Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-27-2009, 08:08 PM   #26
115-K10
115-K10's Avatar
Re: 1970 swb K10 Resurrection (AKA "The Chum Bucket") "Photos"
Hi Landon, Thanks for the photos of your frame. It may be an option down the road. What are you looking to get out of it? Tomorrow I am going to go and look at a 67-68 k10 swb rolling chassis. The guy claims it’s good. I have heard that before.
The chum Bucket - SWB K10 Restoration - http://67-72chevytrucks.com/vboard/s...d.php?t=329775
1971 SS454 Monte http://www.hemmings.com/mus/stories/...feature14.html
1970 - Monte Carlo Convertible, LS6, L89, M22 Build
http://www.firstgenmc.com/ubbthreads...=360236&page=1
1970-SS454 Tripe Black - Barn Find
http://www.firstgenerationmontecarlo...=421201&page=1
115-K10 is offline   Reply With Quote
Old 02-27-2009, 08:32 PM   #27
115-K10
115-K10's Avatar
Originally Posted by msgross View Post
interesting project...
Hi Mike,
I checked out your build a few weeks ago. You have done a lot of work. Looks like you are in the home stretch and it looks great. I had to laugh when your wife wanted to park in the garage. It’s a running joke in my house that if your vehicle is not at least 35 years old it does not get a stall. She drives a ’08 so it’s going to be some time before she is eligible for a spot.
What’s the deal with power steering on these trucks? Does a 70 frame need modification or adapter to mount the steering box?
Old 02-27-2009, 09:05 PM   #28
msgross
msgross's Avatar
a 70 frame shouldn't need modified... it's all about the "raised pads" under the steering box... 67's and most 68's were smooth frames and need an adapter to run a newer steering box... No big deal either way...
I would say my "home stretch" is still a year away! thanks though...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-27-2009, 10:30 PM   #29
Landon
Take a look at that other set up (67-68 frame) and see what you think. I think I may have inquired about that one back in Jan. Never made it to look at it. Craigs List? Mine isn't going anywhere. If your interested the price for the whole thing will be more than fair. My wife would really like it out of the yard!
PS Nice Monte
Landon
Landon is offline   Reply With Quote
Old 02-28-2009, 09:00 PM   #30
115-K10
115-K10's Avatar
PS Nice Monte
Landon
Landon, Took the 45 min ride to check out the frame today and it turned out to be in great shape. I could not pass it up for $450 bucks. This will make this build so much cleaner. It’s all about having a good foundation. Thanks for offering your extra frame. I am sure someone else will need it. You should post it in the parts section.
Old 02-28-2009, 09:47 PM   #31
msgross
msgross's Avatar
wow, you found that frame in NY????
Looks just like mine except 100% cleaner... that things is ready for the road...good buy!
The Garage:
Old 02-28-2009, 10:26 PM   #32
Landon
Glad you found a good one. Looks a lot nicer than the one I showed you pics. of. Just remember that the rear springs are longer on a 67-68 than that of a 69-72 frame. I learned the hard way. I ended up buying the newer springs and moving my sping mounts in. Lucky for me I had a patteren/measurements off the frame I pictured. Good luck. To bad you put all that time into the other frame.
Happy truckin
Landon
Old 02-28-2009, 10:29 PM   #33
UltraBlue71
UltraBlue71's Avatar
god bless ya 115, my cab had rust issues like that, its heartbreaking as you sandblast to watch the rust dissapear and the holes start, I live out in ID now, the trucks are a little more solid that the ones back in in MO, no salt on the roads and little humidity helps, good luck on your build.
UltraBlue71 is offline   Reply With Quote
Old 02-28-2009, 10:52 PM   #34
115-K10
115-K10's Avatar
I went with no expectations and figured it would be a “Wally World” trip so I was pleasantly surprised when I saw it. It’s all about timing. I will most likely sand blast it and put POR-15 on it to be sure I will not have corrosion issues with it down the road since I plan on pushing snow with it. I used that stuff on my Monte chassis and it has held up without any issues for 10 years now.
Old 02-28-2009, 11:07 PM   #35
Landon
What was the guys name you bought it from? I think I may have spoke with him on this one also. It was going to be quite a ride for me just to go and look at it. Long story short I went with the one that was a little closer. But still in NY and almost a 2 hr. ride.
Old 02-28-2009, 11:48 PM   #36
115-K10
115-K10's Avatar
Landon, Great looking truck. I am leaning toward the 67-68 front clip. It’s such a clean classic design. Ya, I knew the spring were longer on the early chassis. I am not sure if I am going to use the 56” springs or go to the 52”. I want to lift it a little but not too much. I am now thinking about bumping it up 2”-3” vs. a full 4”. Your truck height looks good. How much lift is under it? This chassis came with the 16.5 wheels too. They are cool looking. I hope to find 33” rubber for them and run the dog dish caps. The guys name was Lou. Seemed like a decent guy.
Old 03-01-2009, 02:26 AM   #37
drivethechevy
drivethechevy's Avatar
that frame you picked up was deffiantely a nice score for 450
i only wish i was lukky enough to have a nice cab and a nice ready to go frame like that
i cant tell from the pictures but if that frame still has the original front axle you may want to replace it, trucks 69 and older came factory with a closed nuckle set up which has a bad turning radius by design, to make the truck more driveable/ menuverable you should consider replacing the closed nuckle front axle(69 down) with an open nuckle (70 up) also as a added advantage for swaping front axles, if you get a 71- 87 front axle it will have disk brakes
nice project
nate
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 03-01-2009, 08:41 AM   #38
msgross
msgross's Avatar
JC in Jersey is selling a 67 front clip...
