02-13-2013, 01:09 PM | #26 |
17's too small
Re: tilt column rebuild
I keep coming across this thread when I search for tilt column rebuild so I wanted to add my 2 cents.
I took apart 90% of my van tilt column last night (the only think left is the bowl on the shift tube). I plan on making a "how to" thread so search for that for detailed pictures and how to make a pivit pin removal tool that doesnt require a slide hammer.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows |
02-13-2013, 01:29 PM | #27 | |
Its around page 70 on my build
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-13-2013 at 01:37 PM. |
02-13-2013, 02:03 PM | #28 |
17's too small
I have the actual tool (somewhere). I could not find it so I did the exact same thing as you. Plus it helped having the tool to know for sure what I was going after. I took some good photos and will post them real soon to help out others. So I got that apart just fine. The last thing I have to seperate is the shift bowl from the tube that goes down inside the column.
03-04-2013, 02:07 PM | #29 |
17's too small
Im lazy and have not worked on my how to thread as promised above. But I did take some pictures that helped out here.
I also scored the shift bowl removal and installation tool on eBay for about $15 each. I am still wanting the socket that fits the large nut near the upper tilt bearing.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows Last edited by ChevyCruizer; 03-04-2013 at 02:18 PM. |
04-05-2013, 07:45 PM | #30 |
17's too small
I ended up getting the "special socket" Kent Moore J-22599 from this website. I paid way more than I wanted to but I had been searching the web and eBay for the last month and this was the only one that I have found.
I picked up a blast cabinet from Harbor Freight (HF) so I'm planning on cleaning everything up and then looking into getting the HF powder coating tool, but might end up taking the parts to a professional powdercoater in town (I have some big suspension parts to do also).
03-05-2015, 06:43 PM | #31 |
I just need to reach lace the upper bearing in my 72 cheyenne tilt.. Any pointers?
