Old 01-09-2009, 09:03 AM   #26
Gray Ghost
Gray Ghost's Avatar
Re: New 'lifetime warranty' starter from O'reilly is junk
Originally Posted by kookykrispy View Post
Well, now this is very strange. The wife gave me a ride and I got down there, hopped in and it started right up... ??? so WTF? I guess this is an intermittant problem. Could it have something to do with heatsoak? After getting it home, I started it several times again, with no problems. I will double check all the connections... maybe I should replace the main battery cable? Is there any merit to wiring in a ford style remote solonoid? I added one one my '67 GTO and it cured all my heatsoak starting problems.... but that car is high compression, has headers and a ministarter too. This truck is stock! Could it be still experiencing heat soak?
I still don't like this O'reilly starter. I want to do something to cure this so it does not happen again. I want this truck to be dead on reliable, and start every time no matter what.
Good luck with that. You are driving an old truck and using a $40 starter...life ain't gonna be perfect. Take it off the truck and back to OR's and get your cash back, then go somewhere else and get one. Chances are you'll get a better one and then you can come back here and tell us how wonderful their parts are.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 01-09-2009, 11:20 AM   #27
Ackattack
Ackattack's Avatar
I too have fought with starters on these old trucks, being stranded on the side of the road many times. I installed a high torque mini starter and even had a problem with that a few times. Finally I installed a remote starter solenoid and never had any more problems.
If and when I ever have another sbc, that will probably be one of the first things that I install.
Good luck!
Ackattack is offline   Reply With Quote
Old 01-09-2009, 02:16 PM   #28
flynbrian
The Manual I bought at Adavance auto has a whole section on how to rebuild alternators and starters & water pumps. Its either a Haynes or Chiltons..."How to rebuild Chevy Engines book" I use it for reference once in awhile.
Good bathroom reading material.
I have had bad luck with lifetime Radiators, Alternators, Brake master cylinders, and several other items.
The worst was the master cylinder for my 70' It failed on me in November and I almost crashed the truck on a 4 lane busy highway! It was "remanned autozone junk" I went back and almost threw it at them. They gave me back all of my money for it and I bought the "New" one that looks identical with no core charge either. The "new" one is working for now....But I am still very gun-shy about it! Its said made in China on the box and that spells junk in my vocabulary...
I work on Chinese scooters all the time at the Bike shop I work at part time. They have gotten much better with time...But the electrical systems are still junk. Switches and bulbs from China got to be the worst I've ever seen...And if you look at the wire insulation the wrong way....It will fall off the wire. Stuff made in Taiwan is actually much better than China...And Some of the Europe stuff is almost as bad as China...(I got a thing for Scooters) Vespa's are well known for having JUNK electrics.
The worst problem I see with the master cylinder made in China is the rubber seals...Seems that the rubber from over there sucks bad. Their valve stems will dryrot in like two months when exposed to the sun....So watch out.
1970 C-10, manual everything converted to automatic trans with a 307
1974 Monte Carlo Turbocharged cast piston 350 on 14# of boost
1975 Monte Carlo-Project not started yet
1969 Pontiac Firebird, 406, 4 speed, 3.91 gear
2002-08 Zuma Scooters
1997 TL1000SV/R Suzuki V-twin Sportbike
flynbrian is offline   Reply With Quote
Old 01-09-2009, 07:12 PM   #29
Aarons72s
I have to agree 100% with that. Any thing rubber I have bought that was made in china rotted and cracked within a year. Be it rubber ties for wagons or wheel barrows, air hoses, o rings, washers and so on.
Aarons72s is offline   Reply With Quote
Old 01-09-2009, 07:19 PM   #30
MotorSeven
Restoration Desperation
MotorSeven's Avatar
Interesting thread. I have heard the horror stories about crappy starters from discount type auto parts stores. Funny thing, about 30 miles away from me is an old timer that has been re-building starters for 50+ years. Everyone i have talked to here has never had one he rebuilt fail. This is not majic or rocket science folks, but is seems that corporate America could give a rats #$* about it's consumer. We(USA business) can't even be bothered with building our own starters anymore........................sad.
RD
MotorSeven is offline   Reply With Quote
Old 01-09-2009, 07:26 PM   #31
2bits
2bits's Avatar
It is going to be hard finding made in USA replacement parts like that anywhere. Get you two starters, alternators, fuel pumps and water pumps and put one on your truck and the other in your tool box.
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 01-09-2009, 07:34 PM   #32
leddzepp
Moderator
leddzepp's Avatar
Starters, alternators, A/C compressors...always have them built by a local shop that does it on the premises. You will not have problems then. When I buy an alternator from autozone, I immediately take it to my local shop and have old Ernie rebuild it and convert it to one wire. Never have problems this way.
leddzepp is offline   Reply With Quote
Old 01-09-2009, 08:54 PM   #33
kxnomore
kxnomore's Avatar
back to the starter issue. You mentioned heat soak, and I've had some bad luck with that too.
I had a new Kragen starter go bad after a long road trip. It just wouldn't click over until the truck cooled completely. Then it cranked right over.
So I returned it for a new one, but this time I got a new plastic cover for the solenoid and wrapped the whole starter with a heat blanket kit. That was 2 years ago and I haven't had any trouble since.
