Old 03-17-2009, 04:05 AM   #26
AKoldstyle
AKoldstyle's Avatar
Re: Prostreet / Dragrace 1972 blazer
Well ithink are 2 builds are alittle diffrent as mine will be quite tame for its power level and should idle smooth at 900 or so. I made mine able to drive and is built for future spraying which could be fun. I ordered 10 pistons from JE when I built this and it has there blown/nitrous tool steele piston pins.
I really think it can get into the 9's without juice!! So did the converter tech at ATI. Good luck with the project. Got any pics ?
AKoldstyle is offline   Reply With Quote
Old 04-12-2009, 03:51 PM   #27
AKoldstyle
AKoldstyle's Avatar
Thumbs up Re: Prostreet / Dragrace 1972 blazer
Here is my progress over the last 2 weeks. Then I loaded it up and dropped it off 2 have my 10 point rollcage welded in. The doors are jammed ppg black and this will be the whole trucks color. It should be painted in about another 2 weeks.
Old 05-20-2009, 03:58 PM   #28
AKoldstyle
AKoldstyle's Avatar
Talking More progress and body work
I am currentley just waiting for the body work to be finished on the tub as all the other pieces have been primed and jammed PPG black. I am going to try and have this completed and in a carshow on August 2nd here in AK which typically draws around 200 quality cars. Thanks for looking and ill try and update the paint pics as they come.
Old 05-20-2009, 04:26 PM   #29
JimmyFloyd
does the top fit on with the cage? looks a little high in the pictures.
Otherwise looks pretty badass
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 05-21-2009, 12:20 AM   #30
AKoldstyle
AKoldstyle's Avatar
Yes the top fits over the cage,there is quite a taper up from the windshield frame to the top.The cage was built by art morrison and designed for a pickup. I really should have done the cage install myself. The cage should have been mounted forward more and trimmed down the extra 5 inches that the rear floor comes up,then the rear bars would have had a lesser angle and gone further back. It still is a good fit and my seats leave me with lots of room. Thanks for checking it out.
Old 05-21-2009, 09:25 AM   #31
Burt4x4
Burt4x4's Avatar
That will be FTD = Fun To Drive!!!!!!!!
Keep us posted
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 06-23-2009, 02:44 PM   #32
AKoldstyle
AKoldstyle's Avatar
So here are a few pics of the body now.The dash,cage,and firewall along with the door jams have all been prayed. I need to hand and align the doors and front clip, then wetsand and the color can be layed out on the rest of the body. On the bright side the engine and trans are back in for good now! I am very happy with the smoothed dash and firewall.It is worth all the metal work we preformed. I will try keep the pictures current. I am planning to go 4 a ride in it in september. Keeping my fingers crossed. Thanks for checking out the progress.
Old 06-23-2009, 03:05 PM   #33
AKoldstyle
AKoldstyle's Avatar
couple more pics
Old 06-23-2009, 05:51 PM   #34
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
sweet!!!!!!!
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 06-24-2009, 04:17 AM   #35
AKoldstyle
AKoldstyle's Avatar
So here are some pics of the engine installed with carb and exhaust.I will try and get the doors hung and adjusted tommorow.
Old 06-24-2009, 11:14 AM   #36
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
great build
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 06-24-2009, 08:32 PM   #37
Yukon Jack
Post Whore
Yukon Jack's Avatar
Motor looks sweet setting in there!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-24-2009, 11:14 PM   #38
Hart_Rod
Hart_Rod's Avatar
That's going to haul some serious A$$!!!!
Hart_Rod is offline   Reply With Quote
Old 06-25-2009, 05:21 PM   #39
Frizzle Fry
Frizzle Fry's Avatar
I'm diggin it. I want to build a 2wd Blazer bad!!!
Frizzle Fry is offline   Reply With Quote
Old 06-25-2009, 05:48 PM   #40
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
LUV2XCLR8 is offline   Reply With Quote
Old 06-27-2009, 04:01 PM   #41
AKoldstyle
AKoldstyle's Avatar
Ok well i got both doors hung and one fender off the core support. I need 2 go by shims today for the fenders and then I will line them up and check out the hood fitment. this engine has been dropped and shoved back and still sits way up. I now understand fully the term shoehorned
Old 06-29-2009, 03:21 AM   #42
AKoldstyle
AKoldstyle's Avatar
Here the look i was aiming for, I still need to align all the sheet metal more.I had to fit the the fiberglass hood and trim it up alittle.I am still aways off from painting the outside of the body but its looking good.
Old 06-29-2009, 06:07 AM   #43
69trk
69trk's Avatar
very nice!!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 06-29-2009, 08:10 AM   #44
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
are you staying with those wheels or are you planning on going alittle wider
Gage
Old 06-29-2009, 10:42 AM   #45
Yukon Jack
Post Whore
Yukon Jack's Avatar
Still diggin' this project!
Old 06-29-2009, 12:45 PM   #46
AKoldstyle
AKoldstyle's Avatar
Yeah those are the biggest drag radial MT makes and I have seen people running low 8 sec passes on them.I can clear about 6 more inches if I need slick
Old 06-29-2009, 01:04 PM   #47
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
it looks like its tucked up in there alot what are the specs on the rearend
Gage
Old 06-29-2009, 02:58 PM   #48
project 67 sub
project 67 sub's Avatar
how tall is that cowl hood and where did you get it?
project 67 sub is offline   Reply With Quote
Old 06-29-2009, 03:12 PM   #49
AKoldstyle
AKoldstyle's Avatar
Ok the rearend is a narrowed 9inch from art morrison, the rims are 15x10 and those tires are 315/60/15. I can fit up to 20 inch wide tire,and a max of 33 tall. the tires measure 13.5 wide and 29.5 tall, so there is alot of rubber under there. As for the cowl hood its a bolt on 4.5 from unlimited products fiberglass
Old 06-29-2009, 03:17 PM   #50
AKoldstyle
AKoldstyle's Avatar
Here is an old pic from the bed tubbing and yesterday looking at the rear end pic for you. I like how my tires are tucked in and will only go witha bigger tire for traction at the track.
