08-25-2008, 01:02 AM | #26 |
Resident of Here
Re: Addicted to Chevrolets ( bought a C30 )
Awesome! Cant wait to see it painted! Eventually I'll do what you are doing(swap C/K-30).
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
08-25-2008, 02:00 AM | #27 |
I have a radical idea!
Man Oh man!!! - that bad boy looks tough with those Mud Terrains!!!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
08-25-2008, 07:41 AM | #28 |
Love the tires... I forgot about this build... keep the pics rolling...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-25-2008, 09:33 AM | #29 |
That does look awesome. Can't wait to see some more progress.
It looks like the frame was made for these years.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 08-25-2008 at 09:33 AM. |
08-25-2008, 09:40 AM | #30 |
Why lift it?
It looks like the tires clear in the front... If you need to lift it, do a shackle flip, as you want the weight rating the stock springs support, right? Having spent a little over 300 per side for my rear springs in my tow rig project, I would stay stock |
08-25-2008, 09:57 AM | #31 |
high-Tech Red Neck
I am liking what your doing there, going to be a sharp truck
"He used to be a pretty nice feller, now he's a welder!" |
01-12-2009, 10:32 PM | #32 |
I seems like I haven't had the time to update this thread in ages. I have been working on the K30 almost every day, and have made some major progress. I bought a RCI 20 gallon aluminum fuel cell, with sending unit. I also picked up a Msd high pressure electric fuel pump, as well as new fittings and hose. I have it mounted between the frame rails in front of the rear axle. I am not sure if I am going to leave it there or not. But for now, at least I can drive the truck around. Next we mounted the flat deck, which came on my 1970 C/30. It is about a foot or two too short for the newer frame, so I will extend it. Other than that it went on easy, it is even the right height when the channel is sitting on the frame.
1971 Chevy Crewcab cummins diesel 4x4 1970 Chevelle 1967 Chevy c/30 |
01-12-2009, 10:52 PM | #33 |
Next was suspension. I couldn't find any company that made a lift kit for older Chevy 1 ton duallys. In fact, the only company I could find that even made a 1 ton early chevy solid axle lift was Super Lift. I couldn't find much information on using a srw lift on a dually, so my local dealer contacted Super Lift. The only thing that won't work for a dually was there supplied rear u bolts, since duallys have a larger spring pack. So I went with there srw kit, it came with new front lift springs, with 6 leaves! New shocks all the way around, new u bolts, steering block, bushings, and rear blocks. I didn't want to go with blocks, but I don't think I will have to worry about axle wrap with 15 springs on each side. I can always install a shackle flip later on, if I don't like the blocks. The lift went on fairly easy, except for rusted solid rear u bolts, which we had to cut off. I really like how it looks with the lift, and will give me more ground clearance which I wanted.
1971 Chevy Crewcab cummins diesel 4x4 1970 Chevelle 1967 Chevy c/30 Last edited by JustinR; 01-12-2009 at 10:55 PM. |
01-12-2009, 11:02 PM | #34 |
Here are the pictures. One before, and the rest after the lift!
01-12-2009, 11:24 PM | #35 |
Resident of Here
Green Sex Machine.
That thing is HOT! What did you do with the old frame?
01-12-2009, 11:45 PM | #36 |
Haha thanks man. I don't have any plans for the old frame. It is just sitting out back. I haven't decided what color to paint it yet, just working on the body work. So I am open to opinions for paint color!
01-13-2009, 07:49 PM | #37 |
Resident of Here
Goo green.
01-27-2009, 07:04 PM | #38 |
Pretty much done all the rust repair. I bought a little Lincoln Electric 180C mig and went to work. This was my first time doing any type of welding or bodywork. So considering it is a work truck, I am fairly happy with how it turned out. Cab needed all 4 cab supports, left and right front cab floor, left and right rear cab floor, cab corners, inner rockers and outer rockers.
01-27-2009, 07:11 PM | #39 |
Some more pictures
01-27-2009, 07:13 PM | #40 |
Last batch.