But I definitely agree with all the posts about the old time mechanics actually fixing problems, and not just throwing parts at something, crossing your fingers, and hoping the owner sells the car before your installed junk breaks.
kxnomore is offline   Reply With Quote
Old 01-09-2009, 09:56 PM   #34
Green Machine
Green Machine's Avatar
We usually rebuild our own starters and alternators also. Sometimes they are too bad to fix, then we have run the cheaper line of NAPA rebuilts. They have several grades, the more expensive line is supposed to be better, but we've had no problems yet, with even the cheaper ones. I don't think NAPA is any worse nor any better that any other parts house.
We are lucky to have a local electric motor service, that may be the best place to to get something rebuilt if you have one close.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 01-10-2009, 12:36 AM   #35
Cunit69
Hey I was made in Mexico.. but I never build any starters!!!!!!!!!!
Cunit69 is offline   Reply With Quote
Old 01-10-2009, 09:28 AM   #36
70Custom10Nut
70Custom10Nut's Avatar
You know, I went through that same circus a few years ago with the "discount" replacement for my truck, (the kid behind the counter insisted it was the right one) and ended up being able to remove and install a starter in 20 minutes or less (I did this 5 times in a 1 year period). You pay a little more for factory, but my current one has been in place for almost 9 years now. One more note, If you have a nose cone that works, never let it out of your sight.chevy:
70Custom10Nut is offline   Reply With Quote
Old 01-11-2009, 11:50 PM   #37
corn
Parts house cheap line starters & alternators are all the same. The only thing that gets replaced is the part that is bad. The premium lines have been completely rebuilt. I like cheap parts as much as the next guy, but Ill spend the extra $10 for the premium line when it comes to starters & alternators.
corn is offline   Reply With Quote
Old 01-11-2009, 11:54 PM   #38
BowTieMan
BowTieMan's Avatar
Originally Posted by yotaforce View Post
"Anyone can crap in a box and stamp lifetime warranty it..."-Chris Farley-"Tommy Boy"
LMAO!!! that movie was just on a few min ago here.
And I think I went thru 4 lifetime warranty starters from autozone in my 70 before I got one that lasted.
BowTieMan is offline   Reply With Quote
Old 01-13-2009, 12:17 AM   #39
blazer72
Freedom isn't Free
blazer72's Avatar
"but at the end of the day, all you got is a warrantied piece of ****"
Previous rides: (worth mentioning)
67 camaro
70 long fleet, 69 short step (stolen), 72 blazer
62 chrysler imperial (hell yeah)
55 and 56 chevy hdtps
72 monte carlo
Daily Driver:
86 S-10 Blazer (drive it til I die) and 71 long fleet
Projects:
71 suburban, 72 C-30 Dually, 71 Chevy LWB
blazer72 is offline   Reply With Quote
Old 01-13-2009, 12:24 AM   #40
70' GMC
HERE.......Somewhere
70' GMC's Avatar
I got one from napa in 2007 and it went out like in the summer of 2008. all the stuff is foreign for our trucks and you are not going to find one made in america or canada. Only mexijapachin parts for your 67-72 chevy gmc pick up.
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 01-13-2009, 12:52 AM   #41
straitnate14
straitnate14's Avatar
theres a shop in our town that does starters stuff like that and it's a going rate of $45 for anything unless it's got some special part, go in and all you see is crap everywhere and they pull your starter out of a pile of junk with a tag on it and a fresh coat of paint they never have any problems either
ΜΟΛΩΝ ΛΑΒΕ
straitnate14 is offline   Reply With Quote
Old 01-13-2009, 01:34 AM   #42
67ChevyRedneck
67ChevyRedneck's Avatar
Heat soak *may* be your problem. My 67 went through 3 or 4 starters in a couple years time as well as leaving me stuck at gas stations and other places because it was too "hot" to start.
I installed a new starter and heat shield well over a year ago and I haven't had any starter issues yet. They're kinda cheap. This one is metal.
http://shop.advanceautoparts.com/Pro...goryCode=3638J
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-13-2009, 10:08 AM   #43
Lifetime warranty just means they`ll keep throwing jink parts at you until you give up or sell the vehicle.Has nothing to do with quality.I like to take my starters,alternator,and carbs to a trusted benchwork shop.You get your same part back and talk to the guy who`s doing the work.Cheaper,too.In a pinch I go to Napa,pay the core,and keep my part.
Old 01-13-2009, 10:22 PM   #44
69C10@16
I too work at O'Reilly's here at home.
If my starter went out I would ship it to a mom and pop place that our store is hooked up with called J&I. They rebuild starters and alternators for our customers all the time and I haven't heard one complaint yet out of a customer.
I have an O'Reilly Alternator on the GMC and it's the third, one of them stranded me 100 miles away from home. The sale was registered in our system and I got my replacement though.
It's just like was stated earlier, NOTHING is made the way it used to be. The next time that alternator goes out I'm going to say screw it and ship it to J&I too and have them rewind the thing to a higher amperage while they are there. The Off Road Lights I'm going to be ordering this summer really take some power.
69C10@16 is offline   Reply With Quote
