Old 02-09-2009, 10:59 PM   #26
Strodder
Daring to be Different
Strodder's Avatar
Re: 1965/73 Cheap Build Up
There it is.
I put the wheels back on so it rolls. Here it is under the 73 frame. This is where I decided to cut the frame in a different place. Back a little where it's straighter.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 02-09-2009, 11:07 PM   #27
Strodder
Strodder's Avatar
I lowered the body a little at a time so I could get dollies under it. With the hand truck I can wheel it around. I need to go to Harbor Freight to get 2 more dollies.
Notice the doors are closed. It's friggin Raining, snowing, and hailing out side.
Here it's going to sit for a while until I get the frame welded back together.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-09-2009, 11:25 PM   #28
joe231
joe231's Avatar
nice work!
and I dig your shop!
CHEVY ONLY
Old 02-09-2009, 11:30 PM   #29
Strodder
Strodder's Avatar
Thanks!!
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-11-2009, 11:35 PM   #30
Strodder
Strodder's Avatar
Today I pressure washed the frames, and began to measure measure for
the cut. I thought cutting it at an angle would work, but it didn't. So I
cut it at a 90 degrees. I decided to slip the 2 sections together instead
of but welding together, and welding gussets at the seam. It worked
GREAT, and is very strong this way.
After I decided to slip them together with the front part of the frame be cut at a angle. See it just didn't look right.
So I cut a 90 degree, and slipped them together again.
To make them fit snug I heated the lower part of the rail and
hammered them down to open it up. I also used a ratched tie down
to squeese the front frame together which made it move in & out
better to get the measurement correct. Now the front frame slips
in real nice. I measured the cab mounts to get the correct length
when they are joined. Next I leveled both frames, and crossed
measured to make sure they are square.
The frame still didn't fit tight against each other, so I drilled a hole
through the frame where the didn't fit good. Then I bolted them tight.
This pulled them together. Then I hammered the bottom up tight again to
fit close to the inside frame.
Here it is together, but not welded yet. With both sides drilled &
bolted it's real sturdy. Even lifting it on the lift it stayed put.
When I let it back down I remesured, and it didn't move at all.
Next I'll put the cab & bed on to check the fit. If it isn't right I can still move it.Then I'll weld it.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-12-2009, 07:59 PM   #31
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Nice progress. I love your shop.
Alan's Classic is offline   Reply With Quote
Old 02-12-2009, 10:54 PM   #32
Strodder
Strodder's Avatar
Thanks Allan.
Got more done today.
I moved the cab over to the lift. So I could lower it onto the frame.
I needed to see how it would fit with the frame just bolted together.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-12-2009, 10:59 PM   #33
Strodder
Strodder's Avatar
It didn't sit level with the frame. I'm going to channel the rear of the cab to make it right.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-12-2009, 11:13 PM   #34
Strodder
Strodder's Avatar
Mean while I saw that the cab trial fit was good. So I lifted the cab off, and rolled the frame out to do the final welding.
First I leveled, and remeasured. Then I started to weld it.
I took advantage of the holes, and welded them up through the front frame that I slipped into the rear frame.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-12-2009, 11:17 PM   #35
CSoliz
Torn between 66 and 78
CSoliz's Avatar
Where exactly is your union of the 2 frames? Is it anywhere near the cab mounts?
Where you cut them, if you wanted, how easy would it have been to shorten the wheel base?
Love your shop too!
Edit: Sorry, we posted at a similar time. I see your mounts. Second question still stands.
CSoliz is offline   Reply With Quote
Old 02-12-2009, 11:19 PM   #36
Strodder
Strodder's Avatar
Here's what it looks like all cleaned up. I tried to hide where I joined the frames together, and make it look as clean as possible, and very strong. Notice I welded the holes and ground them smooth.
I have to put the frame back on the lift to weld the bottom. Next I have to modify the rear cab so it fits level.
