Old 07-18-2008, 05:46 PM   #26
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Pics and specs of lifted blazers
Originally Posted by bigbadchev72 View Post
Care to explain?
The first time I saw the first picture that you have posted it threw me since it needs to be rotated - I thought it was the front mount rather than the rear shackle and I was really scratching my head and thinking, how in the world could he be using a shackle mount up front - maybe that is what he was concerned about
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-04-2009, 05:20 PM   #27
csa daddy
csa daddy's Avatar
i think it was probly the front blocks that is dangerous to drive on the street
csa daddy is offline   Reply With Quote
Old 08-04-2009, 06:30 PM   #28
bigbadchev72
People know me
bigbadchev72's Avatar
They are tied into the spring pack and are very widely used. Its called a "zerorate" it will let you adjust the centering of your axle.
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
I have since then reworked the suspension in the front and it is alot more trail friendly since i got better shackle angles, it rides alot nicer as well. Plus i got a great place to mount some d-rings. I got a piece of 1/4wall 2x6 square tubing cross tied between the frame rails and my zero rates installed straight up then centered the axle
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 08-04-2009, 09:45 PM   #29
csa daddy
csa daddy's Avatar
yeah ive seen zero rate blocks before its just from the pic it looked like a 2inch block was all do you need them to put the newer springs on the front of the blazer or what
Old 08-05-2009, 12:28 AM   #30
bigbadchev72
People know me
I had mine for the extra lift from my old 84 the springs originally came off of. The wheel was about an 1.5" back towards the firewall so if you wanted the wheel centered in the opening then yes you do need them
Old 08-05-2009, 05:55 AM   #31
vtblazer
vtblazer's Avatar
Originally Posted by 1972CST View Post
VT, I could not get that link to work?
Try it now, sorry for the delay.
http://67-72chevytrucks.com/vboard/s...archid=1285837
As posted earlier, 6" Alcans w/42's.
vtblazer is offline   Reply With Quote
Old 08-05-2009, 09:25 AM   #32
Burt4x4
Burt4x4's Avatar
I have 4"Rancho Front springs, Rear is 5.5" SuperLift springs & 3"bodylift. Tires are 37"(36.8") H1-16.5"wheels & D60/14FF
The orange Blazer has 6"springs front and rear, I think..
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-05-2009, 09:35 AM   #33
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
mine:
front:8" perch,beefed up 52" long 10" lift springs,dropped front hanger,7" rear shackle.
rear:12" perch,beefed up 62" long 8" lift springs,dropped front hanger,shackle flip and 6" shackles.
running :
67x34x25 goodyear terra grip tires.
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
Old 08-05-2009, 10:58 AM   #34
smokekiki
Mike
smokekiki's Avatar
Why is your dog praying?
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-05-2009, 11:54 AM   #35
tallhoedude
cause my truck scares him.LOL
idk hadnt even noticed that,hes a strange dog anyhow,hard tellin wtf hes doin.
MY BUILD THREAD:
Old 08-05-2009, 12:21 PM   #36
csa daddy
csa daddy's Avatar
he is just giving praise to your most awsome k5 haha i love that truck i know i have said it before but damn i love that k5
Old 08-06-2009, 01:32 PM   #37
ssean
Talking Re: Pics and specs of lifted blazers
Parts are as follows; Axles Dana 60 & 14 bolt in rear. Bilstein 5150 shocks all corners ford towers @ front, ORD's shackle reversal w/ Tuff Country softride 4" in back and 52" Alcan leaf springs and axle moved forward 2” in front (total of about 7"). Cross over steering and all components by OTT and a new 2wd steering gear. Toyo 37"x13"x 20" ,HighAngle driveline CV w/ 1350's and pinion e-brake at the rear, front is 1350 squared cv. NP 205 twin sticked 32 spline mated to TH400 stuck to 383 stroker.
ssean is offline   Reply With Quote
Old 09-14-2009, 11:18 AM   #38
70 beast
Certified Hobbiest
70 beast's Avatar
not a blazer but here are the spec on my 71 jimmy
6" all spring lift/ trussed dana44/ Eaton h052/ 4:56/ 350/sm465/205
still under construction
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 09-14-2009, 04:10 PM   #39
vtblazer
vtblazer's Avatar
Tire size?
