Old 04-28-2009, 04:48 PM   #26
fixit-p
fixit-p's Avatar
Re: kyb shocks/ part numbers
Holy crap this is awesome I just spent 15 mins doing a search for this post and nada nothing nope...all of the sudden poof there it is
fixit-p is offline   Reply With Quote
Old 04-28-2009, 09:43 PM   #27
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by ap2002 View Post
who did you get this number from? for teh 6" rear drop?
I saved the cardboard ends off of the KYB shock boxes that I got from ECE. I some how lost the front box end,... and need that number.
The number I posted (344067) is for KYB 6" drop rear coil springs.
Keith
Convert to disc brakes.
Old 04-29-2009, 06:38 AM   #28
ap2002
do you think the 344067 will work for the 5" rear drop?
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear,
1968 C-10 SWB - 454 BB TH350 -Gone!
ap2002 is offline   Reply With Quote
Old 04-29-2009, 07:28 AM   #29
72BlckButy
Tot Roddin'
72BlckButy's Avatar
For the most accurate information related to these drops I would contact ECE personally. However, I don't know why the 344067 shocks wouldn't work for a 5" drop.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-30-2009, 07:03 AM   #30
ap2002
this says that the 344067 is a shock for the front NOT the rear?
http://store.summitracing.com/partde...art=KYB-344067
Old 04-30-2009, 12:06 PM   #31
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The front and rear shock absorbers on 67-72 coil spring trucks will interchange if you wanted to. I have done it before. Front to rear, etc..
Second, ECE simply has done the research and determined appropriate shocks for lowered applications which they buy from KYB. Then, they cover over the official KYB part number on the box with their part number to save their proprietary information.
There is no way in hell that KYB makes specific shocks just for Early Classic. No way, no how.
If you buy the KYB shocks from ECE (like I have done many times) when you look closely at them, the KYB part number is stamped into the shock body right near the bottom eyelet.
After buying a few sets from ECE, nowdays when I buy KYBs, I simply order the KYB part number from Summit to save a good bit of money. Sorry ECE, times are tight. A KYB is a KYB regardless of where they come from.
On lowered trucks, the KYB GR-2 is much more suitable than the Gas-A-Just units are. The GR-2 is softer and helps the ride considerably.
Old 04-30-2009, 01:37 PM   #32
ap2002
thanks alot "TX Firefighter" for the info....
Old 04-30-2009, 07:41 PM   #33
70c10
67-72 Addict!
70c10's Avatar
I'm happy with my Gas adjusts on the front so I bought a set for the rear but have yet to install them. My dad went with the GR2 shocks for the softer ride and they are nice also. KYB's are nice shocks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-30-2009, 08:23 PM   #34
Tx Firefighter
If you are running the Gas-A-Just on the front, be sure and keep an eye on your upper shock studs. They have a problem with coming loose and wallowing the frame hole out anyway, and the stiffer shocks will agravate that even more.
Old 05-01-2009, 07:02 PM   #35
ap2002
just to give yall an update, i installed the KYB 344068 shocks on the front, and i am completely satisfied!!! the truck rides a whole lot better, alot let body roll for some reason? my only guess is that the old shocks were worn out but they seemed to be not too old?
Old 05-05-2009, 11:37 AM   #36
chevyrestoguy
chevyrestoguy's Avatar
On our trucks where we have flip kitted the rear, we have essentially moved the shock attach point up the same amount as the drop (usually 6 inches). I have researching shock data to try and find a suitable shock and many places list the extended and collapsed lengths. Would this theory apply in this example below?
Stock (rear):
Extended: 23.26" Collapsed: 14.23 Stroke: 9.03"
For a 6" lowered rear suspension and NO shock extenders, would you look for a shock with 6" removed from each of these numbers? That would be a very short shock in the collapsed position.
I need to get my notches done and do a full extension/full retraction test and see where the numbers lie and shoot for a shock that has the range I'm looking for. I have found that when you start looking at shorter length shocks, the shaft sizes and body diameters shrink also, and that's not good on a truck.
chevyrestoguy is offline   Reply With Quote
Old 09-15-2009, 03:30 PM   #37
XXL
Señor Member
XXL's Avatar
bump
XXL is offline   Reply With Quote
Old 09-16-2009, 11:59 AM   #38
Tx Firefighter
Here is what I know.
If you buy a front shock from ECE, it comes with their sticker on the box making the KYB number unreadable. The number on the shock is 344068. I ran these shocks for 100k miles on my 72 with drop spindles and 3 inch drop springs. Never bottomed out the shock. They are plenty good for 3 inch drop coil application.