I'm want to paint the frame ASAP. but after I clean up the rest of it.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-12-2009, 11:49 PM   #37
Strodder
Strodder's Avatar
Love your shop too!
It would be easy to shorten the stock frame. Mine was complicated because of the years I joined together. Normally I would butt the frames together, and gusset them for strength. Like I shortened this S-10 frame to put under a 47 Studebaker Truck. This is a picture before I made the gussets that would sandwich the butt welds. You can make a long bed into a short bed this way. Cut behind the cab though. Make sure your wheels are positioned in the center of the bed wheel wells when you measure.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-13-2009, 12:04 AM   #38
Strodder
Strodder's Avatar
BTW Thanks everybody for the complements on my shop. I walk 90 ft to work from my back yard. I love it.
The floor still looks good here. The more work I do the more the floor gets screwed up. OH WELL.
Good thing I walk to work. I wouldn't have made it if I had to drive.....
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-13-2009, 01:40 AM   #39
protrash64
Resistance is Futile
protrash64's Avatar
I have to say 'nice shop' also. Thats cool how the frames fit together like they did. Nice work.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-13-2009, 09:09 AM   #40
joe231
joe231's Avatar
you do restos/customs for a living?
CHEVY ONLY
Old 02-13-2009, 09:28 AM   #41
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Intersting build you got going...I like your plans.
Where abouts is Hesperia ?? Obviously up North some where !!
I was told it's snowing in Nevada City/Grass Valley area. Thats where my wifes grandmother lives.
Curious as to why you wanted leafs, if your gonna bag it ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 02-13-2009, 09:35 AM   #42
Strodder
Strodder's Avatar
Thanks. I glade I decided to do it this way. It's the strongest part of the frame.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-13-2009, 09:37 AM   #43
Strodder
Strodder's Avatar
Yes if you call it a living....I'm supposed to be retired...haha
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-13-2009, 09:45 AM   #44
Strodder
Strodder's Avatar
Hesperia is off the 15 fwy just north of San Bernardino. Were at 3,400 foot level.
I don't care about the leafs that much. I like the way the frame rails look. There better to fab a notch. But for now I might leave the leafs. Also the 73 is a 1/2 ton with a 5 lug 12 bolt posi. One more reason is I'm using the 73 short step side bed.
Anybody want to buy the Dana that came out of the 65 8 lug 3/4 ton?
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-18-2009, 10:35 PM   #45
Strodder
Strodder's Avatar
Here's the latest. I finished welding up the rest of the frame after lifting it up on the lift (note: I LOVE THAT LIFT) Then cutting the back of the cab so it will fit level with the frame.
This is what the cab looked like before I cut it.
This is after
Now it sits level. I'll mount the 65 side cab mounts so I can keep the cab nice and low.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-18-2009, 10:45 PM   #46
Strodder
Strodder's Avatar
Next I swapped the 73 front 1/2 ton cross member with the suspension. Witch included the 2 1/2" dropped spindles, and disc brakes.
While the cross member was off I cleaned up & painted the frame, and cross member where it bolted on the frame,
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-18-2009, 10:52 PM   #47
Strodder
Strodder's Avatar
It's NOW officially a 1965 C-10 Short Bed. Even though it's half a 73
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-18-2009, 10:55 PM   #48
joe231
joe231's Avatar
nice work!!!
CHEVY ONLY
Old 02-18-2009, 10:58 PM   #49
LILRED66
LILRED66's Avatar
Strodder:
I just read through your build thread from start to finish. Very nice, indeed. I like what you are doing. Keep us posted on your progress and thanks for sharing the numerous photos. I'll stay tuned in for this one.
LILRED66 is offline   Reply With Quote
Old 02-18-2009, 10:59 PM   #50
Strodder
Strodder's Avatar
I cleaned up the Cragar SS wheels that came with the 73. They look pretty good. Now I need to find one 15x8 with a 4 1/2" back spacing, Or maybe I have to find 2.
This is the 16X8 in the rear.
This is the only good 15" one in the front
They look really good. Better than I expected.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
