Old 03-12-2009, 03:23 PM   #26
scrapmetalart
Junior Member
Re: Cutting Springs?
anyone cut 3" lowered springs to get another 1" or 2"?
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 03-12-2009, 07:33 PM   #27
crazy longhorn
Fabricate till you "puke"
I havent tryed that......but lower than 3" on a spring, you are really pushin the limits of the geometry on the front end. I wouldnt do it.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-12-2009, 07:47 PM   #28
texanidiot25
Eat My Rust
texanidiot25's Avatar
You'd be really running out of travel. 3in drop springs still give me plenty of travel for city and gravel road driving, but it's as low as I'd ever go and still be in the safe zone with travel.
texanidiot25 is offline   Reply With Quote
Old 03-12-2009, 11:15 PM   #29
72c10lover16
72c10lover16's Avatar
can anyone post pics of their trucks with cut springs? thanks
68 swb 4x4 327 4 speed
72c10lover16 is offline   Reply With Quote
Old 03-13-2009, 06:22 AM   #30
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
they look like any other lowered truck.
Old 03-21-2009, 05:04 PM   #31
justcuz
justcuz's Avatar
I've cut coil springs for years. I use a pair of vise grips to hold the spring and use as a stop for the circular saw. I use a metal cutting blade in my Skilsaw.
The vise grips act as a heat sink and I also wrap a wet rag around the coil just inside the vise grips. Then grind the end a little to clean it up and paint it. If the car does not sit perfectly level you can adjust it a little by turning the springs in the pockets. The lower control arm pocket raises as it comes around so there is some adjustment there. I've done all my Chevelles this way. Removed one coil from all of them, they set just where I want them. My pickup on the other hand may receive 3/4 ton springs. I am going to use some 31x10.50x15 tires on it and do not want any rubbing.
justcuz is offline   Reply With Quote
Old 03-21-2009, 05:15 PM   #32
Longhorn Man
i just chopped 1/4 coil off my 3 inch drop springs last week, used an air powered cut off wheel. Chucked the coil in the vice, put a hose clamp on the metal (to keep a straight line) and let her rip. Not enough heat to worry about at all.
Old 03-21-2009, 08:40 PM   #33
crazy longhorn
Dump it upsidedown in a 5 gal bucket of water,cut the exposed ring with the old "fire stick"......also not enough heat to worry about crazyL
Old 03-21-2009, 09:54 PM   #34
texanidiot25
Eat My Rust
31x10.5s fit great with no rubbing, even when flexing the truck out some, and I have a 3in drop in rear.
Old 03-21-2009, 10:05 PM   #35
justcuz
justcuz's Avatar
Thanks, I am really more concerned about the front. As it sets now the springs are right in the middle of their travel. Droop and compression are equal. I don't want rubbing on compression of the suspension. Other thank the ball joints does anyone know if 1/2 ton and 3/4 ton upper and lower control arms are the same? This is a long bed truck and it has the 5 lug stuff with a 3.07 rear end. I have 3/4 ton spindles, rotors and calipers and am tempted to convert it to 3/4 ton. I know lots of guys want the 1/2 ton stuff and I would not mind the 3/4 ton suspension. With a 4.10 rear end and a
700r4 it would make a great tow rig.
Old 03-21-2009, 10:12 PM   #36
crazy longhorn
The upper arms are the same(just swap the ball joints). The lower arms on the 20 series have a larger hole for the pressed ball joint.........crazyL
Old 03-21-2009, 11:03 PM   #37
6packed
OL' YELLER
6packed's Avatar
Originally Posted by 72c10lover16 View Post
Anyone have any advice on cutting springs. I kinda was thinkin bout cuttin my springs to lower my truck. im on a very limited budget and i drive this truck everyday. Any feedback or opinions would be appreciated.
Sent me a PM when you need springs to put your truck back to stock.
CALLING IT QUITS - LETS MAKE A DEAL
1967 GMC - Ol' Yeller - 305 V6 cid
1967 GMC 4x4 - Ol' Black'er - 292cid ( project)
1967 Chevy Ol' ???? -Parting out
1971 GMC - Ol' Grey'er (parting out) - 350cid
1969 GMC - Ol' Red'er (parting out)
1970 Chevy - Ol' Primer (parting out)
& counting
1995 Blazer
6packed is offline   Reply With Quote
Old 03-21-2009, 11:41 PM   #38
Shane
Shane's Avatar
Not sure I have ever seen sarcasm used as a marketing tool.
Shane is offline   Reply With Quote
Old 03-22-2009, 12:03 AM   #39
texanidiot25
Eat My Rust
How much drop do you have up front? If I have enough spare time, I can swap my rear tires up front and test it. I have 3in dropped up front as well, but I wouldn't run 31x10.5s with that much drop. 235/75? Is what I've got up front, and as far as diameter it just starts to truck up into the wheel well when you look at it at eye level... a 31" tall tire would just be too large looking up front IMO...
On a stock truck though, a 31" tire should be no problem in the fitting or looks department.
Old 03-22-2009, 12:18 AM   #40
Pont406
I cut front springs before. I want to try and lower the rear by heat. I never done this. Do the springs actually get red from heat while lowering?
Pont406 is offline   Reply With Quote
Old 03-22-2009, 12:50 AM   #41
justcuz
justcuz's Avatar
Thanks Crazy L, Texas my front springs are not dropped at all, just stock and got a zillion miles on em. I have the rear end up on stands for the gear oil change and the Lock Right install. My pinion shaft pin/bolt is broken and I am going to try and remove it by using shrink tubing around the broken piece and a new bolt and heating the new bolt with the heat gun to see if I can pull it out. If it does not rain in the morning I'll post a couple of cell phone pics up. The cord for my digital camera to transfer pics to the computer is with my wife upstate. We both have the same camera, but only one cord. She is visiting our daughter during her spring break from college and they are taking pictures and sending them to me so I can see their day to day adventures. Today was the Jelly Belly Factory and the Budweiser Brewery.
Old 03-22-2009, 01:08 AM   #42
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
subscribed
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-22-2009, 02:07 AM   #43
jbristo67
resident oilfield trash
jbristo67's Avatar
Originally Posted by 69halfton View Post
when you cut the springs in front, how much more harsh is the ride? i would have thought that the spring would have been softer this way, and that the truck just bottoms out a lot easier?
I didnt think it was any harsher last time i did it
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-22-2009, 06:49 AM   #44
72freak
Rottenwood Garage Member
72freak's Avatar
AMEN brother!
Here are 2 trucks with 2.5/3" cut front and 5" replacement rears. No difference in ride and no popping when turning. We will need to consult with longhorn man but I am fairly sure he will agree they also look like cut spring lowered trucks!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 03-22-2009, 04:07 PM   #45
justcuz
justcuz's Avatar
Here is my front end and with the tire up against the fender. No cutting required on these springs, for the bigger tire that is. 2 pics of the suspension, 1 of the stock tire, 1 of the one I want to install and a side shot.
Old 03-22-2009, 06:00 PM   #46
Jim Osborne
Before you cut you need to measure the height of your frame on each side to make sure one spring is not weak also gauge tire presure to make sure its level if its the same then you can cut the same off each spring but I would use a cut off wheel to keep the right temper in your spring good luck
Jim Osborne is offline   Reply With Quote
Old 03-22-2009, 06:16 PM   #47
cstm68
cstm68's Avatar
here is a pic of the old colis out of my 68 that the P.O. has torched (they are supose to be strait)
the truck road crap and looking from the front or back the truck was not level
iv cut a few sets of coils and have had great luck but it still cant beet the new drop coils i put in with my front end rebuild
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
