on 24 volts if you want. it just won't run very long due to heat. so if it dosent start with in 5 to 10 seconds let her rest a bit. the excess heat will sweat out the sodder on the armiture. other than that i still run a 6 volt light in my cab. man is it bright!! havent burned it out since i switched to 12 volts in 1984.... still works...
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 09-22-2009, 11:02 PM   #37
steve53
steve53's Avatar
maybe your generator has been converted to 12 volt? i heard it isn't too hard of a swap to get a 6v generator to run 12v.
Old 09-23-2009, 08:31 AM   #38
c10addict
c10addict's Avatar
I am subscribed to your 65 thread and see what kind of work you do so of course I am subscribing to this one... As far as the oil bath goes check my build thread on my 54 GMC...page 2 I gutted the oil bath can and put a standard air filter in the can...
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 09-23-2009, 09:33 PM   #39
Alan's Classic
GT
I heard the bulbs are first to go. Apparently thats not always the case.
It probably wouldn't be hard for someone with a clue, unlike myself.
I'll go check out your link, Thanks. I'm glad you subscribed.
Part number for carb didn't exist, so I ordered a kit it will be in tommorrow. Here's the break down. I guess it's the accelerator pump that looks all dried up.
Other than being dirty on the outside the inside was cleaner than I had expected. I can't believe how simple the carb is. I've work on lawnmower carbs more complicated than this one.
Old 09-23-2009, 09:59 PM   #40
OrrieG
OrrieG's Avatar
Those carbs (and 2gc's too) were notorious for the accel. pump drying out, I always carried a spare. If you need them I have a carb off the 58 235 and a 12v generator I have been trying to unload (shipping might be expensive its heavy). Oil bath will work ok if you want the stock look, most were replaced for convenience after they got accidently spilled on the exhaust manifold. Do you have the oil filter option? I have one of those laying around too. My grandfather used TP in his! Alot of them are missing because the VW guys grabbed them for external coolers.
Old 09-23-2009, 10:13 PM   #41
Alan's Classic
Thanks for the headsup on the parts. I'll hold off for right now. How much oil needs to be in the oil bath? And as far as the oil filter, I couldn't tell you. I'll have to go look.
Old 09-23-2009, 10:17 PM   #42
tomlamb
Nice, you and I are in similar boats, I stumbled on a 52 to work on while my 66 is in process...
tomlamb is offline   Reply With Quote
Old 09-23-2009, 10:24 PM   #43
terd ferguson
terd ferguson's Avatar
You asked before about the generator and something about 12 volts earlier. 1955 is the first year for 12 volt. Your truck should be totally 12 volt. I'm sure you figured it out by now, but your carb is likely a Rochester B. Your engine is likely a 235 with the full oil pressure (not babbit). That is, unless the engine has been changed (usually changed for a newer model).
I've followed your '65 too. Nice work, by the way. I'm on this side trying to learn as much as I can. I'm trading my '53 bel air for a '55 pickup next week. I'll probably be selling my '63 to make the '55 nice and low. Keep up the good work.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 09-23-2009, 10:26 PM   #44
Alan's Classic
It would be alot of fun if I had deep pockets. The 55 has been sitting for 2 years now.
Back when I first got the 55 I redid the complete brake system. This is some parts that are missing. I can't remember who emailed me this pic of what he had, but I didn't buy it at the time. I could make the flat bar portion if needed. I was wondering if someone had this complete set up to sale.
Old 09-23-2009, 11:49 PM   #45
tomlamb
I hear that! I was able to get my 52 running (rebuilt the carb, replace the water pump, run new wires for the generator and front lights, etc.) but it will have to wait until I can save up (and recover) after my 66 build...
Old 09-24-2009, 07:29 AM   #46
Old School Kid
Rottenwood Garage Member..Yes!
Old School Kid's Avatar
I've heard that A 12v in a true 6v system will eat it up... A 8v battery I heard is the trick.. Again this is what I have "heard."
Looking forward to seeing it at PO BOYS..Thanks for your help!
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way.
My 65 (SOLD)
http://67-72chevytrucks.com/vboard/s...d.php?t=317013
My 51 (SOLD)
http://67-72chevytrucks.com/vboard/s...80#post3551880
Racetruck III (SOLD)
http://67-72chevytrucks.com/vboard/s...72#post4254972
Rottenwood Garage and Speed Shop.....where everything must be racy!
Gone to dark side for a while...1966 F100 in the stable
Old School Kid is offline   Reply With Quote
Old 09-29-2009, 08:10 PM   #47
Alan's Classic
OK, I admit I don't know anything about an oil filter option. I went and looked for and oil filter and guess what I couldn't find it. Teach me please. I see a blow by tube on the right side. Here is some shots of both sides of the engine.
I missed your post. It was 2 minutes prior to my last post. That's good news about the 12v. Thanks for the comments and info. Good luck on the 55. I wish I had more time to keep up with everything that is going on on the board, but there's not enough minutes in the day.
Your welcome.
Got the carb done today, I hope.
Here is the kit.
Got to bend my first line today and I didn't mess it up yet. I still have the flare to do at the carb. It is a 45 degree flare right?
Old 09-29-2009, 09:48 PM   #48
daverod
SSN 706
daverod's Avatar
Too funny I was going to say since your tinkering with the 55 you'll need to start a thread, and bam you already did. It's also funny that your doing what I was trting to do on my 64 bend a new fuel line. Mine came up about 2" short. I'll have to give it another try. I've got a straight 292 in mine. Thinking about just keeping it. Runs good. Love the looks of the 55. I need another truck.
daverod is offline   Reply With Quote
Old 09-30-2009, 10:48 AM   #49
OrrieG
OrrieG's Avatar
Here is what the filter option looks like. There are two fittings one in the bottom that returns to a port in the pan rail that drains into the pan. The other is high on the side and goes to a port towards the back and farther up on the block that is a pressure feed. There are also aftermarket types that allow use of a spin on filter.
Old 10-12-2009, 10:20 PM   #50
daverod
SSN 706
daverod's Avatar
Now this is the thread that needs a new name. It's just lame. And no new pictures. What is going on. Is the electron broke or just getting refitted with a more powerful lens.
