Old 03-04-2009, 02:02 PM   #26
MickMc
MickMc's Avatar
Re: Adjustable rear trailing arms how-to
It looked like he inserted steel into the end of the square tubing and I saw the plug welds, but the 'criss crossin' part had me confused...
Mick
MickMc is offline   Reply With Quote
Old 03-05-2009, 03:13 PM   #27
fixit-p
fixit-p's Avatar
Question Re: Adjustable rear trailing arms how-to
Nice job... Do you have any measurements on the trailing arms, my 3/4 ton has leafs so I have no reference to build mine from also did you use 3 x 2 x ?? tube
fixit-p is offline   Reply With Quote
Old 03-10-2009, 12:00 AM   #28
nuke1
nuke1's Avatar
Hey guys sorry for the late response. i will show some pics of what i did, these i took after the fact to show you so bear with me.
As for the angle of the arms, i traced them on white borad. i then took a cheap angle finder and made the same angle that the trailing arms were. once i found this i turned it 90 degrees and that created my angle that i had to cut out to bend my arms too. mathematics is what it is. add and subtract.
for the end piece, you are really gonna have to bear with me, i took my threaded rod and welded square stock to it in a cross fashion ( + ), then drilled coresponding holes in arms to then plug weld the stock too. this creates a stronger area than just welding it to the end.
as for the length i will find out and let you know.
If ther are any more questions just ask.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-10-2009, 04:45 PM   #29
joe231
joe231's Avatar
Thanks!!
CHEVY ONLY
Old 06-13-2009, 08:12 AM   #30
70 Suburban
Rods
wow that is a nice write up
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 08-20-2009, 07:47 PM   #31
bmfpeterson
bmfpeterson's Avatar
Definetly a good write up. so good of a write up I built my self a pair!
bmfpeterson is offline   Reply With Quote
Old 08-20-2009, 08:58 PM   #32
jjjmm56
jjjmm56's Avatar
where did you find that style rod ends?
jjjmm56 is offline   Reply With Quote
Old 08-20-2009, 10:22 PM   #33
SCOTI
SCOTI's Avatar
http://www.ballisticfabrication.com
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-20-2009, 10:39 PM   #34
jjjmm56
jjjmm56's Avatar
Man thats a great site. I cant build the stuff for what their selling for. Thanks!
Old 08-28-2009, 03:20 PM   #35
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
that's looks good.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 08-29-2009, 06:58 PM   #36
bmfpeterson
maybe I bought the wrong steel, but I am pretty sure mine are heavier than my stock arms......def better looking and stronger (that's what I was going for)
If I remember right the angle was right around 15 degrees I'll measure mine and post what they are....
Old 08-30-2009, 01:02 PM   #37
nuke1
nuke1's Avatar
And here vi thought this thread was dead, hmm, good to see some ppl can use it, BMFPETERSON you will have to add some pics, i would like to see them, and to let you all know, i drove my truck finally and it handles amazing, i can crank it into a corner and she lays flat and goes, just amazing, not a truck anymore!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 10-12-2009, 02:58 PM   #38
bmfpeterson
Here are a couple pics of what i have built..... I am waiting for a friend to machine the solid stock to slide into the arm and tap it for the hiems joint.
Old 10-12-2009, 03:29 PM   #39
SCOTI
SCOTI's Avatar
Look's good so far!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-30-2009, 10:54 PM   #40
noonzor
plan on startin on my set next week here!!! cant wait, so glad you wrote this up.
Thanks Nuke!!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 02-02-2010, 09:08 PM   #41
phipp13
THE DAMN YANKEE
phipp13's Avatar
excellent job on your arms. where did the ballistic joints come from??they are much stronger than origional too. phipp
phipp13 is offline   Reply With Quote
Old 02-03-2010, 12:21 AM   #42
SCOTI
SCOTI's Avatar
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-05-2010, 01:55 AM   #43
nuke1
nuke1's Avatar
wow, i inspired someone, feels kinda good, great job guys, lets see some completed pics of them now.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 02-16-2010, 01:55 PM   #44
bmfpeterson
still waiting to get for my buddy to machine me a bung to slide in the front side...... He's been pretty busy but I got him fired up the other day and he started again hopefully next week I can have them done and ready to weld back together......
Old 02-16-2010, 08:55 PM   #45
lofly'a
lofly'a's Avatar
excellent build and write-up needs to be in HOW-TO.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 02-18-2010, 02:51 AM   #46
derek6787
Backwoods Body
Very nice! You just got rid of the articulation complaint of a 2 link.
derek6787 is offline   Reply With Quote
Old 02-18-2010, 10:19 AM   #47
crakarjax
crakarjax's Avatar
Can someone explain what this means for those of us who dont know?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 02-18-2010, 10:35 AM   #48
SCOTI
SCOTI's Avatar
The OE truck-arms use a rubber bushing in the front. The articulation from the stock TA's comes from the I-beam style of constuction, length, & triangulated front mounting position (allowing limited twist) w/the rubber bushings. Substitute poly bushings for the rubber & you limit deflection but increase the possibility of binding.
Make a new aftermarket TA from tubular steel construction & now you've also removed the ability to flex over the length of the TA which again increases the possibility of binding.
The tubular arms offer greater strength & rigidity. Add the pivot-joint style bushing up fromt & you end up w/precise control of the arms movement w/better articulation vs. the less than stellar rubber bushing (pivot joints yeild about 33° of articulation).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-18-2010, 10:45 AM   #49
N2TRUX
Happy to be here
N2TRUX's Avatar
This DIY article is now in our FAQ forum- LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-18-2010, 12:26 PM   #50
DKN
Active Member
You get more twist with less effort. This is great if you are building a rock crawler. It is the exact opposite of what a rear sway bar does.
Danny Nix
CPP
DKN is offline   Reply With Quote
