Old 02-16-2008, 10:41 AM   #26
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: aluminum radiator with fans
Originally Posted by TravisH View Post
I actually bit last week. Got different sized inlet and outlets for $20 too
He doesn't ship USPS though so keep in mind you'll get dinged $35 from UPS for filling out two lines on a customs form
Great that fiqures. Im checking on a be-cool right now so ill do some price checking
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 02-27-2008, 10:24 AM   #27
TravisH
TravisH's Avatar
Came in today, well actually last friday... UPS definately not my shipper of choice
Looks great and the custom size inlet/outlet are going to make finding hoses a lot easier for my ls swap. I hate paying extra to UPS but if you add it to the price of the radiator its still a deal. I also got the relay kit for the fans, its one less thing to make work and I don't have metripak connectors
TravisH is offline   Reply With Quote
Old 02-28-2008, 03:50 AM   #28
71Rat
ran out of money
71Rat's Avatar
these are nice!!! has anyone tried to install this set-up with a bbc with a long pump?
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 02-28-2008, 04:03 AM   #29
Rust Buster
Rust Buster's Avatar
Nice! I'm looking into these too. How was the packaging, and what brand are the fans? SPAL?
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 02-28-2008, 09:33 AM   #30
TravisH
TravisH's Avatar
As far as I know pocoloco71 and I are the only ones on the board with one. I didn't spend a lot of time looking at it last night but it seems identical to the factory rad for a small block (dimension wise)
Packaging was very good, the piece of cardboard its laying on in the pic was wrapped around the radiator, which was secured to it with the two white band straps and the brown paper was stuffed around all four sides, then into a box. You can see in the pics the steam vent fitting is broken, but thats a $2 part and I probably have a couple laying around the shop
Didn't inspect the fans too much but they are listed as SPAL HP fans in his auction
Old 02-28-2008, 10:01 AM   #31
454_72_4X4
454_72_4X4's Avatar
I'm gonna email him and see if he makes these for S10 v8 conversions!
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 02-28-2008, 10:50 AM   #32
jwcardy
man, i cant wait to see you guys install on of these...whats the hold up...haha
-wes
jwcardy is offline   Reply With Quote
Old 02-28-2008, 12:13 PM   #33
TravisH
TravisH's Avatar
I spoke too soon. The core is quite a bit wider than the radiator that came in the truck. Add on the fans and your clearance with a BB long water pump becomes really suspect
Old 02-28-2008, 03:53 PM   #34
pyro883
Those are pretty good lookin, like to get my hand on one of them
pyro883 is offline   Reply With Quote
Old 03-20-2008, 08:59 AM   #35
TravisH
TravisH's Avatar
alright, now for the install:
According to this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=250472, the stock 2 & 3 row radiator is 2.75" wide at the mounts and the 4 row is 3.5". This aluminum radiator is 3.25" wide. I have the smaller brackets so I added 3/4" to them. The rubber mount will need to be squared out and chamfered in some spots.
Took a pic so you can see across the battery box for clearance, if you bb guys want some measurements let me know
Old 03-20-2008, 07:48 PM   #36
bguild
bguild's Avatar
These are cool... I finally got my front clip mostly off last night and I noticed i have a little leak in my radiator.. It might be the hose but need to get it out and see.. also my trans oil cooler is not in the radiator.. With all this in mind I might look at just biting the bullet and getting one of these. I have a small block check with a fan coming off the front..if I got one of these would I keep that fan as well or would I not need it? This might be a stupid question but this is my first real rebuild and I am learning as I go..
bguild is offline   Reply With Quote
Old 03-20-2008, 08:15 PM   #37
rambler
MOVE OVER
rambler's Avatar
looks great! I had bought a 4 row when I hit e deer to replace the mangled one.. still not finished rebuilding it to driving status.
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 03-21-2008, 05:50 PM   #38
TravisH
TravisH's Avatar
bguild if you got this radiator you wouldn't keep the fan on your engine. I've seen aluminum radiators on ebay without the fan setup but never checked to see if they're from the same guy.
