#26 |
Re: Blazer Seat Bracket Question
Forgot you posted the pic's and yours are the same as mine... HATE THEM! Don't know how they ended up in mine. Figured I would swap them out later.
#27 |
![]() Join Date: Oct 2008
Bought covers from LMC to small they sent me to a lady at Truck World named Dixie in Springfield,MO (417)883-8390
SHE WAS ABLE TO FIX ME UP WITH SOME SCROLL COVERS FOR FAT BOY SEATS(UTILITY) THAT IS WHAT SHE CALLED THEM. I SENT PICS IN THE OTHER TREAD TODAY. The back on these are metal and criscrossed as you said. |
#28 |
Does anyone have the rt frt seat brkt picutres or parts for a 1970 K5 Blazer?
#29 |
Sorry, no pics. But you might want to specify which seat brackets your looking for. Utility buckets or Sport buckets. The brackets are different bt. the two.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
#30 |
I guess the utility because the rt frt seat folds forward and latches when in the down position. The seat are pretty fat and the back part is low.
#31 |
These are utility buckets or fatboy seats the others are narrow with plastic backs these are metal backs.
#32 |
That is what I have. They have already been redone but the rt frt seat brackets have been missplaced. Can you get me a picture of the seat with it leaning forward?
#33 |
I will try to remember this evening when i get home. It has a center female bracket bolted to the floor and the seat has a male bracket that it sets down in which can be unlatched by pulling on a rod or using the handle you can see at the back.
#34 |
That sounds correct. I have the male part but nothing else. Thanks
#35 |
I may have an extra female bracket. maybe i will have to check.
#36 |
Here is a picture of a bracket where the latch is to the right mine is in the middle both were used. I copied this from another thread mine is the same only in the middle instead of the right.You can spot the female bracket at the bottom right.
#37 |
Thanks, I have the long bar and the hook shown on the seat but i will have to see about the rest of the brackets. This helps a lot.
#38 |
Here is mine that has brackets in the center.
#39 |
After looking at these pictures mine is different. My seats are on a 1970. Is yours a 71? Maybe they are different?
#40 |
Yes mine is a 71 blazer i think the first picture with it on the right side was earlier model just a guess.
#41 |
#42 |
67-72 parts collector,…
![]() Join Date: Nov 2002
#43 |
Thanks so is that front to back or side to side?
#44 |
Front to back
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#45 |
I need a female bracket for the pass side seat for a 71 blazer. Also need 1 front bracket that bolts to the floor if anyone has them please let me know. Thanx
