Old 12-27-2008, 04:54 PM   #26
Gray Ghost
Gray Ghost's Avatar
Re: Quiet down my cab
Cool...looks just like what I have. Makes a big difference huh?
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 12-27-2008, 07:05 PM   #27
joekewl_chevyfreak
joekewl_chevyfreak's Avatar
Wallyworld sells a do-it-yourself spray on bed liner that may be useful, i think its like 50 bucks and that is supposed to do a single layer on a shortbed? I may be wrong tho
Edit: Haha i should have read the last couple of posts, well now ya know lol
'68 chevy c10 1/2 ton inline 6, 250 2wd stock everything. exposed to elements for 40 years
'87 Dodge D150, 318 auto stock; D.D.
God meant for rubber to be burnt, not for an ear of corn
Myspace
joekewl_chevyfreak is offline   Reply With Quote
Old 12-27-2008, 07:11 PM   #28
thelonerife
thelonerife's Avatar
I think I 'm gonna put the reflectix over my dynamat.. I'm waiting for my 2nd box to finish it up. then I'll get some of it.
thelonerife is offline   Reply With Quote
Old 12-27-2008, 07:49 PM   #29
msgross
msgross's Avatar
B-Quiet (brown bread) has some good reviews...
I'm think about it and a DYI Raptor bedliner for the bottom of the cab...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-28-2008, 11:10 AM   #30
70 net440
Junior Member
70 net440's Avatar
This is what I used in the wife's '63.[IMG][/IMG]
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 12-28-2008, 11:12 AM   #31
70 net440
Junior Member
70 net440's Avatar
Well, pictures didn't post. It is duct insulation from Lowe's. It is 1/8 inch self adhesive foam with foil on one side.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
Old 12-28-2008, 11:26 AM   #32
70 net440
Junior Member
70 net440's Avatar
Hey, I finally figured out how to put pictures in a post. This stuff seems to work well. I haven't driven the truck yet, the carpet was thrashed, so I'm ordering a new one while I'm at it. Three rolls did the floor, inside of the doors, and I might have enough for the door panels. It costs about $15.00 per roll.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
Old 12-28-2008, 04:03 PM   #33
cppursell
cppursell's Avatar
That's the exact stuff that I was considering buying at Home Depot, but decided on the stuff on Amazon since it provided more material for the money. My solution worked great but that looks like it will work too.
cppursell is offline   Reply With Quote
Old 09-22-2012, 11:49 AM   #34
longbed67
longbed67's Avatar
I used two gallons of scorpion spray in bed liner, (A lot like Line-X) and mixed the ceramic insulating particles NASA developed, and then covered that with Frost King Duct insulation from Lowes, then a layer of the jute, and then the Mass Loaded Vinyl that is heat molded to the back of my carpet. Yes probably overkill but I want this thing quiet!
My Question is, how do quiet down the doors!?? They sound so tinny, and yes I know it is an old truck.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 09-22-2012, 01:21 PM   #35
gotchamel
I used Fatmat in the doors.I did it when I replaced regulators and rollers so access was easy.It made a very noticeable difference,the doors sound solid now when you close.On vertical surface make sure its very clean,I used simple green the denatured alcohol.
gotchamel is offline   Reply With Quote
Old 09-22-2012, 03:20 PM   #36
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
I did 2 layers of fatt Matt followed by some carpet insulation and then factory carpet....
Probably the single best thing I did to my truck. It's 100x more quiet and long trips are enjoyable. Also did the push on gmc Paul's door seals and ditched the glass packs for a full exhaust system.
Night and day
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 09-22-2012, 06:13 PM   #37
longbed67
longbed67's Avatar
Thanks!
Night and day
Looks Like I will be getting some fatt mat, and how long did it take for your doors to line up properly after installing the push on door seals?
Adam
(608) 214-8706
Old 09-22-2012, 06:45 PM   #38
70cst
70cst's Avatar
I used B Quiet in the Circuit Rider and am well pleased
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-22-2012, 08:59 PM   #39
gotchamel
Thanks!
I did push on seals at the same time as Fatmat.The pass side was good to go but the driver side has needed some break in time with an occasional spray of silicone.Even cutting them at a 45 it helps to crack a window when shutting,thats a good thing,right?