Old 03-21-2008, 07:04 PM   #39
bguild
bguild's Avatar
So do you just unbolt the fan and leave the pulley there and let it spin with no fan.. I am defenitly not a motor head but i plan a long way down the road to get rid of the 350 sb I have now for a fuel injected set up.. so If I have to buy a new radiator I would like to just buy the one that will take me into that part of my build.. Trying to plan for the future. (-:
Old 03-22-2008, 04:49 AM   #40
TravisH
TravisH's Avatar
yep, unbolt the fan and you should be good to go. to be honest though I'm sure the stock radiator can cool a fi setup. Hell it'd probably cool mine too but I needed a fan setup and this worked out as a good package deal
Old 03-22-2008, 05:06 AM   #41
Lated
Lated's Avatar
TravisH, can you take a pic of the outlet? I was wondering how the clearance between the outlet and frame compared to what I have now. Thanks, Dave
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 03-23-2008, 09:35 PM   #42
TravisH
TravisH's Avatar
hope this helps
Old 03-23-2008, 11:18 PM   #43
Lated
Lated's Avatar
Exactly what I was looking for, thanks
Old 03-24-2008, 01:07 AM   #44
Sammy
Not sure about dual fans but some folks had 2 inch circles put in the shrouds to allow more air through & around the rad for the hot summer. Anyone in warmer climates run into this?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-10-2008, 04:18 PM   #45
theoneandonly
theoneandonly's Avatar
Two questions. First has anyone put these to the test? They are pretty but do they work? Second is there is enough room for a big block? In the pictures the small block looked awful close or maybe it was just the angle and the was more room inbetween the fans.
SSG Jeffery Ahlheim
586th Network Support Company, 525th BfSB
US Army, FT Bragg, NC
2009 Chevy Silverado LT ext cab 5.3L
If you don't stand behind our troops,
please feel free to stand in front of them.
theoneandonly is offline   Reply With Quote
Old 04-10-2008, 06:55 PM   #46
68Mike
68Mike's Avatar
Here's the Ebay ad...
http://cgi.ebay.com/ebaymotors/aw-cg...m=300196654810
Price: $549+shipping
You are bidding on a new Entropy Radiator aluminum radiator for '67 - '72 GM pickup, Suburban, Blazer and other GM truck applications that use the 28-1/4 inch wide x 19 inch tall core. If you need unadulterated cooling for your ride, THIS IS THE PIECE! Made in the USA. This unit features all aluminum construction, a nocklok forced nitrogen brazed core, two rows of 1.0" cooling tubes, precision TIG welded construction through out, aluminum stacked-plate oil cooler, strong 6061 hose connections, a stacked plate trans cooler with the correct inverted flare transmission fittngs, brass drain cock and overflow connections. If you're going to upgrade to electric fans, you only want to do it once. That's why this unit features the HP paddle plade fans - not the bottom of the barrel Spal fans. Spal makes a wide array of cooling fans - from cheap low powered units to high powered HP units. Don't be fooled into thinking your getting high powered fans just because you see the Spal name! Includes the aluminum shroud with dual 11.5" fans delivering a TRUE 3000 CFM. Together, they pull 40-45 amps (check the current rating on the cheapy fans that claim to pull high CFM). For a plug-and-play wiring harness and thermostat kit, please see my other auctions. This is available with or without the heater hose return connection - please specify at checkout. Buyer pays actual shipping costs and insurance. Visa/MC/Discover, Money orders and cashiers checks accepted.
Mike
Currents:
'74 Cheyenne Super C30 Camper Special 3+3
aka "Sucia30"
Past:
'79 C10 BIG 10 (Sold)
69 CST LWB - Always a "Work in progress" true work truck (stolen)
05 GSXR 750 it has a pretty paint job _wrecked
72 SWB full frame restoration -sold!
71 CST K5 Blazer 4x4 (soon to be 2wd)-project - sold!
C10 Club 2012 Brothers Show Video
http://youtu.be/pUeV2vP7Wpo
68Mike is offline   Reply With Quote
Old 12-28-2008, 09:53 PM   #47
PipsC10
PipsC10's Avatar
still no reports on how well this radiator cools the engines it has been installed on. Anybody have any feedback that has installed one of these? His e-bay feedback is over 1000 with 100% positive feedback. Still want to hear on the performance before buying, thanks.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 12-28-2008, 10:58 PM   #48
67ZL1
Yeah I'm anxiously waiting for some one to report on these. I'm thinking about getting one this week.
67ZL1 is offline   Reply With Quote
Old 12-29-2008, 07:12 PM   #49
Alex Hayley
As am I.
Alex Hayley is offline   Reply With Quote
Old 12-29-2008, 11:35 PM   #50
danman987123
danman987123's Avatar
wow! i just found this thread...should of posted along time ago. tony is a great guy. i have bought lots of aluminum radiators from him for all my cars. 68 chevy 68 camaro 72 chevelle....etc this guy is great i even got one damaged by ups...sent him a pic and he sent me new fans to replace my broken ones. YOU WILL NEVER TALK TO THIS GUY THOUGH HE WILL NOT GIVE A NUMBER TO CONTACT NO OTHER EMAIL THAN EBAY. NO ADDRESS NOTHING. LOOK ON YOUR PACKAGE FROM HIM...HE DOESNT EVEN PUT A RETURN ADDRESS THE ADDRESS ON THE PACKAGE IS THE LOCATION OF THE UPS HE SHIPS FROM. WEIRD I KNOW. BUT GREAT GUY....
danman987123 is offline   Reply With Quote
