Old 12-14-2007, 04:09 PM   #26
toplesskayfiver
K5-2WD=C5
toplesskayfiver's Avatar
Re: my 1970 blazer build=4wd to 2wd
each seat was about $40.00 (each bucket, and the rear bench) and the brackets were 2.00 a piece. so i paid like $150. here's a better pic of the bracket.
toplesskayfiver is offline   Reply With Quote
Old 12-14-2007, 07:22 PM   #27
5150
C10 Club Tennessee
5150's Avatar
those are the same ones that I have for my blazer. I bought my seat from jkade and he cut the four brackets out of the floor for me. Looking forward to seeing what they look like in yours.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 12-15-2007, 11:27 AM   #28
jmuck
jmuck's Avatar
If you go with the 4 link you can get it to go lower b/c you don't have the frame hitting the trailing arms. It isn't any more difficult. I just converted my 4x4 to a 2wd recently. Check out the pics of the 4 link and a pic of my 4x4 to 2x4 blazer.
jmuck is offline   Reply With Quote
Old 12-15-2007, 02:56 PM   #29
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
DID YOU JUST REUSE THE 4X4 SPRING MOUNTS ON THE OUTER LINKS?
NTR72GMC is offline   Reply With Quote
Old 12-15-2007, 07:34 PM   #30
toplesskayfiver
K5-2WD=C5
that looks much harder to do than installing the factory trailing arms? is that a kit already made or is it custom? also i dont think im going to go that low.. yours looks good! a lower profile tire might look even better!!! i already got the trailing arms (thanks fleetsidepaul!), im still looking for my crossmember..
Old 12-15-2007, 08:05 PM   #31
toplesskayfiver
K5-2WD=C5
today i pretty much got my front bucket seats mounted. i still need to fill-n'-drill weld the nut brackets to the bottom of the floor. i had to customize the floor a little to make them work. i had to flatten parts of the dip in the floor pan where the two inner bolts go (on both sides), by cuting a small section and hammering it straight then welding it back together. then i drilled my holes.
Old 12-16-2007, 04:03 AM   #32
jmuck
jmuck's Avatar
Yea if you aren't c-notching the frame it would be easier. The triangulated 4-link is a kit from suicide doors and the crossmember is custom. Suidide doors also has a universal c-notch kit. The outer bars of the 4-link attatch to the stock 4x4 spring mounts. I'm not into rubber band tires I like some rubber. Better ride and better looks. (Just my opinion)
Old 12-17-2007, 08:00 AM   #33
toplesskayfiver
K5-2WD=C5
finally got my seats mounted! whew! took forever, but they came out goood! i used the same brackets that go with the seats, once again my chisel and hammer were a big part here in getting these from the pick a part. i drilled holes and filled them with weld to hold them in place. just like the factory.
Old 12-17-2007, 08:19 AM   #34
gringoloco
A guy with a truck
gringoloco's Avatar
Seats look good. Are you gonna remove the headrests?
Here's a few pics of what I did for the fuel filler on my pickup. The same concept will work for your Blazer. I just used the late model filler and covered it all inside the bed with a Blazer filler cover. To get the neck under the bed, I cut off the stock bend and welded on a piece of pre-bent exhaust tubing from the parts store. Used fuel filler hose to connect to the tank- works like a charm...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-20-2007, 08:19 PM   #35
toplesskayfiver
K5-2WD=C5
thanks! im going to keep the headrests for when the top is on, but take them off whenever the top comes off!
Thanks everyone for the gas filler neck pics, the did help! i wanted to make something 100% water proof to the interior. im really happy with the way it turned out. it took about three full work days thinking plus fabricating. the outside is still not fully welded and the back only has a few tack welds, but i am going to fully weld it still!
Old 12-20-2007, 08:23 PM   #36
toplesskayfiver
K5-2WD=C5
Old 01-06-2008, 08:38 PM   #37
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
any thing new on this?????
Old 01-07-2008, 02:48 AM   #38
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-07-2008, 04:06 PM   #39
toplesskayfiver
K5-2WD=C5
hmm lets see, there sure is, i left off fully welding the gas filler design.
the antenna hole got plugged.
some parts pics
back seat for the most part is done as well, i still want to weld and grind from the bottom of the truck before installing the seat brackets
Old 01-07-2008, 04:12 PM   #40
toplesskayfiver
K5-2WD=C5
my feet are near the front of the truck
Old 01-07-2008, 04:31 PM   #41
jaros44sr
jaros44sr's Avatar
Nice work on the gas filler neck, enjoying your thread. J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-08-2008, 09:46 AM   #42
Rokcrln
Rokcrln's Avatar
That is one very clean and well thought out mod for the rear seat mounts. Depending on how big my rear notch ends up being I might go the same rout.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-08-2008, 10:28 AM   #43
smbrouss70
smbrouss70's Avatar
Kevin
LFD Inc.
Once it's finished, it will look almost factory. Good job!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-08-2008, 11:37 AM   #44
gringoloco
A guy with a truck
gringoloco's Avatar
Me too. Slick!
-Chris
Old 01-09-2008, 04:34 PM   #45
toplesskayfiver
K5-2WD=C5
Thanks, im glad you guys are tuned in!
im a sucker for factory style stuff that looks good and works good
Old 01-10-2008, 09:15 AM   #46
vintagechevy76
That is some very nice work!
vintagechevy76 is offline   Reply With Quote
Old 02-06-2008, 06:57 PM   #47
toplesskayfiver
K5-2WD=C5
dash upgrade!
got the rockers welded up finally. and i used all new body mounts to align everything (doors mostly) before i separate the frame from the body, nothing is perfect yet but PRETTY DARN CLOSE! when it goes back together AGAIN i will make sure everything is PERFECT! the driver door looks like a reproduction but it just covered in overspray im using 100 percent gm parts
Old 02-08-2008, 08:09 AM   #48
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
Cool Looking Good!!!!!
Old 02-08-2008, 03:55 PM   #49
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
NIce Work where in CA are you I am in the IE also
Angelse68cal is offline   Reply With Quote
Old 02-08-2008, 11:57 PM   #50
Yukon Jack
Post Whore
Yukon Jack's Avatar
Really coming together nicely. Not sure if you mentioned it before, what color will it be?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
