08-25-2008, 08:15 AM | #26 |
soon to be bagged64sub
Re: Bagged '69 Suburban
Hopefully he will.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
09-03-2008, 12:59 PM | #27 |
Glen
Did you use the original trailing arms when you bagged that Suburban? If not, could someone notch the frame and run the stock arms? Of course I would strengthen the originals.
09-03-2008, 01:53 PM | #28 |
YeaI used stock arms. But the bags are not mounted on the arms they are on the rearend.
09-03-2008, 02:03 PM | #29 |
Glen
Good deal! Does the rear axle need to be flipped to the bottom of the arm like you would with leaf springs? I could look under the Burban when I get home.... I'm not sure if the rear end is on top or below the trailing arm from the factory. If it does need to be flipped, does someone make a kit? Thanks for your help!
09-03-2008, 03:08 PM | #30 |
67-72 parts collector,…
rearend is on top of the trailing arms from the factory.
09-03-2008, 10:36 PM | #31 |
You need to leave it on the top. Switching it on bottom would raise the truck. You actually need lowering blocks between the rearend and control arms to get that low.
09-06-2008, 09:51 PM | #32 |
Looks good, I like the way you did the rear tubs. I am working on a 72 burb that I am 4dr-ing and may make a dually that will lay frame. I am thinking of a sleave bag for the rear and one of Nate's Dropmembers with stronge arms up front with dually spindles and hubs.
Kevin LFD Inc. |
10-03-2008, 01:39 AM | #33 |
dave
nice job I LOVE PEOPLE ARE STARTING TO SEE THESE BEASTS FOR WHAT THEY CAN BE AWESOME
QUOTE=bagged69c10;2852804]The tubs. Front fender. Layed out. All up. [/QUOTE]
check out my build "DIRTY BURB" |
10-05-2008, 01:12 AM | #34 |
PROJECT 7DEUCE
Very cool.............
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-05-2008, 07:23 AM | #35 |
Step Brother
Looks great.....
10-07-2008, 09:46 PM | #36 |
Thanks. The tubs were not alot of fun. Its my first set. I was pretty happy with the turnout.
10-13-2008, 11:54 AM | #37 |
Nice sheetmetal work.......
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-19-2008, 12:20 AM | #38 |
Thanks. It was good practice for when I do mine.
07-31-2015, 12:21 PM | #39 |
Found it...thanks!
