07-15-2008, 04:29 PM | #26 |
Re: Shop Truck
Dodge truck.I got it off one of the RumbleBee trucks.
07-15-2008, 05:38 PM | #27 |
Re: Shop Truck
wow, that is a very slick way to run the wires, i have thought of a couple of ways, but that is one i havent seen or thought about. very clean work on the wiring. and nice truck.
do you have any pics the the wiring harness under the dash? |
07-16-2008, 01:44 AM | #28 |
Re: Shop Truck
I will try to get pics tom.I made a plate to mount the fuse box to,then screwed the plate to the rib that runs down the left side of the column.
07-16-2008, 10:58 AM | #29 |
Re: Shop Truck
man, that is a nice setup you got going there
09-21-2008, 12:45 AM | #30 |
Resident of Here
Re: Shop Truck
Any updates?
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
09-21-2008, 12:58 AM | #31 |
Re: Shop Truck
YOU HAVE 14 FIRST GEN CAMAROS ?!!!
yer my idol
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
09-21-2008, 01:13 PM | #32 |
Re: Shop Truck
I like the fastback in the background too.....Nice truck
http://67-72chevytrucks.com/vboard/s...d.php?t=245203 |
09-21-2008, 07:54 PM | #33 |
Re: Shop Truck
All most done.Carpet and a few other inteior parts.Made a cople road trips with it over the weekend.Probably a cople hundred miles all together.
09-21-2008, 07:56 PM | #34 |
Re: Shop Truck
few more
09-21-2008, 07:58 PM | #35 |
Re: Shop Truck
couple more
09-21-2008, 08:09 PM | #36 |
69fatmotor
Re: Shop Truck
that's one sweet truck!!!!!
09-21-2008, 08:19 PM | #37 |
67-72 parts collector,…
Re: Shop Truck
Very NICE ride. Is this your truck or a customer's truck? I see you are running the new Billet Specialties Apex-G wheels. I like your "attention to detail" throughout the truck.
09-21-2008, 08:21 PM | #38 |
Re: Shop Truck
nice ride
09-21-2008, 09:30 PM | #39 |
Re: Shop Truck
Thanks guys.Truck belongs to us.Started out to be a low budget shop truck.Things kinda got out of hand for what we intended.Still thinking about a spray in bedliner and some tie downs in the floor corners.
09-21-2008, 09:37 PM | #40 |
Re: Shop Truck
Nice! do you sell the camaros or restore for customers?
09-21-2008, 09:42 PM | #41 |
Re: Shop Truck
Nice Truck!!!! how do you like that fatmat? does it cut down the noise good?
09-21-2008, 10:10 PM | #42 |
Re: Shop Truck
Most of the camaro are ours.A couple are customers.
The Fat Mat works good unless you have a header close to the firewall.I have one tube that is about an inch away from the firewall and the mat was melting.I got up this morning pulled the header and wrapped it with header wrap.Double wrapped it where it was close to the firewall.It still was getting to hot.Ordering some center dumps in the morning. |
09-23-2008, 08:24 AM | #43 |
Tot Roddin'
Re: Shop Truck
That shop truck turned out great! Nice work!
Any more shots of how you ran the wiring to make it a little more clean?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
09-23-2008, 10:50 AM | #44 |
Re: Shop Truck
All of the wiring was ran through the lower firewall,then around the lip above the tranny to the starte and msd.The wires for the headlights were ran through the frame to radiator support and across it on the bottom to the other side.
I will try to get pics. |
09-23-2008, 12:11 PM | #45 |
Re: Shop Truck
Very nice truck.Is that the factory seat?
09-23-2008, 01:57 PM | #46 |
Re: Shop Truck
Factory seat.Just showed her how I wanted it stitched.
09-23-2008, 03:07 PM | #47 |
Re: Shop Truck
Beautiful job! Where is that billet dash from and was it fairly easy to install the after market gauges?
09-23-2008, 03:59 PM | #48 |
Re: Shop Truck
Where is the radio?
09-23-2008, 07:06 PM | #49 |
Re: Shop Truck
The gauge cluster is NO-LIMIT.I did'nt have problem with install.Little trimmin around the top because you have to change the location of the headlight and wiper switch.
Radio,let's see.I have a supertuner3 350-290 HP,with 2 1/2 inch flowmaster woofers.LOL |
10-05-2008, 10:06 AM | #50 |
PROJECT 7DEUCE
Re: Shop Truck
Beauiful truck congrats..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
