12-25-2007, 06:03 AM | #26 | |
Old member
Re: LMC Heavy Duty Headlight Harness
Longhorn Man,
12-25-2007, 06:58 AM | #27 |
its all about the +6 inches
naaa, they wanna remember me.
Am I full of it or what? |
12-25-2007, 07:20 AM | #28 | |
Old member
Longhorn Man,
12-25-2007, 11:54 AM | #29 |
12-26-2007, 07:11 PM | #30 |
Just hang'n around
You guys are too funny. And I thought the quad lighted trucks were just prototypes for the double lamped ones. Learn something new every day.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. |
12-27-2007, 03:29 AM | #31 |
Old member
Has anyone got any pictures of the Blue tint bulbs installed and on?
01-05-2008, 10:30 AM | #32 |
Between Trucks...
Bringing this one back from the dead. I just got the LMC Heavy Duty Headlight Harness. Works great. Plug and Play, didn't have to cut any wires on the stock harness. Which is cool , cause if the relays go out you could just plug the lights back in to the stock harness. Product was made in Taiwan. No biggy, seems like most everything is made overseas nowadays. Instructions were easy to follow, took about a half hour to install. With this set up the relays mount on the passenger side. I'm going to be putting in a remote F*rd solenoid, so I mounted the relays to the inner fender. Very clean looking installed. It's daytime here now, but the headlights look brighter, and my dashlights seem brighter as well. $30 well spent...
Beat it to fit, Paint it to match... Last edited by Sinister; 01-05-2008 at 10:56 AM. |
01-05-2008, 12:58 PM | #33 |
Old member
This is my setup I did the weekend of Christmas and it only cost $13.00.
I ran a hot wire from battery to the driver's side and split it off to both relay's. I ran a ground off both relay's and the feed wire came from the dimmer switch wires. Then added a little to the headlight plug to plug into relay. It's all mounted to the radiator support under my cold air intake. Noticed how I offset the relay's this is so I know which is which...High or Low.
01-08-2008, 08:36 PM | #34 |
I have a 65 chevy PU and the lights were dim. I installed the LMC harness and the Euro halogen headlights and they worked perfect and were exceptionally brighter. I also installed the same Euro halogen headlights in my 71 PU without the harness, and there were just as bright as the 65 with the heavy duty harness. The 65 obviously had a voltage drop in the wiring from the headlight switch to the lights making them dimmer. The 71 didn't have that problem. If your lights are dim, you will like the harness. Mine did not appear cheap and worked perfect as I said.