You can do a shackle flip in the rear for 4" of lift or you can use aftermarket spring and relocate the mounts too. That's the same flat frame issue that I have dealing with the power steering box, I picked up an adapter (Brothers has them online for 60-66 trucks but they will work) to mount the newer gearbox for the newer drag link for the newer front axle.
The Garage:
Old 03-01-2009, 10:51 AM   #39
115-K10
115-K10's Avatar
Nate, Thanks for the info on the closed front axels, and yes that is what is on the chassis now. Love the look of the closed version but for function I will most likely be using the open version. I have three front axels now 67, 70 drum & 72 disc. The 70 drum is in better shape than the 72 disc axel. Will the disc setup mount on the 70 knuckle or will I need to swap them out? Out of curiosity can you put the disc set up on a close Knuckle?
Old 03-01-2009, 11:08 AM   #40
115-K10
115-K10's Avatar
Mike, thanks for the heads up on the front clip. I will check it out and the PS adapter plate.
I have not reconciled in my head how high to go or what method. I Know I do not want to go more than 4”. Sort of want to run the old school 56” springs. Other than a shackle flip are guys adding leafs to the 56” springs?
Old 03-01-2009, 02:33 PM   #41
Landon
My truck (pictured) has a 4" spring lift from Superspring. To get the spring lift in the rear I had to go with the 52" springs and more the hangers. I didn't want to go with the block lift because ther rear springs were shot anyway. You will also have to shim the 52" spings because they are 2.5" wind instead of the 3" wide 67-68 units. Better yet use the ahngers off your newer frame.
I hope to get the ugly frame out from under mine this spring and get a nice set of 33" tires also. The ones pictured are 31x10.50s just for comparison reasons.
PS I remember talking to Lou. What kind of shape was that cab in? For sale?
I got my new frame for Lou's buddy Ken. From the sounds of it Lou and Ken have swapped a lot of parts and stories in the past. Both NY boys.
Landon
Old 03-01-2009, 03:02 PM   #42
msgross
msgross's Avatar
I added a leaf to mine and got 1.5" of lift. You would need to take yours to a spring shop and have leaves added/re-arched if you want to go 4" with stock springs...
I don't think you can do disc on the closed knuckle, but I think you can pull the spindle off the open knuckle drum and add the spindle and hubs from the open knuckle disc to it...
The Garage:
Old 03-02-2009, 10:49 PM   #43
115-K10
115-K10's Avatar
Landon , Not sure what direction I will take with lifting it. I have looked up a few spring kits and they vary in price quit a bit. Trying to keep the costs within reason. I did not look that closely at the cab but it seemed good. I made a deal with him for a front clip and I am going down to get it this week. I will look over the cab and see what he will take for it.
Old 03-06-2009, 06:46 PM   #44
115-K10
115-K10's Avatar
Re: 1970 ('68) swb K10 Resurrection (AKA "The Chum Bucket") "Photos"
My chum bucket of parts just got a little fuller and a few years older. Picked up this ‘68 front clip from the same guy I got the chassis from. The front end was out of CA and is solid. It looks fairly strait but can see some areas where dents were repaired but nothing big. I will know better once I strip them.
Old 03-07-2009, 11:26 PM   #45
115-K10
115-K10's Avatar
Landon[/QUOTE]
Landon,
Checked out the cab Lou has. It looks very solid but the sill plates were on so could not tell how that area was. It looked like it may need some repair up near the side kick plates but nothing excessive.
Old 03-08-2009, 11:20 AM   #46
glimmertwin01
glimmertwin01's Avatar
greetings from Rochester NY.. I am in the same boat as many of us in the rust belt... nice looking truck... its going to be cool. Im trying my hand at my first.... wish I had a lift... damn.. thats sweet. hey are you going to use the side mouldings on the clip?? cause if not id be more than happy to take em if they are decent... Im am building a rot free driver... I dont believe in Trailer/ Garage queens...
good luck Man..
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 03-08-2009, 07:44 PM   #47
115-K10
115-K10's Avatar
These trucks are hard to come by in the north east. Our roads look like the Bonneville Salt Flats in the winter. I do not plan on using the side moldings. If you want them just cover the shipping and they are yours. They are not show quality but could be cleaned up for a driver.
Old 03-08-2009, 08:28 PM   #48
115-K10
115-K10's Avatar
Popped off the rockers to see what was behind then. It’s not as bad as I expected but never the less needs some work. Hit it quick with the pot blaster. Other than the dents the cab corners are very solid. I need to order some patch panels. I understand that some of the replacement sheet metal is not that good. Anyone have a preferred source for them?
Old 03-08-2009, 08:36 PM   #49
115-K10
115-K10's Avatar
More shots.
Old 03-08-2009, 08:38 PM   #50
glimmertwin01
Ha! Bonneville... I work for the DOT out this way... our motto is a white road is a safe road...LOL
nothing like a good dose of salt and because that doesnt work fast enough we give it a shot of Mag Chloride... we are doing our part to help the auto industry out... keep rusting out cars they will build more....
I will send you a PM in regards to the trim....
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