In the rear, again ECE sourced shock, true pn 244055 works well with a 6 inch drop and aftermarket shock extenders like ECE, etc. This shock will allow the axle to bottom completely to the frame and still not fully collapse the shock. With 6 inch coils and any lowering block combo it will serve you well. Keeping in mind that only the coil affects shock travel. A lowering block does not affect the shock length.
Old 09-16-2009, 01:55 PM   #39
XXL
Señor Member
XXL's Avatar
All of this shock information is splendid!
Old 05-25-2010, 09:40 AM   #40
chuck3026
chuck3026's Avatar
Any suggestions for a KYB part # on a 5" axle flip it leaf spring drop in the rear.
2006 Crew cab Z71
1972 Short Wide Step (under construction)
chuck3026 is offline   Reply With Quote
Old 05-31-2010, 05:11 PM   #41
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Anyone using KYB's for front dropmember setup? If you have a part number or where to find them that would help...
JNJchev77 is offline   Reply With Quote
Old 06-01-2010, 02:29 PM   #42
72BlckButy
Tot Roddin'
72BlckButy's Avatar
You might want to post this as a separate question in the Suspension section, just so you can ensure you receive the right responses.
-Nate
Old 09-03-2010, 10:25 AM   #43
djinva
djinva's Avatar
I am still a little confused on the rear shocks for a 71 with coils, I read several different KYB part numbers in this thread. 344055, 344085, 344067, 244055. Mine is dropped 4" with the springs and I want to be sure and order the correct shock. I was going with the 344055 but when I look it up it is for a Fiat and a Nissian Quest, which are both much smaller vehicles.
I would appreciate any input.
djinva is offline   Reply With Quote
Old 09-03-2010, 10:29 AM   #44
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Call ECE... they sell 2/4 drop kits which utilize the KYB shocks. They should be able to sell you the correct shock within a couple of minutes. Not reservations, the shocks will work.
-Nate
Old 09-07-2010, 11:02 AM   #45
djinva
djinva's Avatar
I called ECE and they tell me they use the same shock on the rear of these coil sprung trucks no matter how much it has been dropped. Problem is I was going to order from summitt to save a $ and I am still not sure of the correct KYB part number.
Old 09-07-2010, 12:31 PM   #46
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
As many know, there are several threads related to shocks for lowered trucks. I gleaned a bunch of useful info. Here is some that should answer the question about 4 in. drop in the rear.. You can take these numbers and cross reference them to whatever brand you like.
Front Shocks
Doetsch Tech Shocks*
DT4809G 1960-62 front Doetsch Tech Shock stock height
DTM1200GLL 1960-62 front Doetsch Tech Shock lower height
DT4052G 1963-72 front Doetsch Tech Shock stock height
DT4809G 1963-72 front Doetsch Tech Shock 1"-2" lowered
DTM1200GLL 1963-72 front Doetsch Tech Shock 3" lowered
• KYB Shocks KYB "Gas-a-Just" nitrogen*
KYM1200G 1960-62 front lowered KYB Shock, 2"
KY4809G 1960-62 front stock KYB Shock
KY4809G 1963-72 front lowered KYB Shock, 1"-2"
KYM1200G 1963-72 front lowered KYB Shock, 3"
KY4052G 1963-72 front stock KYB Shock*
Rear Shocks
KY4163G 1963-72 w/ rear leaf stock or 1" - 2" drop
KY4095 1963-72 w/ rear leaf or 2" - 4" drop
KY4052G 1963-72 w/ rear leaf or 5" drop
KY4163G 1960-62 rear lowered*
KY4231G 1960-62 rear stock
KY4095 1963-72 rear lowered 2"-4"
KY4052G 1963-72 rear lowered 5-1/2"
KY4163G 1963-72 rear stock
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 09-07-2010, 02:18 PM   #47
djinva
djinva's Avatar
thanks for the info, according to your chart I would need the KY 4095, however when I call summitt they say that is not a good part number and cannot cross it over to a KYB number, so I am still confused.
Old 09-08-2010, 12:36 PM   #48
Twisted78SS
Wide n'Low
My bad, in a hurry to get the info posted I should have pointed out some of these numbers came from the CPP website. I believe they are re-numbering the KYB shocks before they ship them. I will have to dig back and find the equivalent numbers.
Air Force Retired
Old 11-04-2010, 08:50 PM   #49
brans72
bump any word on new #'s looking for a 2/4 drop guys using KYB. Brandon
brans72 is offline   Reply With Quote
Old 11-07-2010, 08:47 PM   #50
brans72
bump