01-27-2009, 09:49 PM | #41 |
Resident of Here
Lookin sweet! Will you use the same welder for the bed? I wonder if it will be hefty enough. Man, this and 67_C-30's build are the best on the forum!
01-29-2009, 01:28 PM | #42 |
Nice build! I am really liking the look.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
01-29-2009, 11:07 PM | #43 |
Formerly- 1972SuperCheyenne
Looks great. I wish I had that 3+3 cab
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
01-30-2009, 02:12 PM | #44 |
Got the floor and dash all sanded down and in primer. Filled the fuel neck hole in the cab, and did a little body filler on the cab corners and where I filled the fuel hole. Still having a hard time deciding what color I am going to paint it, I have gone back and forth so many times already it seems. Joe, your 68 C/30 was the truck that first got me thinking about a one ton. Thats an awesome looking truck you got! I love the black and chrome, which has now swayed me to go for a dark color. I am thinking of painting it the same color as my very first truck. '71 k10 in dark blue. But on this truck I think I would like to paint the roof white, especially since I haven't got a/c. Here are some pictures of the interior in primer, and I'll post a pic of my first truck too.
Next I need to lengthen the flat deck, I am planning on added about 16'' to the front, and angle it in towards the cab. So the very front of the deck will be about the same width as the cab. Hopefully that will work so I don't hook the corners of my flat deck when I'm in the trees. Thirdstreettito, yes I am planning on using the same welder. I think it should be fine, according to the chart on the welder it will be able to handle the thicker metal no problem. Thanks for the comments!
02-09-2009, 02:02 PM | #45 |
I remember seeing a picture of a white blazer at some point that they cut the bottoms off the front fenders and built the bumper around the sides. I thought that would be a good option, since my bumper didn't fit really well with the 67-72 fenders. The bumper is made of 1/2'' plate in the bottom, and 3/16'' for everything else. After welding 3/16 plate on the sides I think that is about the limit for my welder, but it turned out good!! Heres the pics.
02-09-2009, 09:08 PM | #46 |
nice build that bumper looks beefy and i like what you did with the sides of it
02-09-2009, 09:24 PM | #47 |
Eat My Rust
So, getting ready for the eventual apocalypse?
Gotta say, that's a real zombie killer right there |
02-09-2009, 09:27 PM | #48 |
Resident of Here
I really think you should repaint it the same green. This truck looks better all the time.
02-09-2009, 10:01 PM | #49 | |
Your 71 is a sharp lookin' truck too!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-19-2009, 01:19 PM | #50 |
Thanks for all the good comments!! The truck is really coming along good, I have been working on it almost everyday and have got a ton of stuff done. Since I updated the forum last, I got the entire body sanded down, and primed. It turned out pretty good, but there were some small scratches that I didn't see until I sprayed primer. But considering what I am going to be using this truck for, it isn't a huge deal to me. I also painted the inside of the front fenders, front of the cab, door jams, inside of the doors, roof, and inside of the doors. Then on the floor I sprayed rocker guard all the way up behind the dash, on the kick panels, floor, and the back of the cab on the inside. This turned out looking really good, and it is supposed to help with noise, and also will keep any moisture out. On top of the rocker guard I put sound deadening all the way up the firewall, and on the floor. I cut sections to fit the floor around the high spots, and then did one full section covering the whole floor. I used 3M spray adhesive for the deadening which worked really good! I hope between the rocker guard and sound deadening it should be fairly quiet inside. I found some 2005 Silverado bucket seats with the fold down middle seat for sale locally. Which were really straightforward to mount, and seem like the perfect thing. I still have plenty of headroom. I even had a friend who is 6' 2" try sitting in them, and he didn't have any problems either. I used 3/16 plate to reinforce the underside, since the seats have integrated seat belts. I really like how they fit, and considering I bought them for less than it would have been to get my bench recovered I am really happy!! Here are some pictures!