Any idea as to why it sits so much lower in the rear?
Are you running cross over steering with the 6" lift?
Old 09-14-2009, 07:29 PM   #40
cleszkie
cleszkie's Avatar
6-inch Superlift (springs all four corners), CV rear drive shaft, drop drag link, 35 x 12.50 x 16.5 Parnelli Jones Dirt Gripz (measure a true 35 inches).
cleszkie is offline   Reply With Quote
Old 09-14-2009, 10:26 PM   #41
70 beast
Certified Hobbiest
70 beast's Avatar
for now im running a 38"
the springs came off my pops work truck so the rear got used alot. he went down to a 4" so i snatched up the 6"
no crossover but it will be in the future.
my jimmy build
Old 07-07-2010, 10:47 PM   #42
CussinDusty
CussinDusty's Avatar
87 K5
4" lift,all suspension,no body
36x12.50-17LT TSL SX
http://i957.photobucket.com/albums/a...sty/sig2-3.jpg
87' Blazer
36"TSL SX,
Bedline'd Interior,and bumpers
Heddman Long Tubes,True Dual Flowmaster 40's
4:11's locked
Build Thread-
http://www.fullsizechevy.com/showthr...r-Build-Thread
CussinDusty is offline   Reply With Quote
Old 07-29-2011, 11:36 PM   #43
Bull72
Bull72's Avatar
4" suspension with 35x12.5 tires on 8" wide rallys
The pic in the middle is the same truck before painting the body and the rally's. I think the unpainted rally's with beauty rings actually look bigger, but it is the same setup.
Thank you god for all your blessings!
My mini build (I had a great starting point)
http://67-72chevytrucks.com/vboard/s...d.php?t=440743
Bull72 is offline   Reply With Quote
Old 07-30-2011, 07:59 PM   #44
wildearp
wildearp's Avatar
Sold as a 3" lift, but actually added close to 5" in the front. 33x12.50x15 tires. Well, 5' with a small block. Probably 4" with the BBC that is in the photo.
wildearp is offline   Reply With Quote
Old 08-01-2011, 08:48 PM   #45
tples k5
[IMG][/IMG]
10 inch ralley wheels made and put on 32x11.50 tires. when I bought the blazer it was advertised having a 4 inch Rancho lift but I think it's more like a 2 1/2 or 3 inch lift
tples k5 is offline   Reply With Quote
Old 08-18-2011, 03:46 AM   #46
ol' yeller 72
ol' yeller 72's Avatar
heres mine sitting on a 7" lift and 33s
'70 K/5 350/TH350/NP205
ol' yeller 72 is offline   Reply With Quote
Old 08-18-2011, 04:02 AM   #47
mcmlxix
Collector of Projects
mcmlxix's Avatar
You got a saggy butt.... well the truck does anyway ....
Rich
1972 K5 Blazer CST Click HERE
Old 08-18-2011, 04:09 AM   #48
ol' yeller 72
haha yeah i did that on purpose so my heavy duty bumper will level it out lol
Old 08-18-2011, 04:30 AM   #49
mcmlxix
mcmlxix's Avatar
aaahhhh.... much better .. did you cut the front fenders? do you have pics? I was thinking about doing this to mine as well....
Rich
Old 08-18-2011, 04:44 AM   #50
ol' yeller 72
yeah i cut my fenders. i took painters tape and lined it up with the bottom of the grill and follow it with the body lines, then i took off the grill and used a die grinder with a cut off wheel to trim the fender cups off. its easier to take the grill off so you can make a clean straight cut on the back side of the fender.
