Old 10-21-2008, 11:39 PM   #26
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Re: my 80 build
flamingbig10, you said you did your steering box twice? How hard is it to replace? I have a nasty leak in mine and was thinking of getting a new one.
-- Will
killthewabbit is offline   Reply With Quote
Old 10-21-2008, 11:57 PM   #27
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
its not to bad, I did it by myself, it was I little tricky since its about
50ibs, make sure you unbolt the box from the frame last, it will make it a lot easier, the tools you will need is a floor jack, jack stands, line wrenches, socket wrench, wrenches, pitman arm fork, hamer and a crescent wrench
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-22-2008, 01:10 AM   #28
Fer79
Fer79's Avatar
Re: my 80 build
very nice, great job...
Fer79 is offline   Reply With Quote
Old 10-22-2008, 01:24 AM   #29
flamingbig10
6.0 powered square
Re: my 80 build
thanks fer, hows your truck coming along
Aaron
Old 10-22-2008, 09:54 AM   #30
killthewabbit
Re: my 80 build
Cool, thanks
-- Will
Old 10-23-2008, 01:45 AM   #31
flamingbig10
6.0 powered square
Re: my 80 build
got the door panels held by ducktape for now
Aaron
Old 11-10-2008, 11:39 PM   #32
flamingbig10
6.0 powered square
Re: my 80 build
I haven't worked on my door panels but I did order a new wiring harness http://cgi.ebay.com/ebaymotors/KW22E...1%7C240%3A1318 i'm thinking about getting a mojave heater
Aaron
Old 11-22-2008, 02:05 AM   #33
flamingbig10
6.0 powered square
Re: my 80 build
today I removed the factory a/c and heater box, wiper motor, all of the wiring harnes, and most of the interior. I will be installing a new ez2 wire 22 circuit wiring harness, a new summit mojave heater, shaving the fire wall, adding heat shield, also i'm will be getting my seat and door panels coverd with blue and white leather, and also a tonneau cover
this is almost how the old wiring harness looked under the dash
new 22 circuit harness
Aaron
Old 11-22-2008, 02:14 AM   #34
SCOTI
SCOTI's Avatar
Re: my 80 build
Originally Posted by flamingbig10 View Post
today I removed the factory a/c and heater box. I will be installing..... a new summit mojave heater.....
Dude...... You need a/c more than that heater around here.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-22-2008, 02:25 AM   #35
flamingbig10
6.0 powered square
Re: my 80 build
I know but I didn't have $$$$ for a vintage air setup and I don't like the clutter of the factory a/c under the hood
Aaron
Old 11-22-2008, 10:28 AM   #36
Cherub
Cherub's Avatar
Re: my 80 build
wow looking real good there man
Cherub is offline   Reply With Quote
Old 11-22-2008, 12:35 PM   #37
flamingbig10
6.0 powered square
Re: my 80 build
thanks cherub
Aaron
Old 12-04-2008, 10:35 PM   #38
flamingbig10
6.0 powered square
Re: my 80 build
today I finished up the patch panels and sprayed under coating on the floor
Aaron
Old 12-04-2008, 10:46 PM   #39
vern350
like a rock
vern350's Avatar
Re: my 80 build
Its going to look alot better when its all cleaned up. Great progress.
vern350 is offline   Reply With Quote
Old 12-08-2008, 11:53 AM   #40
flamingbig10
6.0 powered square
Re: my 80 build
thanks vern
Aaron
Old 12-08-2008, 12:57 PM   #41
boatpuller
boatpuller's Avatar
Re: my 80 build
look's good.i like the door panel's.nice truck.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 12-09-2008, 01:09 AM   #42
flamingbig10
6.0 powered square
Re: my 80 build
thanks boatpuller
Aaron
Old 12-11-2008, 12:27 AM   #43
flamingbig10
6.0 powered square
Re: my 80 build
today I finished routing the wires
Aaron
Old 12-11-2008, 12:51 AM   #44
flamingbig10
6.0 powered square
Re: my 80 build
wile I'm rewiring i'm going to add this to the hoses http://store.summitracing.com/partde...art=SUM-350001, and i'm also going to shortin the fuel line and re paint the block and try to find factory none a/c and smog pump pulley's, I would like a serpentine belt system, but when I really don't have a job right now
Aaron
Old 01-05-2009, 02:16 AM   #45
flamingbig10
6.0 powered square
Re: my 80 build
On new years Eve I finally figured out how the wires on my ez2 wire 22 circuit harness hooks up to the starter, Alternator, and H.E.I, It took me over a Month to figure it out, and if understood the instruction it would only took me a couple hours from taking the harness out of the box it came in, and wile I was rewiring I decided to Paint all the engine brackets but when it was time to put the brackets back on the alternator I couldn't find them, so I went to autozone and picked up a chrome alternator bracket with hard wear, so installed the bracket checked the fluids, and she fired right up, no problems, the first time my truck has started since before Thanksgiving and planned on driving around the block but I clean up for a New years party, and yesterday I drove it around the street with only thing working and wired up the wires that go to motor, ignition and the radio, also no seats just siting on the floor, I took my seats to upholster almost a month ago and guy just got the fabric yesterday, but I guess it's ago sine it not going cost a thing since I help the guy build a foundation for is shop, that going to that going to howse his 46 ford.
since I'm re wring my truck I decided to get new headlight plugs, parking light plugs, taillight plugs, euro turn signals from lmc, headlight switch, and dimmer switch
the battery will be in the bed once I get longer battery cable, and firewall will be finished after the wiring is done
between cab and inner fender if you close you can see the spedo cable and headlight, taillight, and motor wire
Aaron
Old 01-08-2009, 12:43 AM   #46
flamingbig10
6.0 powered square
Re: my 80 build
Today I wired up the head and tail lights to the switch and they came on, hi and low,checked the wires that go to gauge cluster and they all work, now I have figure out why the parking lights aren't coming on, with switch at the parking light position
Aaron
Old 01-08-2009, 01:54 PM   #47
87c10slammer
truck addict
Re: my 80 build
looks good man.. i have the same wiring nightmare going on in my truck but im hidding everything so its a little more involved... i ordered a painless 20 circut kit and so far im in abou tthe same stages as you are but i am not running heat or a/c and i have air ride to wire up also... i put my battery in my bed so it only sticks up a little bit... the air compressor hides it pretty well though...
but the truck looks great man.. nice job on the paint
87c10slammer is offline   Reply With Quote
Old 01-08-2009, 04:44 PM   #48
flamingbig10
6.0 powered square
Re: my 80 build
thanks slammer, some of the hidding was a chore, routing the wires that go to the front truck, since I routed them through the fender, I also need to move the hood release handle maybe behind the bumper
Aaron
Old 01-09-2009, 12:25 AM   #49
flamingbig10
6.0 powered square
Re: my 80 build
Today I got the parking lights to work just wired the switch wrong, I ordered a few parts for my truck from summit
http://store.summitracing.com/partde...0&autoview=sku
http://store.summitracing.com/partde...5&autoview=sku
http://store.summitracing.com/partde...w=1&N=700+150+
Aaron
Old 01-09-2009, 12:33 AM   #50
1984 swb chevy
1984 swb chevy's Avatar
Re: my 80 build
looks good. how much drop will you have in the front with the new springs
1984 swb chevy is offline   Reply With Quote
